First post, by Jackhead
I have a P2B-D Rev 1.06 that running two CPUs.
First i tryed installing Win2k SP4 and leave F5 so its installed with the ACPI HAL. With my SCSI controller and GPU installed anything is working fine.
But my problem is that i want to install many Expansion cards, and i dont want ACPI to control my IRQs. Soon as i plug in more boards i got problems like bluescreens.
So i want to reinstall W2k with another HAL. Question is what option should i choose to have usage of both CPUs and IRQ managment like Win98?
MPS Multi or standard ? Should i aktivate/deaktivate MPS1.4 in my bios?
Or is it not possible to use the P2B-D without acpi under win2k?
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - MPU-401AT with YucatanFX / Roland CM64
Win98SE: Asus XG DLS 1x SL4XY - SG Voodoo 5 6000 PCI - 1GB RAM ECC- Audigy 2 ZS - MX300
Reply 1 of 4, by red-ray
I save a SIV save file for an ASUS P2B-D that I got 2020-02-20 and it's running Windows XP Service Pack 3 with the HAL MPS 1.4 - APIC platform, W2K should also work with MPS 1.4.
AFAIK to have both CPUs you need to use either ACPI or MPS otherwise only one CPU will show up.
I would use Device Manager to change the HAL to MPS 1.4 (you don't need to re-install) and see it it does what you would like. Remember to check that MPS 1.4 is selected in the BIOS.
Reply 2 of 4, by Jackhead
the question is, can i adjust with MPS 1.4 my IRQs in bios again like with win98? Or is this only possible with standard HAL.
Reply 3 of 4, by red-ray
Jackhead wrote on 2025-04-12, 21:13:
IDK, but the MPS table has IRQ and INT entries so I suspect so. Swap the HAL and try it.
file.php?id=216844
Reply 4 of 4, by Jackhead
I need to reinstall. Changing to MPS Multi ends up my system dont get the adaptec drivers installed automatic again. When i trying manualy to install then result in a Bluescreen..
That IRQ sharing comes from W2k right? It has nothing todo with ACPI or MPS?
For example, my SCSI controller is IRQ10 and its shared with 2 other devices..
I just want win98 IRQ managment with multi CPU support 😀. Maybe i need to try NT4 because its based on Win9x.
