First post, by kagura1050
I was a bit curious after reading Sis 540 Aiming For The Stars!, so I looked into it and found some interesting information in the Aladdin V datasheet (as far as I could find, no one had mentioned this).
The image is the PCI Clock Control register (8Dh) in the Aladdin V datasheet. (There are no other registers to set the clock, so AGP seems to be fixed at twice the PCI clock.)
Look at the "PCI Frequency Mode" at the bottom. Doesn't it seem like it will run in 4X mode with "001"?
I don't know how the BIOS reads the PLL IC settings. But I think this shows that true 133MHz FSB may be possible with Aladdin V if set this register correctly and feed the correct clocks (133/66/33) to the board. (I have an ASUS P5A and a SI5351A module, so I might give it a try someday)
古いマシンで新しいOS(Linux/NetBSD)を動かすのが好き。
Timezone : UTC+9
Reply 1 of 1, by cyclone3d
Pretty sure I that might already be possible via undocumented jumper settings.
There have been a few reports of successful 133Mhz FSB on a P5A.
If that register needs to be set and is not already by the BIOS, a BIOS modification would probably be necessary.
I don't remember if there are any hidden settings on the P5A that can easily be unlocked by BIOS modding tools or not. Has been too long since I looked at that.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
