Reply 220 of 233, by Errius
- l33t
OK, interesting, your system is a NC440BX then, which is the N440BX in a Columbus II case
There's also a NA440BX, which uses the Astor case
I believe the difference between the Columbus and Columbus II and Astor and Astor II cases is just that they take different motherboards. They're otherwise the same.
Mine is missing the drive cage, which is unobtanium now. I had to mount the hard drive in one of the 5.25" bays instead.
The white plastic fan casing at the bottom also broke off in transit (I guess plastic gets brittle with age) so I had to secure it with twist-ties.
ETA: add links
https://web.archive.org/web/20000815081703/ht … is/Columbus_II/
https://web.archive.org/web/20130908074845/ht … ~1/columb~1.htm
Another poster has uploaded the product specification here: Re: NEC Proserva V Plus (dual socket 7 system) (have a lead on multiple of these)
It's also included in this official archive about the Columbus II and Astor II: https://downloads.bl4ckb0x.de/downloadcenter. … .com/18389/eng/
Is this too much voodoo?
