First post, by Jackhead
- Oldbie
Goal here is to putting a Server Mainboard into an modern EATX Case.
Running fastest Slot2 CPUs with FSB133 4Gb RAM and a Voodoo on Win2k.
Still experiment with hardware. Dremel and 3d printer is available.
Check last Posts for progess. This build will take some time..
Hardware so far:
MB: Compaq G530 G1 Server FSB133 Slot2 ServerWorks Chipset
CPU: 2x Intel Pentium 3 XEON 1GHz FSB133 5/12V (MMX and SSE)
RAM: 4GB Samsung ECC FSB133
GPU: Strange God Voodoo 5 6000 PCI
SPU: SB Audigy 2 ZS
Case: Fractal North XL
OS: Windows 2000
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - MPU-401AT with YucatanFX / Roland CM64
Win98SE: Asus XG DLS 1x SL4XY - SG Voodoo 5 6000 PCI - 1GB RAM ECC- Audigy 2 ZS - MX300
