Pulling my hair out with EGA programming.
Reply 20 of 21, by mkarcher
keenmaster486 wrote on Yesterday, 23:06:
Well, I'm not selecting any read planes.
Which means you likely always read plane 0. So the masking you do is most likely pointless, because the EGA masking works as intended, and the EGA card ignores the masked pixels.
			vmem[m + i] = (vmem[m + i] & ~this->data[t][maskDataPos + i])|this->data[t][dataPos + offs + i];
This obviously works by reading the 4 planes to the latch(es), then adding the bits you want for the selected plane, and writing just the selected plane back to EGA memory. I guess your issue was that you did not acutally read from EGA memory to fill the latches, because in your other attempt, the compiler noticed that you don't use the value you read from EGA memory, and optimized the read access away. You can likely prevent the compiler from "optimizing" your EGA memory access by declaring the vmem pointer as "pointer-to-volatile", like "volatile unsigned char far* vmem". Omit far if you are not in a 16-bit program.
Reply 21 of 21, by keenmaster486
mkarcher wrote on Yesterday, 23:14:
Sure enough, this is exactly what was happening. Thanks for the tip. Changing the vmem pointer to volatile fixed the bizarre behavior.
World's foremost 486 enjoyer.
