Reply 29580 of 29774, by Pino
debs3759 wrote on 2025-04-26, 15:22:
zuldan wrote on 2025-04-26, 03:21:
Pino wrote on 2025-04-26, 02:41:
Installed a Zalman cooler on my 9700PRO.
It's my all-time favorite VGA and they tend to die, so I will try to keep it cool.
Does the bottom of the cooler fins touch the top of the AGP slot?
That's just the angle of the shot, being taken from very close.
Correct, just bad angle on the picture, the fins does not interfere with the AGP slot, it was perfect clearance.
Reply 29581 of 29774, by StriderTR
Working on the DOS machine today. Got the PicoGUS installed, up and running. I like it! Next in line, a DreamBlaster.
As suggested over in the PicoGUS thread, I'm going to run both the PG and AWE64 together. That gives me all the sound compatibility I could ever ask for!
On a side note, my DOS rig is now covered in as many stickers as my 90's DOS rig was, thanks to Geekenspiel. 😜
Got some for my Win98 system too, just not on there yet.
Retro Blog & Builds: https://theclassicgeek.blogspot.com/
3D Things: https://www.thingiverse.com/classicgeek/collections
Wallpapers & Art: https://www.deviantart.com/theclassicgeek
Reply 29582 of 29774, by Thermalwrong
Thermalwrong wrote on 2025-04-14, 03:29:
It's been a while but I found a couple videos on Youtube that piqued my interest for this again. I follow a couple of folks in J […]
Thermalwrong wrote on 2023-07-23, 21:54:
Nice, I'll have to try something like that at some point (though I have no roland card or real GuS). What's the resource managem […]
Nice, I'll have to try something like that at some point (though I have no roland card or real GuS). What's the resource management like, is it using the original software or something like unisound?
I bought an untested NEC Versa V/50 laptop the other week which had essentially destroyed its hinge, not plural, it only has a right hinge, the left just holds it in place:
The attachment versa-v50-originalhinge.jpg is no longer available
It has no power supply which was stated in the auction, but it didn't state that no hard drive was included. This NEC needs a special caddy and the pinout is unknown, there are a couple of them on ebay but they cost 5x what I paid for this computer, no thanks.
The power supply part is relatively easy - I got an NEC Versa 4000C recently too and in the service manual for that it's got the dock pinout listed.
Ground was easy to find, just see which pin beeps against a port's metal shield. To find positive I ran a multimeter in beep mode across the dock pins. In the service manual the pins it beeped with match up where it's got "12v-sys" compared to "12v-charge" on the other possible pin.
Cut up some LCD inverter plugs since they're a good fit for this size of pin and decently conductive, jammed them in and now I have a PSU adapter:
The attachment versa-v50-repair1.JPG is no longer available
To repair the hinge / LCD panel corner, which had broken up into 5 pieces and destroyed every screw mount; thankfully enough plastic was still attached that it could be repaired by:
  1. Superglue the parts in the way they fit best
  2. Melt some metal pins / staples into the plastic with a soldering iron (with ventilation, heating superglue makes bad fumes). Did this on front & back
  3. Using a wedge tip on the soldering iron, melted some shapes into the flat areas on the inside, all around the broken bits. My thinking is that this gives much more texture for epoxy to grip onto.
  4. Taped off where epoxy shouldn't go, then poured on epoxy to the inside of the LCD panel corner and installed the LCD hinge bits
  5. Put some tape over the clip corner of the front facia and installed that so the epoxy would set around where that clip goes and the display still goes together nicely later
  6. For where the hinge attaches to the top case I first got some longer screws (this laptop uses m3) and put some extra threaded inserts onto the longer screw, then melted that all into where the hinge plate used to screw into
  7. Taped off and blutack/taped an area for epoxy go in the hinge area of the top case, then poured in epoxy around where the screws were
  8. Once that had partially hardened I took the screws out and flattened the area where the hinge plate screws to
  9. There was one standoff for the topcase that had sheared off where the top surface was accessible and not part of the palm-rest, so I melted in a threaded insert to that post. Then melted a hole through the top-case where that mounts and put in a countersunk screw
The attachment versa-v50-repair2.JPG is no longer available
Creepingnet's post on VCF made me aware that the hinge is so tight that it probably destroyed that plastic, so I loosened the hinge off slightly with some pliers and washed out the original grease stuff with some PTFE lubricant. It's a little floppy but the plastic now feels decently solid so it's operable and the screen works okay in this state.
