Reply 4880 of 4937, by pete8475
H3nrik V! wrote on 2025-04-14, 06:17:
Well, you actually have an image with a Work Bench on your work bench. Epic!
hah, I suppose so.
I just tried out the A2000 and it only shows a black screen. I suspect there is some unseen corrosion under some of the sockets and I can see some ugliness on the legs of a few of the ram chips still. I think I'm going to keep 1 of the 2 working Amigas and give the 2000 and the rest of the stuff to an Amiga enthusiast I know if he wants it.
Reply 4881 of 4937, by dm-
found yet another BlasterBoard M003
looks like later revision: it has HIp6004BCB PWM, Game Port, USB port soldered. Bios 2000 year.
number 3 in my collection.
The attachment 1.jpg is no longer available
The attachment 2.jpg is no longer available
The attachment 3.jpg is no longer available
The attachment 4.jpg is no longer available
The attachment 5.jpg is no longer available
Reply 4882 of 4937, by Ozzuneoj
dm- wrote on 2025-04-15, 07:47:
found yet another BlasterBoard M003 looks like later revision: it has HIp6004BCB PWM, Game Port, USB port soldered. Bios 2000 ye […]
Man, these must have been released in very limited markets. Awesome that you keep finding them... just wish I could stumble across one myself. Such a unique board. 😀
Reply 4883 of 4937, by PcBytes
Make that two of us so far. I'd love to have one of those BlasterBoards.
Reply 4884 of 4937, by RandomStranger
Got this for helping to empty a coworker's basement. Nothing special, but at least not a Celly-D FX5200 combo.
The board is a bit warped, but otherwise doesn't look damaged.
The attachment IMG_20250416_111932.jpg is no longer available
The attachment IMG_20250416_112214.jpg is no longer available
The attachment IMG_20250416_112411.jpg is no longer available
The attachment IMG_20250416_112607.jpg is no longer available
Reply 4886 of 4937, by RandomStranger
I don't know what you mean. It is a 9200 SE. I didn't state otherwise.
Reply 4887 of 4937, by Tiido
ohshit, I somehow read the opposite of what was meant. I blame the sleep deprivation I have been having ! 🤣
I used to use a 9200SE in a PIII machine I had in 2008 or so, until it got replaced with a 9600XT from a computer repair place I was an intern at. I got to take home all kinds of old stuff from that time, but unfortunately for me, I didn't value any of the older things then as I do now. There were K6-2/3 things that ended up in recycling that I would love to have now...
Reply 4888 of 4937, by RandomStranger
I had the 64MB version of the 9200SE until I forced it to run Battlefield 2 back in the day and it started artifacting in everything. Probably the same little heatsink this one also has couldn't handle the load. I still have the box and everything for that one. Still looking for the same Connect3D card to make it complete.
Reply 4889 of 4937, by weedeewee
a PC-CHIPS M423 ver 1.1.1
Now I finally have a mainboard (if it works) to test the opti vlb et4000 card on !
Do not ask Why !
Reply 4890 of 4937, by Horun
weedeewee wrote on 2025-04-20, 18:18:
Hope it works ! Are you sure it is a M423 ? Thought they were mostly ISA only.
Is it like this: https://theretroweb.com/motherboards/s/pcchip … -486-vesa-chip8 ?
Can you post a good picture ?
Reply 4891 of 4937, by weedeewee
Horun wrote on 2025-04-21, 01:33:
Hope it works ! Are you sure it is a M423 ? Thought they were mostly ISA only. Is it like this: https://theretroweb.com/motherb […]
Image #3 https://theretroweb.com/motherboards/s/pcchips-m423 is how it looks.
Notice the clearly readable M423 ver 1.2 in the top right corner of the photo.
Mine says ver 1.1.1. Makes one wonder what is different between versions.
and if you look closely at image #2, one notices that there are 2 slots that aren't ISA slots.
Do not ask Why !
Reply 4892 of 4937, by pete8475
weedeewee wrote on 2025-04-21, 07:13:
Image #3 https://theretroweb.com/motherboards/s/pcchips-m423 is how it looks. Notice the clearly readable M423 ver 1.2 in the to […]
EDIT - I have been informed those are NOT in fact EISA slots, do NOT install EISA cards in them!
Thanks to Disruptor for correcting me.
Disruptor wrote on 2025-04-21, 18:24:
This board does not have EISA slots. It has one flavour of Opti / Orchid local bus. More information here: OPTi Local Bus varian […]
More information here: OPTi Local Bus variants
WHEN YOU USE AN EISA CARD YOU DAMAGE BOARD / CARD or BOTH!
Please remove or edit your post. It is dangerous.
Those are OPTI local bus slots not VLB or EISA.
486 OPTi Local Bus
Reply 4893 of 4937, by weedeewee
pete8475 wrote on 2025-04-21, 17:45:
Those are EISA slots not VLB.
https://en.wikipedia.org/wiki/Extended_Indust … rd_Architecture
EVERY FRIGGING TIME !
While those are actually the same connectors as on any EISA board.
They are in this situation, on this mainboard, absof*kinglutely not EISA !
They are in fact OPTI Local Bus Slots.
Sticking an EISA card in these will either do damage to the mainboard or card or both.
If you do not believe me, dig a little further.
edit: duh.
Do not ask Why !
Reply 4894 of 4937, by Repo Man11
I saw an ad in the Craigslist free section for a 2010 or so computer for free. I initially decided not to get it since I'm actually trying to get rid of stuff to get ready to move, but I then decided to try and grab it anyway. The guy said sure, and that he also had a box of old computer stuff. I guess I've been living right, because he gave me a whole bunch of great old stuff. But this was a real surprise, a VooDoo 2 1000! I haven't properly tested it yet, but I stuck it and an S3 Trio in a Socket A board with WinXP, and everything works. I'll have to put it in a Win98 system to be sure. Another really cool thing is an Abit KA7 motherboard! It needs to be recapped, but I have an untested Slot A CPU that I've been wanting to try for years now, and I'll finally have a chance!
Edit: I tested it in a P3 system, and it works fine!
Reply 4895 of 4937, by weedeewee
Found a little passive
- PCMCIA PCcard Compact Flash adapter - https://imgur.com/a/LF7QQZH
and an ISA card,
- FASTLINK 20.190.2310.014 VBE - https://imgur.com/a/xvqRi7i
unknown what functionality the ISA card offers nor which software to use nor where to find it.
Rough guess, some sort of serial communications card
Do not ask Why !
Reply 4896 of 4937, by Repo Man11
The capacitor plague personified...
Reply 4897 of 4937, by Repo Man11
Some of the games.
Reply 4898 of 4937, by Repo Man11
A Chaintech 5HTMO motherboard. Did they ever make I/O shields for this style of motherboard to fit in an ATX case?
Reply 4899 of 4937, by Ozzuneoj
Repo Man11 wrote on 2025-05-24, 23:31:
Hmm... it seems they did!
https://en.m.wikipedia.org/wiki/File:Several_ … %28smial%29.jpg
