Anomalies in the Intel® Processor Specification Updates
Reply 20 of 220, by red-ray
PARKE wrote on 2025-05-04, 13:30:
Do you have all the CPUID's in the same look-up database ?
It's actually a constant C structure and all the CPUID/S-Spec SIV knowns about are in the same structure, but it does not have "all the CPUID's" there are only 689 entries starting with 0400 486DX and currently ending with 068A SL5QK, the same CPUID is usually there multiple times, once for each S-Spec. It started with i486 ones to populate the dropdown and I have added more over time.
file.php?id=218567
Reply 21 of 220, by PARKE
Yes, sorry, I meant S-Spec but wrote CPUID.
'Costant C structure' is above my head.
I have started working on my P2/P3 database to reduce the number of (possible) discrepancies. Btw, I think there is some suspect stuff on CPUW too.
Reply 22 of 220, by red-ray
PARKE wrote on 2025-05-05, 11:11:
It's quite simple, I defined a structure with all the components and then populated it. F400 means the CPUID is unknown.
What form does your database take, I suspect I could get SIV to cross check it with it's.
CONST C Structure
typedef struct _CPU_SSPEC                       // CPU S-Spec Block
BYTE otf; // On The Fly
BYTE sle; // SL Enhanced
WORD cid; // CPUID
WORD rev; // Revision
CONST TCHAR *nam; // CPU Name
CONST TCHAR *ssp; // CPU S-Spec
CONST TCHAR *stg; // CPU Stepping
CONST TCHAR *dat; // CPU Date
CONST TCHAR *not; // CPU Notes
} CPU_SSPEC; //
#define INI_SSPEC( otf, sle, cid, rev, nam, ssp, dat, stg, not ) { otf, 0x ## sle, 0x ## cid, 0x ## rev, TEXT( #nam ), TEXT( #ssp ), TEXT( #dat ), TEXT( #stg ), TEXT( not ) }
CONST CPU_SSPEC ssb[] = //
{ // CPUID Rev Processor S-Spec Stepping Date Notes
INI_SSPEC( 0, 00, 0400, 0000, 486DX, ?, A0+A1, ?, "" ),
INI_SSPEC( 0, 00, 0401, FFB0, 486DX-25, SX308, B2-B6, 89, "" ),
INI_SSPEC( 0, 00, F400, 0000, 486DX-25, SX249, ?, 89, "" ),
INI_SSPEC( 0, 00, F400, 0000, 486DX-25, SX250, ?, 89, "" ),
INI_SSPEC( 0, 00, F400, 0000, 486DX-25, SX493, ?, 89, "Low Power" ),
INI_SSPEC( 0, 00, F400, 0000, 486DX-33, NA, ?, 89, "IBM PN 63G9145" ),
Reply 23 of 220, by PARKE
I use an old Paradox database program but I can export into the common formats for you - spreadsheet or comma delimited txt etc.
Are you in contact with people from CPUW ? I wonder where they got the S-Specs from that do not occur in the spec updates that we have.
Reply 24 of 220, by red-ray
PARKE wrote on 2025-05-06, 10:58:
comma delimited txt
Thank you, for me a .CSV file would be simplest, once I get it I suspect it won't take long for me to get SIV to import it into I suspect a CPU_SSPEC table and cross check things.
I have never managed to get in contact with them, it's also possible if they have it's NDA. Some time ago I sent them an e-mail asking if it was OK for SIV to open such as https://www.cpu-world.com/sspec/SX/SX308.html and as yet have not got a reply.
Reply 25 of 220, by PARKE
red-ray wrote on 2025-05-06, 11:35:
comma delimited txt
Will let you know when I am done checking - may take a day or so.
I ran into a site where someone stored what seems to be the entire S-Spec collection of CPUW (or at some point entire):
https://github.com/zymos/cpu-db/blob/master/s … pec_numbers.csv
I downloaded this csv version and it imported seamlessly (the columns are only delimited with a comma).
Reply 26 of 220, by red-ray
PARKE wrote on 2025-05-06, 13:22:
OK, may I have say say the first 20 lines so I can write the code so I am ready please?
I have a quick look at this and it does not seem to have the CPUID which makes to next to useless for SIV, does your database have the CPUID?