I discovered that it could boot and the screen was good, but what to do with no fixed disk? It has an NEC floppy drive which is a really early and nice direct-drive floppy, no bad belts! And the system can boot off that, so I've set up DOS 6.22 with PCMCIA services on a floppy disk and I have a PCMCIA ATA flash card that is otherwise not used:
The attachment versa-v50-storage1.JPG is no longer available
This method actually works surprisingly well, DOS refuses to install on it through the installer - but Windows 3.1 will happily install onto whatever drive you point it to. It very likely would not be able to run Windows 95 though.
There's still one free PCMCIA slot so getting files on and off is easy, so I'm not sure I'll actually bother trying to get the hard drive caddy for it.
It can run Windows 3.11, and even ran DOOM but it has no soundcard (yet??) and with only 4mb of RAM, DooM must've been running from the Windows swap-file 😀
The attachment versa-v50-storage2.JPG is no longer available
One problem I do have is that the screen is sometimes flickering quite badly and that doesn't seem to be the backlight, but seems to change depending on what the computer's running, it's bad in DOS but looks fine in Windows. Weird, I wonder if it's capacitor related?
It's been a while but I found a couple videos on Youtube that piqued my interest for this again. I follow a couple of folks in Japan that share videos of their PC98 stuff so I don't feel much need to get a PC98 (a deep rabbit hole that I don't want to get into outside of emulation) and this popped up:
https://www.youtube.com/watch?v=Dk_7Jhpq2X4 and this shorter video: https://www.youtube.com/watch?v=8Orc59I0gPA
They're both NL6448AC30-10 which is the 9.5" TFT panel that's in my NEC Versa V/50 laptop, which had this weird thing it does where it flickers when displaying black and makes a straining noise while doing so. Displaying whiter stuff like Windows 3.11 stopped the noise / flickering.
Watching the video, I had originally thought that the NL6448AC30-10 LCD panel had no capacitors and it was all solid state - not so, there are caps hiding inside the display PCBs on the back sandwiched in place and held completely in place by the soldered down cables that connect up the column driver chips:
The attachment IMG_5695 (Custom).JPG is no longer available
The attachment IMG_5697 (Custom).JPG is no longer available
The attachment IMG_5698 (Custom).JPG is no longer available
Those caps are all so crusty, thankfully I have some 33uF 25v SMD capacitors in stock since they're so common in LCD panels. I used the grip & twist method to remove these and they all came off with damage to pads, another year or two and the traces might've been damaged enough to let go with this force applied:
The attachment IMG_5702 (Custom).JPG is no longer available
To clear these up, I just put on some fresh solder then use my solder sucker with a rubber tip (abeco flexivac 2008) to get the traces flat. Solder in fresh caps:
The attachment IMG_5705 (Custom).JPG is no longer available
Then solder the connector back down being careful to avoid any shorts, thankfully the wire spacing gives a lot of room and there's lots of space to work. Nasty flux they left on the board too, but no corrosion which is good for ~31 years of age.
And we're done, the pictures look just like the last pic I took of the Versa V/50 with Windows 3.11 looking great on there. The floppy drive uses a voice coil instead of a stepper motor and the spinner is direct drive so it's so different for reading floppy disks compared to any other laptop I own. Now the screen no longer flickers when displaying black and no more weird noises 😀
Did some more plastic repair as well, since the disassembly inevitably broke a few more clips and parts of the casing. Not that the plastic is excessively brittle but I was able to do better this time re-melting the plastic around threaded inserts and stuff. My new favourite tool for plastic repair is just regular staples, they melt into plastic nicely and are stiffer than capacitor/resistor legs.
