Reply 440 of 449, by Kahenraz
- l33t
Jccwu wrote on 2025-05-11, 16:52:not about Roland, but Yamaha.
Tell me, has anyone changed the battery in the Yamaha MU80?
It looks like there is a non-standard battery that is soldered to the pad. Should I be afraid of its leakage? When turning on the device it says Low Battery.
The battery has to be desoldered to be removed. It's not necessary to replace it with another one for use with games. The low battery message will continue to appear each time at power-on, however.
You could try using a pair of snips to cut the metal legs. Just be careful not to apply too much stress to the legs, or else you might tear off one of the solder pads on the PCB.
