First post, by Nicolas 2000
Hi all!
I'm 40 now, and have been busy with computers all my life. After a start with a hand-me-down 386, the computer of my youth was a 200MMX with a Voodoo2. So I didn't merely adopt the Voodoo life. I was born in it, molded by it. I didn't see an unused PCI slot until I was already a man.
Anyway, life happened, sold the PC's -with Voodoo2 12MB inside- for pocket change at a carboot sale. Yeah. Silver lining: I kept all my old big box games and somehow the original packaging of my Creative Voodoo² 12MB.
Anyway, midlife crisis happened. Wanted to return to the old PC masterrace glory. The main goal is to play the games I had back then, and some nice older DOS games like Slicks 'n' Slide, Cyberdogs... So I'm aiming at a W98SE system. I have a more recent XP system to play Half Life 2 and beyond, so there is no need to go over the top with the specs of the W98SE build. However, I do want improvement over the 200MMX I had back then as it was holding on for dear life in some games.
If the PC turns out really incompatible with a few old DOS games, so be it. But i aim for at least a good chunk of DOS compatibility. I know that Cyberdogs doesn't like anything above 200MHz (zero division...) so we'll see about that. Though I would like to be able to play GLQuake, Dooms, Duke3D, Warcraft 2... Straight from W98 if possible, exit to DOS if needed.
Speaking of not going over the top, I have bought a Creative Voodoo² 12MB SLI setup. To let the Voodii stretch their legs, I have bought a Pentium !!! Coppermine 733. 128MB RAM, but I have another 256MB bar laying here so you do the math. Ati Rage 128 (non pro) is what came with it, once everything runs I'll see about any need to swap that one out or not. SB Live! and a Philips PCI SB clone and onboard sound Creative CT5880. Yeah. But I also have a real SB16 ISA here, so the Philips might get swapped out. All this in a Fujitsu Siemens T-Bird case with a Gigabyte GA-6VX7-4X REV 1.2 Socket 370 Motherboard. I have and old optical USB mouse waiting to increase the quality of life, and a nice 5:4 IPS HP monitor from 2015 to give me excellent quality image in that good old 4:3 ish resolution. I've even already bought an Extron vsw 2vga a automatic switch to get rid of the Voodoo passthrough cable.
So I'm all set. However here comes the part where I need your help. I need to cobble it all together into one functioning PC. It currently runs XP, no Voodoo's installed. So my first big question is: what steps to follow for smooth sailing. Format C? Then install W98SE from CD? Boot diskette required? What procedure to install the Voodoo's? When to add the RAM? Swap out sound cards? Extra steps are fine if it means a greater chance of getting it up and running without issues.
I'm quite computer literate, I program for a living and I used to swap out graphics cards and the like even as a kid. I just don't want to make life any more difficult than it is, so any good approach to avoid a world of IRQ conflicts is welcomed.
In the meantime, I'll DIY my SLI cable.