It's funny as well, the english speaking internet has no search results *at all* for the repair of this NL6448AC30-10 LCD panel but the Japanese internet, searching for "nl6448ac30-10 コンデンサ" which is 'kondensa', the japanese term for capacitors, has a ton of results. If only advancements in tech/AI could break the language barrier for search.
Following on with this, my NEC Versa V/50 has been operable but not very useful because I don't have the hard drive caddy or any memory expansion. I also have not had the proper charger for this - that changed the other day when I won an auction for an NEC UltraLite Versa which doesn't power on. It doesn't power on (has the same corroded 1.8432mhz crystal that creepingnet mentioned on his one too) but it had the hard drive caddy, 8MB memory card and the OP-520-4001 charger:
The attachment IMG_5826 (Custom).JPG is no longer available
The hard drive works great and the 8MB memory expansion is also really helping. But the charger wasn't working when plugged in, 0 volts output.
Opening it up the board is all sticky with what I thought might be cap juice but after spending ages cleaning it off, both manually and with the ultrasonic cleaner. I'm now less sure because all the caps except C8 (35v 56uF) & C9 (35v 22uF) tested good:
The attachment op-520-4001-repair-1 (Custom).JPG is no longer available
The attachment op-520-4001-repair-2 (Custom).JPG is no longer available
Those two caps are too small to have leaked that much capacitor, so I think it was just weird flux now, maybe.
Put all the caps back on and replaced C8 & C9 and now the charger outputs 13.5 volts on its running voltage pins. Those little caps, particularly the 35v 22uF are typical for running the switch mode psu controller. I'm very happy it was just that because my ability to troubleshoot a switch mode PSU doesn't go much further.
The attachment IMG_5830 (Custom).JPG is no longer available
Testing it with my NEC Versa V/50, it's a rather *big* charger, like xbox 360 power brick kind of size. That's just how things were in 1992 / 1993, the battery charging stuff was in the charger rather than the laptop and my Toshiba T4400 power supply is similarly rather big. It has worked for a couple of hours though and I was able to charge the battery to discover that the batteries are dead after all.
The NEC UltraLite Versa (486SL 33mhz, PC-432-1531) is still not working and I don't have much faith that I'd be able to get it running, quite a few corroded vias. It's really a lot like the Toshiba T4600C inside, bleeding edge for its time with a load of small SMD electrolytic capacitors & regular electrolytic caps that are leaking, losing capacitance or otherwise failing.
The attachment Versa-V50-Working2.JPG is no longer available
Now if only it could have a soundcard somehow, I'd like this NEC Versa even more if it did. The screen is really nice since the capacitors were replaced and I'm liking the NEC-made TFT's colour profile compared to the Toshiba LCDs from the same era. The NEC support software seems to be a little nicer than Toshiba's for this era too, thankfully people archived the Versa V setup disks: https://archive.org/details/nec-versa-486-disk-images
Reinstalling the OS and software from floppy was fun - I used just two disks and my USB 2.0 LS120 + WinImage to write the images, so that while one floppy was being read on the laptop, the other floppy was being re-written on my main computer. No trouble at all from this NEC floppy drive 😀
Reply 29583 of 29774, by eisapc
Sucessfully repaired my latest aquisition.
An Asus 486SV1 EISA/VL based machine with Adaptec 1742 SCSi und 2MB Diamond VL graphics.
Bigtower with two floppy drives, SCSI CD-ROM, Tapestreamer and a huge heavy SCSI HDD.
