First post, by MSxyz
Following the experiences narrated in this thread: Looking for an OLD raytracing benchmark for pure DOS and following a hiatus of a few months, I started using this benchmark on all my retro machines + processor combinations. It's a long process, but I intend to build a database with all the results, as I do for the other benchmarks I run on my retro PCs.
C-Ray is a benchmark created by John Tsiombikas ( https://github.com/jtsiomb/c-ray ). I merely compiled the source under DOS using an old Watcom CPP compiler after implementing some simple QoL tweaks.
The benchmarks runs on any 386 class processor with a FPU , some XMS memory (4Mb should be enough) and a VESA 2.0 compliant video card capable of 32bpp (either natively or though a VBE driver). So far I've been able to run in on old 486 boards with PCI or VLB, and several Pentium motherboards. The benchmark relies heavily on the FPU, even more so than DOS Quake. Cache, memory latency and other aspects of the hardware architecture seems to have a very limited impact on the result. By default it creates a 640x480 image with 1 sample per pixel. Resolution and samples per pixel can be specified. The results scale linearly, so an image of 320x240 with 4 samples per pixel will take as much time to be computed as one of 640x480 with only one sample per pixel.
Attached you'll find the preliminary results for my machine based on a Zida Tomato 4DSP motherboard, 256KB cache, 32MB of 60ns RAM. I tested this configuration with several CPUs from my collection. Benchmark was run with default settings (640x480, 1 sample per pixel)
Reply 1 of 3, by MSxyz
The benchmark runs also without a FPU, in this case has to do the floating point calculations in software.The results, however are absolutely brutal 😁
If a 486DX2-66 takes 270 seconds to render the above scene at 640x480, a 486SX2-66 (the fastest x86 CPU that didn't come with a FPU) takes 9455 seconds! That's 35x more time to do the same computations. I'm not saying it can't be done faster than with the default Watcom CPP x87 libraries, but I'm not surprised about the results. Heck, I still remember my first experiences with rendering using a humble Amiga 500 with a 68000 running at 7.14 MHz... I was very envious of people who could afford a FPU add on card, not to mention those 68020 accelerators...
Reply 2 of 3, by jtsiomb
Oh hey, just stumbled onto this. If you want to send me your QoL additions, either as pull requests, patches, or just a zipped source code and some description of what you changed, I'd love to take a look and possibly merge whatever makes sense to merge.
John Tsiombikas (Nuclear / Mindlapse)
Reply 3 of 3, by aVd
jtsiomb wrote on 2025-11-25, 21:31:
Hi, John,
You can check some modified and bugfixed C-Ray32 and C-Ray16 (both DOS versions) source code from the attachments here.
SvarDOS fan :: artificial "intelligence" bots - not a fan at all :: say NO to systemd :: is freeware a lie, when human freedom is a fundamental lie? :: f00ck €u!
