End of 10
Reply 80 of 95, by the3dfxdude
Namrok wrote on 2025-05-14, 14:21:
So, I did run into a real world case of this just gaming. I tried to play an older game, Harvest: Massive Encounter. It apparently had a Linux native version. It attempted to install a batch of binaries that were no longer supported in Mint 22.1, and so it completely failed to run. It actually ended up working better running the Windows version through Proton than trying to get the Linux version working properly. I have to admit, it was unexpected. As I continue down this path, I wonder if I'll find Linux has better compatibility with 10-20 year old Windows software thanks to heavy development into Wine/Proton than it has with 10-20 year old Linux software.
This is not a linux issue.
The issue here is the distro is not supplying version latest-1 of libfoo, and the game dev or you aren't supplying it. The difference to the Wine project, is that it seems everyone is being tricked into installing it which happens to provide all the necessary 20 year old ABIs in the name of getting to play their games, in a massive package that is a re-implementation of the WinAPI that won't be changing for an app that's 20 years old anyway. So of course it works.
There are runtimes people have assembled similar to what Wine provides to get WinAPI support, but for the older/other libs that Linux executable format games use from back in the day. They just aren't getting attention because, people focus on the narrative blasting linux as sucking for backwards compatibility, and people then never look. The libs never went away.
Flatpak was never really needed to solve this. For the people talking about 10 year support, I have worked in both open source and closed source (commercial) and we support multiple distros, and go back 10 years often with customers. Any competent application developer knows what to do to support the users.
Reply 81 of 95, by chinny22
Is Windows 10 really that loved people don't want to upgrade? or is it just the stricter hardware requirements?
I find Windows 10 does the job but I don't love it. Been using 11 for over a year now and for me its about the same. It does the job but that's it.
If MS want to give me a free upgrade to yet another mediocre for free then fine.
Anything that can't upgrade I'll run it unsupported till it breaks, that's what I've done previous times without issue.
Reply 82 of 95, by dr_st
chinny22 wrote on Yesterday, 02:37:
No, it's just that people just don't want to upgrade (especially if it is perceived as forced), period.
So each time a new version of Windows comes - it's the same old tune - sucks, old one was so much better, I'm staying with it.
3-5 years later a good portion of people moves, finds out it is not so bad, gets used to it, then the next one arrives, and it all repeats.
Indeed.
Reply 83 of 95, by Grzyb
keenmaster486 wrote on 2025-05-14, 06:05:
I'm serious - standardization is here. Debian, apt, that whole ecosystem... it's the Windows of Linux, in a good way.
I'm not convinced.
Debian release cycle is 2 years.
RHEL - 3 years, and they seem to actually care about binary compatibility.
RHEL 10 just got released - current "el10" RPM packages should work with future 10.x releases, probably until 2028.
For how long can we expect current DEB packages to work?
eM-!3 wrote on 2025-05-14, 08:21:
The same issue exist in Windows when new MSVC or .NET is released and you get a binary file without dependencies.
But for Windows, I hardly ever get a binary file without dependencies.
During the last 10 years, only TWO major Windows versions got released.
For a third-party vendor, this means: only TWO testing environments.
Do a clean install of Win10, test everything, do a clean install of Win11, test again - and the product is ready to ship!
Really, it's hard for a software vendor not to notice missing dependencies.
the3dfxdude wrote on 2025-05-14, 21:12:
Indeed - Linux is just the kernel.
But this is a HUGE issue of all Linux-based operating systems.
Or the fact that the latest version API isn't compatible with latest-1.
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Reply 84 of 95, by The Serpent Rider
[sarcasm] Just put everything in flatpaks [/sarcarm]
Reply 85 of 95, by BEEN_Nath_58
How well is the Wayland support right now compared to X11?