One Tantalum on the -12V rail was shorted, preventing the PS to start and one of the rare 4MB 30pin Simms seems faulty and caused a reboot loop during post,
or a strange screen showing just the number 5000 white on blue in the middle of the screen.
Just have to dig for the boards cfg files in my archive to get rid of the EISA config error and have a look at the content of the 600MB SCSI brick installed.
Funfact, Asus still has the BIOS for the board on the web, but not the cfg-file needed for the EISA config.
Replacement batterie or a Dallas chip mod may be needed too.
Reply 29584 of 29774, by Veeb0rg
Spend Sunday morning at a local Retro Tech swap meet. Got rid of some things and only managed to pick up one system a few odds and ends. Was a pretty decent turnout, much bigger then the last one. Hopefully the event continues to grow!
Reply 29585 of 29774, by zuldan
Decided to do some overclocking on my P45 ASUS Maximus II Formula running a Q9650 with a 750W PSU and 2x 5870’s in Crossfire. Upped the CPU voltage to 1.32v with CPU running at 3.6GHz. The machine then randomly shutdown. I swapped the 750W PSU with a 850W PSU and she’s rock solid stable now. I think I could reach 4GHz but that’s probably going to involve playing with memory voltages etc. I’ve ordered a E8600 which apparently will OC to 4GHz with just a CPU voltage increase. It’s probably more suited to the games I will run which only use single or 2 cores.
Reply 29586 of 29774, by PD2JK
Inspecting an AT case I got recently. Never saw a jumper-free LCD with battery backup for storing the clock speed. It still had some juice in it, but 100 was a bit standard. 😉
The attachment DSC_3917.JPG is no longer available
The attachment DSC_3922.JPG is no longer available
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 29587 of 29774, by Yoghoo
PD2JK wrote on 2025-04-28, 17:22:
Make sure you replace the battery even if it's still working. Got a case some time ago which also had a jumper-free LCD. It contained 2 batteries. Both of them leaked and destroyed the pcb. Had to replace it with a selfmade Arduino solution.
Reply 29588 of 29774, by PD2JK
Thanks for the advice, I removed the battery and the contacts were a bit white/green. So vinegar and alcohol it is...
Reply 29589 of 29774, by Imperious
Successfully modded my NOS Aliexpress Chinese Socket 370 board (mostly a copy of Gigabyte GA-6VTXE) for some extra FSB options
then along with the vcore mod I installed, played some Aliens VS Predator 2 with my old Gigabyte TNT2 Pro and a Celeron 300A @ 472.5mhz 105*4.5
Had to turn down settings a bit, but just enjoying an overclocked alternative system that I never had in the day. I had an AMD Duron at the time.
I have some p3's and Cyrix and Tualatins to try when I've finished playing with the Celeron.
Reply 29590 of 29774, by nach
I replaced the screen polarizer of a Sony Vaio PCG-C1R that was starting to have vinegar syndrome and in addition the image was all very yellowish, i guess also for the same reason.
I know that is not that a big deal maybe but It was my first polarizer replacement and i am very happy with.
I have another PCG-C1 that is starting to look very suspicious so i will replace it very soon.
Roland MT-32, Roland SCP-55, Roland SC-88, Roland MT-90U, Roland PMA-5, Casio GZ-70SP, Casio GZ-50M, Yamaha MU90B, Yamaha MDP-5, Panasonic CF-VEW212, TDK Digital Music Card 9000, Kawai Gmega
Reply 29591 of 29774, by Thermalwrong
nach wrote on 2025-05-01, 06:45:
Wow, how did it go? I've had to do that on my Vaio PCG-C1XN's original panel, but I had a spare undamaged panel on my PCG-C1VFK that's got a sort-of damaged motherboard.
I stripped the bad polariser off of the bad one and so far all I've done is stick a non adhesive polariser in front, which was sort of working without sticking to the glass but over time it has started to contact the glass giving that 'air bubbles' kind of look.
