Sis 540 Aiming For The Stars!
Reply 20 of 42, by Kruton 9000
Sphere478 wrote on 2025-04-21, 05:55:
havli wrote on 2025-04-20, 10:12:
I think it survived, no magic smoke 😀
Thank goodness.
So did any of these 133mhz socket 7s ever have a functional AGP? Is there a mobo model to look for?
Quite often integrated graphics in a chipset are connected via the internal AGP or PCI bus. I think this is because this approach simplifies the integration of the graphics chip into the chipset. In this case, the pins on the AGP bus become busy and it becomes impossible to make a full-fledged AGP connector. This is most likely the situation with the last Super Socket 7 chipsets.
Reply 22 of 42, by nickles rust
analog_programmer wrote on 2025-04-18, 18:19:
I'm attaching the latest PC Chips M586LMR AMI BIOS (010514S) from TRW site with almost all of its settings unlocked.
Thanks for posting this. Do you know if there is a similar suite of un-lockable settings for the SiS530? I saw on Jan's web site that he has a K6 patched bios for the Asus P5S-B. I was looking at one of these for sale, but I wonder if its bios will be too limited. I'm trying to find a K6 board that will work with later PCI or PCIX disk controllers.
Reply 23 of 42, by analog_programmer
nickles rust wrote on 2025-04-22, 22:33:
Does this modified BIOS work fine, if you've already tried it?
I can check if there are some hidden useful settings in the BIOS menus for Asus P5S-B motherboard. I still can't help with adding support for new CPUs (like adding a K6-2+/III+ support), but yeah, there's already a patched version with added support for K6 "plus" CPUs for this board on the Jan's site.
I'll send you a PM later, so we don't dilute this thread with off-topic posts about another model motherboard.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 24 of 42, by nickles rust
analog_programmer: Thanks for sending that message!
About the SiS540 build: Were you able to replicate the results that scrap computing shared in the video? A 133MHz bus should really help on Socket 7...
Reply 25 of 42, by Sphere478
It’s alive!!!
The attachment image.jpg is no longer available
Also, can anyone verify compatibility of these add ons I found in my drawer
I still need to find a VGA header maybe I can steal one from a low profile video card?
Sphere's PCB projects.
Reply 26 of 42, by Sphere478
I tried this in the bottom slot, it prevented system booting. Perhaps a bios setting? Removal allowed POST.
Edit: no go in top slot either. Darn.
Reply 27 of 42, by PcBytes
Sphere478 wrote on 2025-05-06, 18:40:
It’s alive!!! […]
It’s alive!!!
Also, can anyonr verify compatibility of these add ons I found in my drawer
The PS/2 and USB header should work. I've had one on my M726MRT (ALI Aladdin Pro II, Slot 1 and 370).
Reply 28 of 42, by pete8475
It’s alive!!! […]
It’s alive!!!
That P2/IR/USB header looks like the right one.
Reply 29 of 42, by Sphere478
confirmed, the usb header works.
okay here are some relivant files provided by the seller on the hard drive they sent with it.
rar archive 6gb dictionary size, 5 mb parts
Reply 32 of 42, by Sphere478
pete8475 wrote on 2025-04-17, 06:41:
I remember those when they were new, it's definitely a PC Chips turd. I don’t know if it was common elsewhere but the main seller of PC Chips boards in my town insisted they were “Houston” brand not PC Chips. Perhaps to distance themselves from the bad reputation of PC Chips aka PC Shits.
I would think the M586LMR since you have the LAN pins.
In system info it indicates it is Matasonic (spelling?) not in front of it atm, but that’s what I recall. Not pc chips.
I was lucky enough to find this for sale
The attachment IMG_6443.jpeg is no longer available
I also found in my drawer of stuff a lan board with ribbon.
Any thoughts on the audio riser?
Or the memory/multi display extension? Need those now also.
Reply 33 of 42, by pete8475
Sphere478 wrote on 2025-05-08, 03:35:
In system info it indicates it is Matasonic (spelling?) not in front of it atm, but that’s what I recall. Not pc chips. […]
Matsonic, Hsin Tech, Houston, Amptron, Sybercom, etc. it's all PC Chips.
I think unless you can find the part you aren't going to have any sound, aside from that I have no helpful advice, sorry.
Reply 35 of 42, by Skalabala
Wish there was a better chipset for SS7, if they only pushed it to native 133FSB, I am going to try to do my P5A native 133FSB
Reply 36 of 42, by Sphere478
Skalabala wrote on 2025-05-15, 20:30:
Try some low ESR polymer caps. Maybe a VRM upgrade.
Did you see the score I got on the mvp4 build with a 7500…. It’s going pretty good! I need to find a way to adapt it to AGP through the PCI slot.
Reply 37 of 42, by Skalabala
Sphere478 wrote on 2025-05-16, 02:04:
I saw the score, thought it was low :p
Reply 38 of 42, by Sphere478
i haven't been able to get nvidia stuff to work right.
what do you suggest to make the score better?? it was a good score compared to what I have been able to get before! :p my prev record with a 9800 pro and k6-3+ was only a couple hundred points more.
Reply 39 of 42, by Skalabala
MVP4 should not be slower than MVP3? Maybe chipset driver, set to "slow" when installing?
