First post, by chinny22
So part of where I work is an old papermill that closed mid 2015.
We use the ground floor of the old factory as a storage warehouse, however upstairs is all but abandoned and untouched since the plant closed its doors for the final time.
Looking in each direction.
One day I decided to go upstairs have a bit of a look and found this room
I guess it was the IT room as off to the side was another room with a bit more IT equipment and old Comm's rack.
Well after just under 10 years of been neglected I guess it was my calling to save it all!
So what did I save? from left to right
- 386 DX40
- Socket A PC with Biostar M7VIT Grand Motherbaord.
- HP Visualise C3600
- MMAC-8FNB as well as some Token Ring Patch Panels)
3 HP VEi8 P3 500's
1 HP VEi8 P3 600
2 ViewSonic CRT's
3 HP 5:4 TFT's
a PS2 keyboard and US Robotics modem 33.6 Modem
As well as some 5.25 and 3.5 disks including official Dos and Windows 3 install disks.
What I didn't save.
2 HP Deskjet 695c
I was tempted to save 1 as a "prop" We had a very similar HP back in the late 90's and you just don't see them anymore. but decided I don't really have the space for something I don't even want to use.
Epson Inkjet
At first I got excited thinking it was a Dot Matrix, I've no interest in running inkjet printers again.
24 Port Cisco 10/100 switch, Forget the exact model.
Still may rescue this, looking online not much demand however this does have the fibre ports which makes it marginally useful.
The Plan? erm....
Everything is filthy. I get the impression it was in storage here before the closure, then another 10 years neglected with Pigeons, rats, mice, and whatever else having run of the place.
None of this is tested, I've just given everything a quick wipe down to remove the excessive dust and bird poo and dumped it in my garage where at least it's safe from any clear out.
I got real excited about the 386 as it has 286 badging so been upgraded sometime in it's life. I kind of like the idea of "modernising" a 286, Large HDD, Network, etc. but with my first PC being a 486/66 a 386 just feels like a slow 486.
I'm thinking I'll have a play then use a case for a homeless P1 I have.
The Socket A I'll probably part out. The case is missing the side panel.
The Visualise C3600 I thought was some kind of Intel Workstation it isn't and runs HP Unix, not really my area of interest. I'll see if it works then sell on.
The Token Ring stuff is closer to my area of interest, but again. Probably not worth the space, I'll probably sell it.
The 4 HP desktops are very much my interest, so much so I already own 6 similar P3's... Need to work out what stays and what goes.
5:4 and CRT's are always nice to have a bit of a stockpile, I'll probably hold on to them.
The Modem is part of my Dial up network setup I still plan on doing!
Reply 1 of 15, by keropi
oooh very nice haul!
any old hardware saved is better than rotting in some storage and ultimately end up in the dump , good work!
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 2 of 15, by gerry
this is fantastic! i love to see abandoned things returned to some use - whether its cars, computers, tools, toasters - anything really 😀
Workplaces are particular hotspots of old gear of all kinds, often left when the place closes as having no value - or at least no value to spend time sorting and selling
i those pics i can see what looks like electric motors, some safety gear, lots of lights, all that railing - so much stuff that could be re-used but wont be due to the cost of doing so
i enjoy some YouTube videos exploring abandoned office and industrial places and sometimes see good stuff slowly rotting away
you did well to rescue some pieces here
Reply 3 of 15, by debs3759
I used to love rummaging around old abandoned and derelict commercial buildings in the 80s and 90s. Made a tidy sum selling some of the stuff I found throughout the West Country. Even better was the squat I lived in in the 80s. If I had known about squatters laws back then, the house I lived in would have been mine after 12 years, I just couldn't prove I'd been there that long. House was worth £750K in early 90s, hadn't been lived in for 35 years, and had a fully equipped WW2 dental surgery in the front room, along with thousands of vials of noradrenaline (probably very unsafe to use after so long). Perfect for a film prop 😀
Reply 4 of 15, by Pino
Nice save, you are a good man!
Ps.: My first ever PC was a 386DX 40 on this exact same case, have been looking for one for a while, I'm sure at some point I will score one at my local recycling center, as this cases were pretty common.
Reply 6 of 15, by StriderTR
That's amazing! A day saving old hardware is a good day indeed!