Reply 27 of 220, by PARKE
Yes, my database contains some 450 PII/PII/Celeron entries but 24 CPUID's are missing. Here a comma delimited txt file with the Deschutes. First line contains the titles.
SL2SP is, btw, interesting. Cannot find anything on it but for one mention by a Vogons member:
Re: Which Pentium IIs can be underclocked?
The attachment ANSWER.txt is no longer available
Reply 28 of 220, by red-ray
PARKE wrote on 2025-05-06, 14:40:
Thank you, as I suspected it was simple enough to get SIV to read it, but when I opened it in Excel the columns were wonky, I wonder do some of the entries contain commas? If so can it be exported as a .TSV (Tab Separated Values) file? It's usual to generate such as one,two,"three , 3", four when there are commas, but a .TSV is easier to parse.
SIV did not find any conflicts, but I had not added a couple of the 66 MHz FSB P-IIs so I did. Below is what I got after adding a couple of 🐛 to the .CSV file.
Reply 29 of 220, by PARKE
Sorry for the comma issue I'm a bit rusty. The column with notes contains comma's and I should have used another delimiter. The original file was started with tables that came one on one from the Intel spec sheets and the notes refers to the originl notes at the end of the tables.
It is probably simpler for you if I sent you a file with just the columns that you need and in the order from left to right that works the best for you. et me know.
I do not see the problem in the output that you posted above here ?
Reply 30 of 220, by red-ray
PARKE wrote on 2025-05-06, 18:45:
file.php?id=218709
I edited the [dB0] + [dA1] in the .CSV file to [dBo 🐛] + [dA1 🐛] so I could check that SIV reported an issue.
Can't I just have a TAB rather than COMMA separated values file, see https://en.wikipedia.org/wiki/Tab-separated_values, I can't imagine you have tabs in the data.
Reply 31 of 220, by PC Hoarder Patrol
Finally got round to the promised check!...
The attachment SL49G.jpg is no longer available
The attachment SIV_SL49G.png is no longer available
Reply 32 of 220, by red-ray
PC Hoarder Patrol wrote on 2025-05-07, 04:42:
Thank you it's [cB0] as I suspected it would be and not [cD0], the images also confirm the year as 2000.
I wonder why SIV didn't report much for GPU-1 + GPU-2, what are they please? What does Menu->Machine->GPU Info report? At a guess Voodoo 1 or 2.
Reply 33 of 220, by PARKE
red-ray wrote on 2025-05-06, 20:37:
Oh, I see... you introduced some marker thingy for issues.
Tabs are fine, try this - see attached
The attachment SSpec.txt is no longer available
In the second column [issue] stands for problem or for untraceable (besides CPUW/Wiki) and checked means that I found proof of existance.
Reply 34 of 220, by red-ray
PARKE wrote on 2025-05-07, 07:54:
Thank you, I feel TABs work well and the file is way easier to read.
I am still working on my parsing, but noted SL27Z is not in the SIV table or Intel .PDF file, but SL2Z7 is, I feel this is a typo, do you?
Reply 35 of 220, by PARKE
Yes, they are both listed at CPUW but only SL2Z7 seems legit to me. This sort of thing gets a life of its own when hardware sellers and database copyers start to repost them. SL27Z is f.e. still for sale 😀
Reply 36 of 220, by PARKE
But for your purpose it is not a big deal when you have couple of n0n-existing S-Specs in there - nobody will ever run into them, right ? Double entries are your main pain in the butt.
Reply 37 of 220, by red-ray
PARKE wrote on 2025-05-07, 11:13:
Not really, they just seem wrong to me so I comment them out.
There are a couple with stepping cB0c in the S-Spec update, I feel it's an Intel typo, do you. In your file one is cB0c and the other cB0.
SIV does not as yet have Celerons so it's skipping them. I have got as far as below and will think about these later. With such as SL5BR there is not CPUID so what does checked mean?
