First post, by vvbee
Creative 3D Blaster Banshee CT6750 AGP. Recognized in OS, drivers install, but heavy artefacting from get-go. Running in a Pentium 4 system with a 100 MHz FSB, which has worked with some Voodoo3s and a Rush.
VGA boot screen:
PC boot screen (Energy Star logo etc.):
Similar fullscreen artefacting in Windows, the cursor leaves behind garbage etc., but partially correctly rendered.
Pressing on the card in various places while it's running has had no obvious effect. No evident trace damage, and no obvious loose joints on the half of the memory chips I've gone through. Visually all memory chips look ok. Measured a number of resistors and looked for cracks in them and capacitors, but nothing bad. No shorts as far as I can remember testing.
The card was also not able to flash its original SST BIOS chip, failed data verification. Same with a replacement chip of the same make and model, unknown condition. But works with an AMD and an Atmel BIOS chip. Flashing with the correct BIOS type as far as I know, and have tried a few versions of BIOS and flasher.
