Reply 40 of 78, by ElectroSoldier
- Oldbie
Mondodimotori wrote on 2025-03-24, 19:53:Horun wrote on 2025-03-23, 22:05:I did not have any issues (with my e8500 or the q9650) with Call of Duty 4 MW or WAW which recommend a dual core 2.4ghz or better, those games do utilize dual cores.
My only downfall is the nV 8800 GT but have kept it since all the parts are from same 2007-2008 era, there are better vid cards...I've got myself a much faster GPU. The XP system came with an HD4850, wich was decent enough at 1024x768, but I wanted something similar to a 560ti. I ended up finding an auction for a Sapphire HD 6970, and snatching it for 21€ shipping included. Now I can easily max out games up to 2008 even at 1280x1024, and even add a sprinkle of anti aliasing. Unfortunately some higher details settings for objects and rendering distances will still hamper performances, and it's not the GPU bottlenecking, because I can see it's usage dropping to less than 80%. I guessed it must be a CPU bottleneck. After all those recommended settings weren't there for rocksolid 60 fps at max settings. It's not like today where, if you meet recommended settings, 60 fps at 1080p and higher are a no brainer.
And that's why I wanna max out the gaming potential of the CPU too. Then I can OC it to a 400MHz FSB and run it 1:1 with the 800MHz Corsair ram kit I got. It's a pretty tight ram kit.
Nice GPU for our uses and more than a match for the E8600.
At 21euros it would be rude not to use it.
I have an E8600 system, I run Windows 2000 on it and it runs amazingly well. I had XP on there to see what happens before settling on i7 power for XP, but kept the E8600 for Win2k.
I dont think you would regret that combo, and like you said its more than capable of playing any XP game.