Sadly, where I work, they go through a ton of hardware, but due to policy it MUST be destroyed and recycled. I was willing to save some old late 90's/early 2000's systems that were replaced a couple years back, only to find out it wasn't possible. The rules are kinda silly, "safety and security" are the core reasons. It's the healthcare industry, security is to remove any possibility of a HIPPA violation, even though all storage media is removed and handled by internal IT. Safety is "infection prevention" since the hardware is used in hospitals. So, it's all liability. You might get a virus from the PC. 😜
Either way, love seeing stuff like this. Have fun working on those systems! 😀
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 7 of 15, by chinny22
StriderTR wrote on 2025-04-10, 16:45:
I've work at similar places in the past, and I understand. It's just not worth their time to really understand the risks, just play it safe and apply a blanket rule.
Sometimes I can get around this by swapping out old/dead hardware for the items I actually want. That way they still have something physical to mark off their register.
But it's not always possible and have seen some nice stuff sent off to the recycler.
I'm lucky it's not the case here, whenever we do a big clear out of our company's stuff including furniture management always says if feel free to take it before it's sent away.
So anything from the previous company is even less of a concern.
debs3759 wrote on 2025-04-10, 14:52:
Made a tidy sum selling some of the stuff I found throughout the West Country.....
gerry wrote on 2025-04-10, 08:22:
Don't think work's generosity extends to stripping the place 😉 Which is a shame as mentioned above some of this stuff would sell for decent money but not enough to cover the actual cost of removal.
Work may be ok with me spending 20 minutes chucking a few old computers in the back of the car but spending a day or coming in over a weekend unsupervised (and therefore a possible liability claim) may be pushing it.
All I can hope is I've pleased the retro gods in saving what I have and they bless me with un-blown cap's for a few more years
Reply 8 of 15, by PD2JK
HP Visualize C3600, HP 9000/785, were introduced in 2001 for $12,243
I would reconsider. That's sounds/looks like real fun. Not 'your' standard x86 stuff. 😀
Like the others said, great hauling.
has all kinds of stuff
Reply 9 of 15, by gerry
chinny22 wrote on 2025-04-11, 06:31:
I suppose turning up with a flatbed truck and an angle grinder is a bit much 😀
will be good to see what works out of what you got though, i'd guess most of it - depends if it was moved around roughly or got wet or something
Reply 10 of 15, by chinny22
PD2JK wrote on 2025-04-11, 07:03:
I would reconsider. That's sounds/looks like real fun. Not 'your' standard x86 stuff. :) Like the others said, great hauling. […]
When I could tell it wasn't generic x86 (and you can tell if you look at it closer) I was hoping for something Alpha NT4 compatible to play with.
But *nix isn't really my interests and CAD is wasted on me without a creative bone in my body.
But some old networking hardware on a topology that's all but dead. Come on thats sexy right?
Reply 11 of 15, by H3nrik V!
For a moment I was amazed that there were still 386s in use in 2015, until it dawned on me that I myself decommissioned a 386sx from my old workplace in 2021, and a 386dx40 from my current workplace last year 🤣
At the moment, our corporate IT's policy is that we can buy of hardware more than 3 years old for peanuts, as long as storage has been wiped with an approved piece of software.
Reply 12 of 15, by gerry
H3nrik V! wrote on 2025-10-09, 05:44:
out of interest were they being used for with laboratory equipment / instrument or as control for some machine? that's where I've seen some last a long time
Reply 13 of 15, by liqmat
Something about large industrial spaces like this that I really like. If it wasn't so cost prohibitive I would love to convert a warehouse like this into a living space. Maybe even get that high capacity bridge crane operating again.
Reply 14 of 15, by H3nrik V!
gerry wrote on 2025-10-09, 12:25:
Yes, the 386sx had some GPIB instrumentation cards in. Can't remember if they were removed or not. The 386dx40 ran some test equipment on serial port IIRC.
Reply 15 of 15, by chinny22
As you both say its still quite common to see long obsolete PC's hooked upto industrial equipment so very much could have still been in use.
Although it may have just been in storage or for parts with missing the HDD, PSU cover and I/O covers or any cards suggesting bit of cannibalism goin on.
liqmat wrote on 2025-10-09, 13:52:
These old building definitely have character. More then modern factories that are not much more then large tin sheds, which is fine no real reason to make a factory pretty, but still it's soleless
