DudeFace wrote on 2025-03-27, 20:11:
Maz Hoot wrote on 2025-03-27, 07:10:Hello, […]
Hello,
I get 2 toshiba satellite 320cds in bad condition, one had his hard drive broken and the other could start with win95 but the screen is difficult to read, blurry and not much light, and the keyboard works anyhow (double or wrong keys etc…).
So I removed the disk from the computer with garbage screen and keyboard and put it in the other one with a better screen and keyboard. I installed windows98se on it because I thought it would make things easier. There was some errors during the installation, but I can boot in win98 (I see an error with a file, I press ok, then an error with graphic card but if I cancel I can boot normally (in a window but it’s not a big deal)).
My principal problem is about the sound card which I want to use with adlibtracker2
But I can’t use the sound card (OPL3-SAx WDM YAMAHA). I tried with both SETUPSA and UNiSOUND but I have these errors :
With SETUPSA :
« SB reset error ! » (2 times)
« SAx board not present ! »
With UNISOUND :
« No PnP card detected. »
I tried also from freedos (I have the hard drive from a toshiba tecra 530cdt with freedos so it’s easy to test with it too) but it’s the same errors…
When I’m in win98, in system, opl3 driver looks like fine. At first there was a « ? » But I reinstalled the driver from win98se and now it looks ok (but I don’t know how to really test it on win98 and the final goal is to use it from ms-dos with adlibtracker2
try the driver in this post its from a 300cds/cdt driver cd,
Re: Advice on retro gaming Windows 98 build
On the second s320cds I installed the driver and I can now start setupsa.exe, but there is still no sound. In adlibtracker2 the playing works but there is no sounds from speaker or from headphones
Luckily, one of the 2 s320cds works now good because I saw that the screen could be ok if I turned the hidden wheel on it adjusting « brightness? » (yea I am stupid…) and I replaced the keyboard with the other computer keyboard which removed the keyboard problems. And sound works on this one (not from speaker where there is nothing, but from headphones it’s ok). The screen is bad but as I readed it’s related to several satellite CDS (adlibtracker2 playing is blurry, while on external screen with vga it’s ok). So there is probably nothing to do for better display ?
About the second one where there is sound and cd-rom problems, maybe I can use it too, it could be usefull if the first one is broken someday
So on the second one, the internal cd-rom is not recognized. Sometimes it’s recognized but the most time not, if it was I could reinstall windows98 without errors because now I know that if I point the cd-rom locator when prompted errors, it can install missing files so maybe it will repair graphic errors at startup and maybe sound ? Or maybe the sound problem is due to the chip and there is nothing to do ? 🫤
This laptop is not in good condition, I removed the keyboard because it acted crazy, unusable, it works with an external keyboard with a ps2/usb adaptor and a usb mouse.
In the bios there is no CD-ROM. Sometimes it is here, but the most times not, and several last times I rebooted it was not here, but when I insert a cd, it makes normal reading physical sound, but nothing in win98 and in bios…
My music (chiptune, post-punk, world, industrial) : https://mazhootmusic.bandcamp.com
