First post, by bloodbath2you
Hi folks,
About three weeks ago i brought two machines for cheap, a 386SX and a 486 machine. This machine came with a FIC 486 VAV REV A board with a 486DX-33, 128 KB cache and a Seagate 2 GB hdd.
I've been digging around on the net and found that this seems to be a low end but highly integrated board, it has onboard ide , fdd, and Video (Cirrus Logic GD5428 which is very decent and is sitting on the local bus).
The first thing i did was fixing the RTC issue by adding the coin battery mod, then updated AMI BIOS from 1.025 to 1.026A version and upgraded the ram from 4 to 16 MB. The bios was very limited and i thought by updating it would unlock some hidden features but still there are no ram timings nor BUS options for tweaking, so had to investigate a bit and found the AMISETUP software for enabling hidden features. Used to tweak it a little more but the results were small, still no settings for tweaking the timings or bus speed.
Later i overclocked the Intel 486DX-33 to 40 Mhz, the perfomance gain was ok but doom was still very choppy so i tested with different CPUs that i had at hand, a Cyrix 486DX2-50, Am486SX2-50 and a 3V Am486DX2-66NV8T which sadly i could not use because the motherboard does not support 3v CPUs. Anyways i plan to order a Socket Blaster PCB in the future.
The Cyrix one was out the game, slow and bad overclocker so i used the Am486SX2-50 oc'd to 66 with no issues.
And talking about memory perfomance, at 66 Mhz CACHECHK reports 17.1 MB/s which that from my little knowledge is hmm, meh i guess, i don't know. However this board has the VIA VL82C495 and VL82C481 Chipset which is known for having cache and memory perfomance issues.
The question is, does anyone had experience with this board, i'd like to expermient such as modding the bios, Socket Blaster for 3V CPUs, i already ordered some 32x8 UMC SRAM chips for 256KB. Also socketed the PLL for future clock mods, tested with can crystals and work they ok, ordered a 100 MHz for overlcocking the DX33 to 50 Mhz. I also been tinkering with XT-IDE with a NIC but had no luck at the moment, also tried a bit using bios from diffent boards that use the same chipset, some worked, but i still need to dig a bit deeper to get more conclusions.
I plan to make this my main 486 machine and replace the previus one which sadly i had to sell for paying a university debt for that time, damn i still miss that machine..
Any help and suggestions are very appreciated guys. If anyone has the award bios of the REV B version of this board a dump would be very appreciated. Also a VIA 82C495 datasheet would be really useful for modding the bios.
    189.12 KiB
    256.26 KiB
    334.93 KiB
    146.47 KiB
    171.65 KiB
Reply 2 of 20, by bloodbath2you
majestyk wrote on 2025-04-19, 17:22:
You can double video-ram for a total of 2MB by populating the two "zippy" sockets.
Mine is rev. A also and the BIOS I dumped is 1026...
i think these would just add some high res modes, but maybe perfomance will be improved a little by having more room for video pages.
Reply 3 of 20, by bloodbath2you
Hi, a little update.
I upgraded cache to 256 KB, ordered 10 UMC 32x8k two weeks ago. The perfomance increase was not much but noticeable, it feels snappier. CPU score was mostly the same, speedsys reported 24.4 pts and topbench an overall of 205 (no changes at all).
On FastDoom 1.13 benchmark i get 34.5 FPS avg.
LM60 - 316 MHz AT
3DBench - 45.4 FPS
Reply 4 of 20, by jakethompson1
Your Cachechk scores for internal and external cache are in line with a fully tuned 486DX2-66 system. However, the memory speed is bad.
Something you can do is temporarily disable external cache, and run Cachechk again. If the memory scores improve, it's an Always Dirty issue (should not be an issue on this board). If they don't, it's untuned RAM wait states.
There is a FIC 4386-VC-HD BIOS with many more options, but I don't know if it would be compatible with your board.
Reply 6 of 20, by bloodbath2you
jakethompson1 wrote on 2025-04-23, 03:47:
Gotta give a try after work, and about the bios swapping, the issue is that the video bios is on the same chip that is the system bios, maybe by just merging them together and keeping the offsets would work.
Reply 7 of 20, by jakethompson1
bloodbath2you wrote on 2025-04-23, 12:16:
You should be able to replace the last 64K of your ROM image with whatever BIOS you want.
The issue would be if there are multiple revisions of your VIA chipset, and perhaps yours is missing those settings (even as hidden options) for good reason, like if they aren't supported.
Reply 8 of 20, by bertrammatrix
you should use a DX cpu if at all possible, even a good old inexpensive intel dx2 would do. To me it wouldn't make much sense to max out the cache but to keep using a SX cpu.
also, if there is any way to set the board to run the fsb at 40mhz that would be the way to go
Reply 9 of 20, by bloodbath2you
bertrammatrix wrote on 2025-04-23, 17:37:
Yes, i even used a DX-33 overclocked to 40, i can also fit any crystal on the same PLL socket, i think the board can go up to 50 MHz. i ordered 100 and 120 MHz crystals to give a try.
