First post, by Ammo_Headache
My newest acquisition is an EISA based system which included an ATI MACH32 EISA card (YAY!) and a DTC 2290 EISA EIDE/Floppy controller. When I received it, the DTC's jumpers were set to have the BIOS disabled for that card. I adjusted it to enabled with memory address C8000. The drive I have connected to it is small (240mb) so I have the jumpers for 64 head mapping set to disabled. The issue is (and this could be perfectly normal) I don't see any option ROM display when booting. I would think it would perform like the ISA or VLB cards from DTC where the BIOS shows what drives it recognizes during boot, but nothing. I changed the memory address to D4000 but still no luck. The drive is working if I set it up with the correct settings in the motherboard's AMI BIOS. I know this isn't a common card and I can't find a manual for it. The only thing I have to go off of is the EISA CFG file's notes. I have run the EISA config utility and the card seems to be operational, just nothing to indicate that it's BIOS is active. I know it is a longshot but does anyone have this card that can confirm or deny that I will see the ROM displayed during boot? Thanks!