I see a lot of mentions about X being obsolete, however I have heard of a lot of glitches and stability issues on WLand
Reply 86 of 95, by UCyborg
dr_st wrote on Yesterday, 04:46:
I think older versions have a different, almost relaxing vibe to them while newer are more raw, with bland color scheme and flat design / lack of skeuomorphism. I wonder if people working at Microsoft today ever visit the old versions (old PCs, emulators, virtual machines etc.). Oh, and no background processes firing on their own in the old versions unless you set some up yourself.
Hm, I did think of the default gray color scheme of pre-XP versions as a graveyard scheme, though I'm not sure what I'd pick today instead. Maybe some light blue? A least I think blue is one of the reasons I fancy Aero.
Is it possible that eg. in the 90s, people had more easygoing approach to computers? And maybe life in general. I don't know, maybe tensions were always this bad and wasn't really aware since I was just a kid.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 87 of 95, by dr_st
UCyborg wrote on Yesterday, 09:49:
It goes back and forth. Win8 was flat but overly colorful. Win10 relaxed the color scheme (too bland?) Win11 adds back some rounded UI elements compared to the flat and rectangular UI of Win10.
There are always background tasks. They can either be split into individual processes, or multiple tasks stuck inside the same process (svchost, anyone?) The end result may not be very different from user experience point of view.
With that said, the overall number of background tasks does increase, as the OS generally starts doing more things (which are claimed to improve user experience, but it is not always so).
Reply 88 of 95, by gerry
MS wasn't entirely honest about its requirements - not in RAM and CPU, its fine - but more recent iterations practically require an SSD.
Windows support questions/forums are littered with complaints about how incredibly slow windows 10 is during updates of almost any kind (and the hopelessly 'by the book' robotic answers from MS people and MVP types that studiously and completely miss the point.....)
I have an older laptop that runs Win10 fine - but it has HDD not SSD, when a large update is happening the computer is almost unusable for some time, sometimes over an hour. Luckily it isn't a critical work machine and i have an almost "this cant be real" fascination with just how crippled win 10 becomes while updating, even after fine tuning.
and yet on a similar specced machine with an SSD, its all fine!
I'm guessing almost all new machines are sold with SSDs now, and have no idea how Win11 acts. I can say that Linux Mint seems fine - Linux updates all the time, almost daily, yet it handles it all ok on quite constrained systems with HDDs
Reply 89 of 95, by Namrok
gerry wrote on Yesterday, 15:44:
MS wasn't entirely honest about its requirements - not in RAM and CPU, its fine - but more recent iterations practically require […]
I can say from my own experience, this is a thing that got progressively worse with Win10. My wife has an old laptop that gradually became completely unusable despite being perfectly fine when it (and Windows 10) were brand new. It was entirely down to the HDD being horribly thrashed whenever Win10 did updates. And unfortunately, my wife's usage pattern evolved into "Laptop is slow so I never use it, when I have to use I have to wait several hours for all the updates to finish, then I turn it off and avoid using it as long as possible because it's slow". After replacing the HDD with an SSD it was flawless. Later on upgrading the ram from I think 8GB to 16GB helped a lot too.
The relentless cruft constantly shitting up Win10 over a lifespan is just abominable.
Win95/DOS 7.1 - P233 MMX (@2.5 x 100 FSB), Diamond Viper V330 AGP, SB16 CT2800
Win98 - K6-2+ 500, GF2 MX, SB AWE 64 CT4500, SBLive CT4780
Win98 - Pentium III 1000, GF2 GTS, SBLive CT4760
WinXP - Athlon 64 3200+, GF 7800 GS, Audigy 2 ZS
Reply 90 of 95, by chinny22
Namrok wrote on Yesterday, 17:34:
I can say from my own experience, this is a thing that got progressively worse with Win10. My wife has an old laptop that gradually became completely unusable despite being perfectly fine when it (and Windows 10) were brand new. It was entirely down to the HDD being horribly thrashed whenever Win10 did updates... After replacing the HDD with an SSD it was flawless. Later on upgrading the ram from I think 8GB to 16GB helped a lot too.