I've replaced the polariser with proper adhesive ones on a different LCD, the one on my Toshiba Portege 610CT - the Toshiba LTM09C031A and even though it went well there were still a couple of air bubbles. And because I was replacing both the front and rear polariser I got careless with the LCD ribbon connections / cof cables and now there are vertical stripes on the screen, so it's ruined. I have more polarisers to replace but if I can't get it perfect then I don't want to do it since it's ~£5 per application attempt for a polariser film.
Ya know - I did notice that putting a layer of cellophane between the LCD glass and the polariser - stops the non-adhesive polarising film 'sticking' to the glass and the cellophane doesn't either. I was doing that to fix the colours of a DSTN panel but I should try it with a TFT to see what it does, maybe it could make non-adhesive polarisers easier to make look good without that partial adhesion occuring.
I do wonder why it seems like the Vaio Picturebook series' polarisers are especially affected by vinegar syndrome, even ones that have spent most of their time in the UK can go bad.
eisapc wrote on 2025-04-28, 07:59:
Sucessfully repaired my latest aquisition. An Asus 486SV1 EISA/VL based machine with Adaptec 1742 SCSi und 2MB Diamond VL graphi […]
Nice 😀 That's a pretty rare system - regarding the 4MB SIMM being bad, I was going through all my bad SIMMs last year and found that the SIMMs that were bad were almost all fixed by just finding loose connections and resoldering the legs where necessary. Perhaps touching up all the solder joints would recover that SIMM for you, could be easy if it's a 2/3 chip SIMM rather than a 9 chip SIMM.
Reply 29592 of 29774, by CharlieFoxtrot
Yesterday evening and today morning I decided to make some changes to my Prolinea 4/50@66MHz system. Previously I had it already completely in usable condition and had installed 3com NIC, MPU401 card, 5.25" drive and AWE32 Value CT3910, all the software and some ram to 24MB. Besides these addons and CPU OC, the system is in original state with 170MB HDD. As I had gotten some new gear recently that fit this 1994 machine perfectly, I decided to make some changes.
AWE32 and 5.25" floppy drive gets replaced by Pro Audio Spectrum 16 Studio (650-0097) multimedia kit which includes the Media Vision branded Sanyo SCSI CD-ROM drive. I also yesterday received sander's reproduction cache module for these computers.
Here it is in its old glory and new stuff going in:
The attachment old and new stuff.jpg is no longer available
Cache works great! There are also dip switches for 512kB and 1MB on sander's board, but at least 1MB requires BIOS changes:
The attachment cache.jpg is no longer available
Externals after the change:
The attachment new.jpg is no longer available
This was fun tinkering for few reasons. First, this is the first time I have been using PAS16 and I must say that they are amazing cards. The sound is of incredibly good quality and clean and comparable to new cards such as Orpheus 2 or PicoGUS. I have used many kinds of ISA cards during the years it has really dawned on my how crappy Creative products are in pretty much every way other than the compatibility. Second, this was also the first time I have installed SCSI stuff. I have few SCSI parts in my bin and will test those at some point, but this multimedia kit took my virginity in this sense. It took few decades!
CDROM drive also works fine. It is of course slow 2x drive, but completely fine on a system like this and certainly period correct. It is little bit different from the more modern ones. It has fully motorized tray unlike another early Creative branded Sony drive I have on my Compaq Deskpro 466 EX, but the tray has this locking spindle like you usually find on laptop CD drives. Sony drive has its own peculiarities and that is the reason I like to use these in these old DOS machines. To my surprise and just like the Sony drive, this one also seems to read CD-Rs just fine which isn't necessarily the case with these early drives.
And sander's cache module is just so cool. Of course with such VLB system at 66MHz the performance increase isn't drastic, most benchmarks showed pretty much 10% improvement and in Doom around 15%, but as the originals are impossible to find, it was neat to finally get one of these otherwise unobtainium L2 cache sticks to at least on of my LPX desktops. And maybe I drop my Kingston Turbochip in this at some point and then L2 cache most likely will benefit that CPU better!