Reply 10 of 20, by bloodbath2you
Ok, tried with a different bios from this board:
https://theretroweb.com/motherboards/s/fic-486-vc-hd#bios
it has both ami and award, tested the award one, version 1.10K, first with the GD5428 + Award bios it worked but got no video, maybe the original ami bios sets the onboard video on boot. So, i picked up a crappy 8 bit VGA card for video output and did some perfomance measures.
As you can see, the award one is even worse, feels older and more basic than the ami one, no auto HDD detection, no rom shadowing options, no fast a20 gate... it has a cache speed option btw, tried with two of three options, NORMAL and TURBO.
Turbo:
Cachechk reports 18.9 MB/s memory speed,
Speedsys reports 44.20 MB/s memory bandwidth
Normal:
CACHECHK reports 16.6 MB/ memory speeds
Speedsys reports 36.67 MB/s memory bandwidth
Topbench reported 60 something points comparable to a 386DX40 machine but is due to the bad video card so is understandable, after all i had no expectations on this bios. I think i'm reaching a ceiling but i'd try hacking the AMI bios in future and any suggestions will be very appreciated.
    118.39 KiB
    126.39 KiB
    94.7 KiB
    122.32 KiB
    133.25 KiB
Reply 11 of 20, by bloodbath2you
i went back to the AMI 1.026A bios but took advantage of time to update the GD542x bios version from 1.30 to 1.41, any advantages doing this? dunno but why not.
    123.84 KiB
    114.09 KiB
Reply 12 of 20, by majestyk
VIA chipsets from that time often have poor memory performance. Most (all) BIOSes increase waitstates as soon as CPU frequency and/or FSB go up and you cannot overrule it by adjusting BIOS settings. I had several cases where memory performance was better(!) with slower CPUs /FSB).
All you can do is max out L2 cache and make sure all installed mamory is being cached.
Reply 13 of 20, by bloodbath2you
majestyk wrote on 2025-04-26, 05:47:
Found it! Found a good bios. Taken from this board:
BIOS 1.021
Has all options i need
- Bus speed options
- Cache timings
- Memory timings
Made a new rom with the latest Cirrus Logic bios CL-GD542X Bios v1.41 + Version 1.021 and worked perfectly.
Set all memory and cache timings to the fastest , AUTOCONFIG disabled and did some measures. Also tried at 40 MHz fsb which, with the latest bios the board won't even post, crazy.
At 33 FSB, max memory and cache settings.
TOPBENCH - 219 score
SPEEDSYS - 53.94MB/s memory bandwidth, 24.67 MB/s troughput
LM60 - 316 MHz AT
DOOM -35.5 FPS
3DBENCH - 50 FPS
CACHECHK - 22.2 MB/s main memory speed
At 40 FSB, max memory and cache settings.
TOPBENCH - 257 score
SPEEDSYS - 65.7 MB/s memory bandwidth, 29.78 MB/s troughput
LM60 - 380 MHz AT
DOOM - *CRASH*
3DBENCH - 58.8FPS
CACHECHK - 26.6 MB/s main memory speed
It was stable until ran doom, duke3d runs and is playable for 20 mins until crashes. Maybe i'll mod the board and add more bypass caps around the CPU socket for reducing the current noise.
    106.93 KiB
    159.06 KiB
    151.62 KiB
    101.7 KiB
    259.79 KiB
Reply 14 of 20, by bloodbath2you
captures
    160.8 KiB
    141.91 KiB
    171.38 KiB
    145.74 KiB
    153.61 KiB
Reply 15 of 20, by bloodbath2you
Ok, the next i'll do is:
1. Try 50 MHz FSB with crystals.
2. Add more bypass capacitors.
3. Increase Video RAM to 2MB
4. Order a socket blaster PCB and put an Intel DX4-100.
5. Replace the onboard video chip with a GD5429 or 543X.
6. Set multiplier to 2X and use 50MHz FSB, if works, try 60 MHz.
Reply 17 of 20, by bloodbath2you
majestyk wrote on 2025-04-26, 15:53:
I assume the VC-HD BIOS won´t support the SMC super-I/O?
Seems not because the FDC and HDD are working fine, havent tried serial and parallel ports yet.
Reply 18 of 20, by bloodbath2you
Update: Added a bunch of bypass capacitors on the socket for a total of ~36uF, 18 x150nF and one 10 uF.
FDoom now is stable and got 42 FPS at 40 MHz FSB.
    292.09 KiB
    176.97 KiB
Reply 19 of 20, by bloodbath2you
Update:
- Built a 486 Socketblaster + Intel DX4WB
- Built a custom PLL
The custom PLL based on the ICS501 LOCO made able to play with weird clocks, using a 16.9344 MHz base clock.
- 42.5 FSB 2x Multiplier : Stable
- 42.5 FSB 3x Multiplier: POSTED but very unstable.
- 45 FSB 2x Multiplier: This one is the most i tinkered with, felt very stable giving 90 MHz
TOPBENCH : 300 Pts
3DBENCH - 66.6 FPS
- 45 FSB 3x : No past post, i think it needs more CPU voltage.
- 50 FSB: No video.
All tests were on 3.78 VCORE, for overclocking i think is the max this CPU could handle.
Anyways, the socketbaster is not complete yet, i need to solder the missing SMD capcitors on the bottom. This could be a big difference on stability.
I'll post more measures if you are interested, i did everything on a run this moring, even the custom PLL so many tests were not done.
