Ivy Bridge XP system
First post, by Sly_Botts
Motherboard: ASUS PBZ 77-v LK
The attachment Screenshot_20250419-113628.png is no longer available
Cpu: Intel i5 3570k
The attachment Screenshot_20250419-113540.png is no longer available
Ram: 8gb generic DDR3 1333mhz ( I know about the 4gb limit on XP however this will allow for dual Channel performance on the 4gb being used)
The attachment Screenshot_20250419-113823.png is no longer available
GPU: ASUS Direct-CU II GTX 760
The attachment 2130-front.jpg is no longer available
Sound: Creative x-fi xtreme music
The attachment NR603a1_639x480.jpg is no longer available
Storage: Crucial BX500 2.5 256gb ssd
OS: Windows XP SP 3
Media: Generic SATA optical DVD drive.
It is possible to commit no errors and still lose. That is not a weakness, that is life.
Reply 1 of 13, by Sly_Botts
Additional pics
Keyboard: unicomp IBM type M PS2.
The attachment ultra_classic_ibm_keyboard_beige_large.jpg is no longer available
Mouse: Logitech ps2 optical wheel mouse.
The attachment 61WuwP0RmGL._AC_UF894,1000_QL80_.jpg is no longer available
Reply 2 of 13, by Sly_Botts
My original plan was to use an ensoniq audiopci 1370, partition the drive and have a DOS 6.22 partition for DOS gaming. However Dos does not like to share a drive with with XP. It kept corrupting the XP boot sector. So I kept it as a pure XP system. Using rivatuner statistics server to set a frame limit based on monitor resolution, and vsync to maintain a smooth experience with minimal input lag. I set frame limit to 2 frames below refresh rate. The Nvidia profile inspector proved useless for me.
Refresh Lock is mandatory for all my XP systems since XP loves to default to 60hz.
Monitor: Samsung syncmaster 955df 19" (mine is black)
The attachment 36846f76ad14b73462d44c2dd45c8c2333adfa98-samsung-syncmaster-955df-slika-20638698.jpg is no longer available
Reply 3 of 13, by SScorpio
Sly_Botts wrote on 2025-04-19, 17:38:
Does your motherboard BIOS have a boot device menu? I can't remember when that became a common feature but it's usually hitting F-10 or another F key and it will list the drive. You can configure it to default to XP. But boot off a separate DOS drive if you want.
Reply 4 of 13, by Sly_Botts
SScorpio wrote on 2025-04-19, 18:23:
Yes but Dos doesn't like to be 2nd fiddle. It likes to interfere with the boot sector. If I had a 2nd drive I'm sure it would be fine.
Reply 5 of 13, by SScorpio
Sly_Botts wrote on 2025-04-19, 18:36:
That's what I'm saying. Have a second small physical SSD in there for just DOS and use the BIOS boot manager when you want to boot to that instead of XP.
DOS gaming generally isn't very write heavy. You can get 32GB 2.5" SSDs for under $10.
Reply 6 of 13, by gerwin
I had a habit of installing DOS 7.1 before installing Windows XP. On a FAT32 primary partition. It always worked fine. The Windows XP installer will keep DOS 7.1 as a boot option.
Reply 7 of 13, by Falcosoft
There is no such general problem with DO
S. DOS can coexists with WinXP partitions on the same drive without problems.
Actually DOS can run from the same partition as WinXp if XP is installed on a Fat32 partition. This way you can start DOS from the XP boot menu with the help of an inserted section into boot.ini that refers to BOOTSECT.DOS as the original boot record.
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 8 of 13, by Sly_Botts
Falcosoft wrote on 2025-04-19, 20:15:
There is no such general problem with DO S. DOS can coexists with WinXP partitions on the same drive without problems. Actually […]
Maybe my issue was XP being NTFS then. I just noticed whenever I installed DOS it would screw up my XP boot when I switched back to XP. I did read somewhere that DOS likes to be installed on its partition before XP. Mind you I'm not mucking with boot.ini either.
Reply 9 of 13, by Sly_Botts
gerwin wrote on 2025-04-19, 19:54:
This is a great suggestion.
Actually this triggered a memory of this in my college days back in the early 00s
Reply 10 of 13, by chinny22
Typically I'll partition my drives like this
Primary Partition
C:\Fat 32, Win98 (same as Dos 7.1) 2GB
Extended Partition/Logical drives
D:\ Fat 32, Data (all remaining space not used in c:\ or e:\
E:\ NTFS, WinXP, 4GB
I use fdisk to do the partitions, that way I know the Win9x stuff will understand the disk layout
Reply 11 of 13, by theelf
Hi, my main computer is a Sandy Bridge i5-2520M, 8GB Ram. I use windows XP as only and main OS, then i need as much updated i can, hardware and software, because i need for my everyday needs
I found Primo Ramdisk very good to do a ramdrive of unussed ram areas of xp 32bits, i create a compreesed Z: drive and there i have a 2GB swap file, and rest is for temporary files. I will upgrade soon to 16GB, to do a 4GB swap and leave 8Gb to temp files, because i compile a lot with cygwin and mingw and temporary ram drive is amazing fast
Reply 12 of 13, by Sly_Botts
theelf wrote on 2025-04-22, 14:15:
That's awesome!
Reply 13 of 13, by ATi_Loyalist
This is great! Seems like Ivy Bridge is a great platform for XP, I am just beginning to acquire some Ivy Bridge parts for a SuperXP build. Will be following this!
P4/XP Rig: P4C800 | P4 3.4 | Radeon X850 Pro
A64/XP Rig : A8V | A64 X2 4400+ | X1950 Pro
Ancient Rig: Pentium 166 W | S3 Trio