Reply 29593 of 29774, by dominusprog
Washed the whole thing and replaced both the thermal paste and thermal pads.
The attachment 20250501_135806.jpg is no longer available
Creative AWE64 Value ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 29594 of 29774, by PD2JK
@CharlieFoxtrot: Great compact Compaq. Never seen this drive before. I own a PAS16 with on-board LMSI interface. Great cards indeed.
@dominusprog: Red never looked so red before. Nice.
Reply 29595 of 29774, by dominusprog
PD2JK wrote on 2025-05-02, 17:14:
Haha! I just did an auto level in GIMP.
Reply 29596 of 29774, by CharlieFoxtrot
Yeah, I have sort of soft spot for Compaqs from this era. I also have Deskpro 466 XE and Presario 425 AIO in my collection. That CDROM drive is Sanyo CDR-H93RMV, they just slapped Media Vision sticker on it, but there are no special MV markings on the front bezel or tray unlike some Creative drives which were much more effectively branded. There are couple of those Sanyo branded ones for sale in Ebay currently, so it probably isn't super rare, though not very common either.
LMSI drives are rarer than hen's teeth, although there seems to be couple for sale in ebay with ridicilous prices.
Reply 29597 of 29774, by kinetix
I have started restoring a 386 motherboard, it is slightly damaged by the battery (easy compared to the one I restored before). It is the one that interests me most from 6 different that I got. From 4 of them I already sent better images to theretroweb, and from 2 the bios. With one of them a new entry on the web was created.
Reply 29598 of 29774, by Major Jackyl
Today, I had all the parts laying around for it, so I modded a Dallas RTC for the first time. Was fun and easy.
The attachment 20250504_120334.jpg is no longer available
I set the chip on a heatsink with suitable spacing to hold it while I heated and chiseled away at it. HEAT GUN. Should've borrowed one. Would've made the process even easier.
The attachment 20250504_123002.jpg is no longer available
The resin removal was the hard part. The rest is easy (easier if you don't puncture the crystal, 🤣)
The attachment 20250504_131508.jpg is no longer available
The attachment 20250504_131518.jpg is no longer available
I don't have an AT PSU easily accessed ATM, so I'll have to test it later.
The attachment 20250504_132211.jpg is no longer available
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 29599 of 29774, by momaka
Big thumbs up from me here. 😀
Only thing I have to ask, though: did you de-shim the GPU? If not, probably a good idea to do that. The shim tends to raise the heatsink surface a hair above the GPU die, which is significant when it comes expecting regular thermal compound to compensate for that (and thus will raise the running GPU temperatures significantly.)
Removing those shims is the first thing I do.
Another remark I have: isn't the fan a little too loud hooked directly the way it is right now? FWIW, I have the all-aluminum VF-700 and I find the fans on those to be extremely loud at 12V (full blast) - about on par with most socket 370 and socket A coolers. Adding a resistor to reduce the voltage can cure that... though then the cooling will be slightly reduced too. The other thing I noticed about these VF-700 coolers: they aren't all that great past 40W TDP... so the 9700 Pro is probably borderline OK with it (R300 cores are about 50W TDP.) I have one on a Gigabyte GeForce 7900 GT (came stock with the card), and besides being loud, it isn't able to keep the GPU under 60C, which is a must for the GF7000 series if one wants them to last.
So I guess what I want to say here is: the VF-700 is a very nice step-up from the stock Radeon 9700 cooler, but probably still not quite what I'd consider adequate to keep these cards "proper" cool (so that they can last longer.) Some of the Arctic coolers should be slightly better. But if this is all you have, definitely keep that VF-700-CU on there instead of the stock Radeon 9700 cooler - those things are shamefully small for the TDP of the GPU. It's a miracle any Radeon 9700 card are alive today as it is.
