HELP, identify parts on my Asus P3B-F
First post, by rolierop
Hi all,
I just received a Asus P3B-F rev 1.03, but there are parts missing (don't have a clue why). It won't boot obviously.
I want to replace the missing parts hoping the board will come to life. So, who can help me identify the missing parts? I have them circled in red on a example photo (not my actual board).
I would love to know the parts and their values.
The attachment asus-p3b-f-61a3fcb4f3877499441442~3.jpg is no longer available
Regards,
Rogier
LuckyStar 486E C2 | AMD X5-133 5x86 | PicoGus+WaveblasterPi
Gigabyte GA-5AX | AMD K6-2+ 550 | Yamaha Audician 32 + DreamBlaster & PicoGus
Intel D815EEA2 |Intel PIII 1000 | Sound Blaster Live!
MSI P35 Platinum | Intel Xeon E5450 | Sound Blaster Audigy2
Reply 1 of 28, by Horun
The crystal is a 14.318Mhz, cap ce26 is same as ce28. The resistor appears purple-green-gold-gold or 7.5ohm 5% and looks like a 1/2watt. Not sure about the diode or FET, my board is in storage....
Reply 2 of 28, by Karbist
D1= 1N5817
Q14= PBYL1025B
the big resistor is 1watt.
Reply 3 of 28, by Horun
Karbist wrote on 2025-04-13, 01:34:
D1= 1N5817
Q14= PBYL1025B
Thanks ! saves me from a drive and digging into boxes 😀
Reply 4 of 28, by rolierop
Thanks for your help, I will order these and hope this will bring back life in this board.
When finished I willet you know if I was succesful.
Reply 5 of 28, by rolierop
Parts are ordered, but the PBYL1025B is only sold by Utsource, who I don't trust 😐
Ordered a few anyway, hoping they are legit because there are no other alternatives.
To be continued......
Reply 6 of 28, by rolierop
Update:
Board got a good clean.
Received all missing parts this week and placed them on the board.
Also did a repair on a broken trace at the underside off the board, under simm slot 2.
No shorts found anywhere on the board after thorough inspection.
Inserted post-analyzer card, first without CPU and memory for a smoke test. Succesful.
Then inserted a Celeron in a slotket and, yes postcodes appeared stopping at C1.
Added 1 memory bank and post code stopped at 00.
Also with a graphics card it stays at 00.
I rebooted couple off times and only once ended up with a booting system getting me in bios. It recognized the CPU and memory correctly!!!!
After that.....keeps hanging at post code 00.
Wiggled the slotket adapter, resoldered the joints, reseated several times.
So system showed me it is capable of booting, but something is holding it back. Dunno what, so love to get your thoughts on it!
Reply 7 of 28, by byte_76
Can you post some high resolution pics of your board as it is today so that the community can try to help look for any other missing components?
Have you checked for bent pins inside the CPU slot?
How did you clean the board? Did you wash it with soap and water?
Did you remove the BIOS rom chip before cleaning? (Make sure it's properly seated again)
Perhaps you can give the CPU slot another clean with Isopropyl alcohol and a brush that can reach into the slot (be careful not to damage the pins in the slot), just to be sure that the pins are properly clean because you could get this kind of behaviour if the CPU is not making a good connection.)
Also, give those memory slots another clean with the isopropyl as well.
Do you have an eprom programmer to reprogram the BIOS in case there is any corruption?
Did you connect a PC speaker and do you get any beeps when you have no memory and no display card installed?
Were you using an AGP or PCI display card?
Did you ensure that all jumpers / switches are properly configured?
Reply 8 of 28, by rolierop
byte_76 wrote on 2025-04-25, 20:24:
Can you post some high resolution pics of your board as it is today so that the community can try to help look for any other mis […]
I will post it
yes, I have checked
With soap and water
Yes, I removed it before cleaning
Will do that
I'm afraid not
Yes, beep codes where accordingly
Used a working AGP card
Yes, tried auto-config (all switches in off position) and configured for Celeron 500 MHz.
Reply 9 of 28, by rolierop
The attachment 20250425_175907741.JPG is no longer available
The board after placing missing components.
Was thinking, maybe to check capacitors for their values, maybe the repair on the broken trace.
The attachment 20250426_124724149~2.JPG is no longer available
Reply 10 of 28, by byte_76
Are those broken traces?
Reply 11 of 28, by rolierop
byte_76 wrote on 2025-04-26, 11:09:
They have continuety.
Reply 12 of 28, by Karbist
Disable the jumper free mode by setting the Jen jumper to 1-2 position and manually set the FSB to 66mhz and 2x multiplier, see if it makes any difference.
Reply 13 of 28, by rolierop
Disabled jumperfree option, cleaned CPU slot with isopropyl alcohol and a small brush.
Also checked capacitors. They are Rubicons and check out ok. Double checked damaged traces, but they all have conductivity, including the one I already repeared.
Tried a Coppermine CPU. No succes, but the voltage regulator on the motherboard switched nicely to it's 1.65 volts and with the Celeron to it's 2.0. volts
During couple of boots the post codes got a step further to error code 07, but could not get it again. Still hangs at post code 00.
The attachment 20250427_154315067.JPG is no longer available
Reply 14 of 28, by rolierop
Another thing crossed my mind.
Could I have used the wrong crystal, which I harvest from an socket 478 board?
The attachment 20250428_122425159.JPG is no longer available
Reply 15 of 28, by Karbist
That crystal has the correct value, you should have around 1 volt or 14.318Mhz on each leg when it's oscillating.
Reply 16 of 28, by rolierop
Crystal is working as it should.
It seems I get different results in post codes when I move the processor in it's slot. So I guess some pins have a bad connection. Going to heat the pins with the heatgun a good idea?
Reply 17 of 28, by PcBytes
I have a non-working P3B-F as well, mine hangs at C0 with two dashes after. I'll watch this thread in case someone finds a fix.
Reply 18 of 28, by Trashbytes
rolierop wrote on 2025-05-24, 11:17:
Deoxit spray on both slot and cart then just insert and remove a few times, clean the cart and test the board again.
Reply 19 of 28, by rolierop
I cleaned the slot again thoroughly, reseated the CPU a bunch of times.
The post-analyzer card gets pased C0 and C1, so memory is seen. If I remove the memory it hangs on code C1. But after C1 the next code is 00 and it stays at that.
So to me it seems the processor is working or else the post analyzer card could not do anything. Processor also gets warm.
Code 00 does not seem to mean anything??
After using the reset on the motherboard, instead of power cycling, it suddenly got to 0c (no keyboard) and 0d (no video adapter) and one time even past a bunch of other codes.
So, connected them, but still no video output. And then hangs at 00 again.
Sometimes ago i did get into the bios, but that was only once.
Maybe a recap?
