Okay, both motherboards have arrived.
Time to play with them is short. I hooked this one up because the seller didn’t pack it well. The board got banged around and the heatsink was ripped off. It pulled a leg slightly out of one capacitor, I pushed it back in, checked for short, found none, and fired it up, (it will get replaced soon) the fan connector was also bent over, I bent it back and pushed it back down.
Lower temp sensor was folded and twisted, straightened it back.
So far it seems to be working. I was able to boot to speedsys.
I was able to set cpu to 250mhz in preparation for 133mhz fsb tests.
I see settings for 50-100mhz
So if I’m going to go higher I have to map out the jumpers at the end of the top pci slot for hidden settings (fingers crossed)
Anyone have a clock gen datasheet?
Curious it has a k6-2 450 in it. Speedsys says 64k L1 but cache test seems to suggest 32kb? Thoughts?
Anyway, no time for a cpu-z or anything else right now. Gotta run. Will revisit.
