You guys are right. Most of the DX8 demos don't work. The ones that do work are:
Skinnd mesh, runs and shows a cyan/grey screen. […]
robertmo3 wrote on 2025-05-16, 19:53:
nvidia is going to remove stap by step, feature by feature directx3D13 too.
if you want to help, test dgvoodoo instead, which doesn't plan to turn those features off, but instead already supports all direct3d versions up to and including 9c
Text3D
VolumeTexture
It does look like it's being axed. Well beginning with the GTX1000 series, they killed VESA 2.0 linear framebuffer support, making it nearly impossible to run Warcraft I I *think*.
I wonder what's been removed from OpenGL (gulp). My life is about to become very very difficult. AMD's removed non-UEFI boot support with the RX9070, which means no more freedos, maybe.
I need to get some sleep. Need a bottle right about now 🙁.