This was the same experience as my wifes Macbook Pro, number of years ago. I guess it makes sense though.
Any computer they had sold in the last few years only had a SSD so was the 5+ year old machines that still had a spinning HDD.
At what point to do start to prioritise the newer technology instead of holding back for older systems?
If I was ever to give that laptop a clean install I wouldn't install the latest supported version, but find which is the best suited for that generation.
Windows 10/11 is much like MacOS now where If your running older hardware may be a good idea not to move up to the latest Feature Update
Reply 91 of 95, by the3dfxdude
It's slower than I remember Win10 being, and that was slow.
You will see I'll defend linux where there are sane devs, and tell you that it doesn't deserve flak for things that can happen on any OS due to bad devs. (dependencies and ABI crap is not a linux issue) But I'm quite wary of most distros competence, one that updates almost daily. (Why?)
I know from experience that Windows 10 API was not stable between releases, such that I had to code in sub release/update number checks! Sorry Microsoft is more like the nutty rolling release Linux distros. That is not a good example for something with the same version number for 10 years.
You throw linux out of existence, and let Haiku be the open source king, it will be the same complaints, poor quality projects start infiltrating everything. This isn't a linux issue. It's an every-OS-issue.
Reply 92 of 95, by Intel486dx33
No more 32bit support.
What to do with all my 32bit computers ?
Reply 93 of 95, by dr_st
This in a point in and on itself. The official Microsoft support forums (answers.microsoft.com) are literally a useless pile of garbage, filled with exactly what you described. At some point a couple of years ago I was shocked to realize that I have never, ever, not once, had found any solution to any problem on their forums. So I developed a habit - to skip any search result that points me to that useless waste of cloud storage.
Any OS will be faster with an SSD, because random access on a mechanical drive is a major bottleneck. However, Windows 10 (possibly also 😎 somehow (and don't ask me about details) have their standard system services and background flows heavily optimized towards random access of the storage, which makes the difference huge. I never had a satisfactory experience on any system with Win10 and a mechanical drive, and yet my old desktop which started with Vista and now has Windows 7 is still somewhat OK, even with the system drive being a 10-year old 7200RPM HDD.
Win11 kernel is an evolutionary step from Win10, so it probably behaves the same. SSD are so standard these days, there is absolutely no reason to change the approach. In fact, if anything, solid state storage is likely to become a minimum requirement for a system drive.
chinny22 wrote on Today, 02:04:
Depending how old, I guess. Having updated a 2012 machine from Win10 1909 to Win10 22H2 within the past year, I didn't experience any negative consequences, and a few glitches went away.
Reply 94 of 95, by gerry
dr_st wrote on Today, 07:44:
I learned that too. What amazed me was the seemingly deliberate obtuseness of the answers, always ignoring the central details obvious to any reader and referencing generic and pointless checklists with various unrelated and ineffective steps. I'd love to know from anyone who ever took the helpdesk roles there to see if they were heavily guided towards that behaviours for corporate reasons (eg fear of litigation, bad press etc)
I guess so and SSD is standard it seems, win7 was ok with HDD even when still supported, so there was a step change from there
This is the issue, if i leave that old laptop too long it'll be out of action for hours effectively, it puts off those who are not using it day to day. When i need it i have learned to start it about an hour before i need it, just in case today is the day for updates
the3dfxdude wrote on Today, 02:19:
While i'm happy with the ability of linux to function while updating, and the greater control the user has about installing them, i am sometimes surprised by the frequency of updates, i don't even have that many applications outside of the usual linux mint standard ones
Reply 95 of 95, by Joseph_Joestar
gerry wrote on Today, 09:38:
The update frequency probably depends on the distro.
I also use Linux Mint on one of my systems, and it pretty much wants to update on a daily basis. Not entirely surprising, since it's based on Ubuntu. On the other hand, I run MX Linux (which is based on Debian) on my laptop, and it updates far less frequently. Maybe once or twice per week.
