First post, by lepidotós
- Member
I know PCI Express to AGP and vice versa does, and that makes sense. I'm curious if wiring a PCI chipset up to an AGP card edge specifically (i.e. Voodoo 3) needs any internal reworking or bridge chips to work. I would suppose not, if AGP is a superset of PCI, it should just act like a 66MHz, isolated PCI bus in that situation (or the card look like a lazy AGP card that doesn't really do many fancy things to the bus) based on how I understand it, but I'm just double-checking for confirmation.
Thanks.
"I have to blow everything up! It's the only way to prove I'm not crazy!"
—Dr. Gordon Freeman, May 2000