Checkout of S-Spec
[Check CPU S-Spec] <- SIV32L - System Information Viewer V5.81 Beta-07 RED::ray
SIV32L - Checkout of S-Spec on \\RED - Windows 10 x64 Enterprise V10.00 Build 19045 22H2
CPUID Processor S-Spec Expected Actual CPUID Reason Description
? Coppermine-600 [cD0] SL5BR Unknown - checked
? Coppermine-650 [cD0] SL5BU Unknown - checked
? Coppermine-666 [cD0] SL5B6 Unknown - issue
? Coppermine-800 [] SL65C Unknown - issue
068A Coppermine-850 [cD0] SL49G(2) Unknown - issue
068A Coppermine-866 [cD0] SL49H(2) Unknown - issue
? Coppermine-866 [] SL5HK Unknown - issue
0683 Coppermine-933 [cB0] SL49J Unknown - checked
? Coppermine-933 [cD0] SL5B4 Unknown - checked
? Coppermine-933 [] SL5HL Unknown - issue
? Coppermine-500 [cA0] SL3US Unknown - issue
0683 Coppermine-533 [cB0c] SL44W cB0 cB0c 0683 Coppermine-533 [cB0] Pentium IIIEB 256K
0681 Coppermine-650 [cA2] SL3NC Unknown - checked
? Coppermine-666 [cC0] SL4G6 Unknown -
0681 Coppermine-700 [cA2] SL3SB(2) Unknown - issue
0681 Coppermine-800 [cA2] SL4G7(2) Unknown - issue
0683 Coppermine-866 [cB0] SL47S Unknown - checked
? Coppermine-1000 [cD0] SL5L7 Unknown - issue
? Coppermine-866 [cD0] SL5HG Unknown - issue
? Coppermine-933 [cD0] SL5HH Unknown - issue
0633 Klamath-233 [C0] SL2TK Unknown - checked
0633 Klamath-266 [C0] SL2PV Unknown - issue
0634 Klamath-266 [C1] SL2QD Unknown - issue
06B4 Tualatin-1133 [tB1] SL6JK Unknown -
06B4 Tualatin-1200 [tB1] SL6JL Unknown -
? Tualatin-1333 [] SL6HS Unknown - issue
06B4 Tualatin-1400 [tB1] SL6C2 Unknown - checked
? Tualatin-1400 [] SL6HR Unknown - issue
06B4 Tualatin-1133 [tB1] SL6JM Unknown -
06B4 Tualatin-1266 [tB1] SL6JN Unknown -
06B1 Tualatin-1400 [tA1] SL5XL Unknown - checked
06B4 Tualatin-1400 [tB1] SL6JP Unknown -
? Tualatin-1000 [tA1] SL5PS Unknown - issue
Checked 315 entries from D:\SIV\SSpec.tsv in 0.000 seconds, found 1 issue and 32 missing
[ OK ] [ Copy] [i486 S-Spec][Pentium Spec][Skt 8 S-Spec][Slot S-Spec][CuMine Spec][Chk S-Spec][CPU S-Spec]
Reply 38 of 220, by PARKE
I don't know if the extra c's mean anything; maybe if you ever run into such cpu it would show ?
The [checked] means that I found photo's or dead Intel links via Google that prove that they exist(ed) outside of CPUW or Wiki. In the past I also picked up a couple from the Intel ARK website
[[https://ark.intel.com/content/www/us/en/ark/p … 00-mhz-fsb.html]]
which does not exist in that format anymore plus that Intel has stopped providing info on pre-Pentium 4 cpu's.
The ARK website info did not come with CPUID's.
You can take a look at the 'checked' ones in this Word file.
The attachment CheckSSpec.doc is no longer available
Reply 39 of 220, by red-ray
PARKE wrote on 2025-05-07, 13:38:
They are Intel typos, if you lave them there it should say typo where is says checked.
I am down to as below and I also added the check to see if you have any missing, found four which are all in the S-Spec update along with 100 Xeons which I did not list, do you plan to add Xeons, Pentium Pro, Pentium or i486?
0650 Covington-300 [A0] SL27Z Unknown - issue
06B1 Tualatin-800 [tA1] SL66D Pentium III 256K - Unknown
06B4 Tualatin-800 [tB1] SL6HC Pentium III-S 512K - Unknown
06B4 Tualatin-933 [tB1] SL69K Pentium III-S 512K - Unknown
06B4 Tualatin-1000 [tB1] SL6QU Pentium III-S 512K - Unknown
Checked 326 entries from D:\SIV\SSpec.tsv in 0.005 seconds, found 0 issues, 25 + 104 missing (100 Xeons) and 120 skipped
