First post, by Wurenji
- Newbie
I have registered at VOGONS for a period of time but this is my first post.
# Hardware configuration
Here are the full view of my build (sorry for my bad cable management):
For outside, almost all of them are from the Win10 era and not period correct:
- Case: Cooler Master Silencio 352
- Monitor: Lenovo ThinkVision LT1913p
- Speakers: Edifier R1200TII
- Keyboard: Rapoo V500Pro mechanical gaming keyboard
- Mouse: Some unbranded USB mouse, got it for free from my previous roommate
- USB hub: Ugreen switchable USB hub
Here is the internal view:
- CPU: Intel Pentium Dual-Core E5800 @ 3.20 GHz
- Mainboard: Gigabyte 8I865GME-775-RH Rev. 2.0 with 45nm patch
- RAM: Two A-Data DDR400 1GB sticks with stock 3-3-3-8 timings
- Graphics: UNIKA Radeon X800 XT AGP
- HDD: Seagate ST3500418AS (Windows 2000, XP and Data)
- SSD: Gloway Fervent 120GB (Windows 7 32-bit and Debian 11 64-bit)
- ODD: Optiarc DVD+-RW AD-7250H, via SATA-to-IDE adapter
- FDD: Sony MPF920-Z
- Audio: Sound Blaster Audigy 2 ZS
- Network: Onboard Intel 82562
- CPU cooler: DeepCool GAMMAXX 300
- PSU: Huntkey HK400-52SP (300W max)
# Uses
Definitely I use it to play some old games that I played in my childhood, notably CS 1.6 and Diablo II, and also some old software like Visual C++ 6.0.
It has a very capable burner, so I use it for burning some CDs for my CD player and retro computers.
I've set up a quad-boot configuration: 2000 for older games/software and MIDI, XP for some newer games, Win7 for some everyday use and flashing old Android/Nokia phones I collected, and Debian 11 with Trinity Desktop for some web browsing.
# Notes
Originally I had an Asus P4P800-VM with Pentium 4 3.0E. The CPU runs very hot (Preshott!) and the board cannot remember CMOS settings after disconnecting the power even with fresh CMOS batteries. I switched to this Gigabyte board before prices go up. The original CPU for this board was a C2D E4600, but I got a modded BIOS with Wolfdale support. E5800 works perfectly.
There is a problem: I planned to run Windows 98 SE on it, but I couldn't get the GPU working. After installing the driver and reboot, the resolution didn't change, and the device manager says some of the driver files are missing. I tried different versions of ATI driver and use device manager to install manually but no luck. Recently I got a bundle with Sempron 2500+ and ECS K8M800-M3 from my friend for free, I will try 98SE on it someday.
PC#1: Ryzen 7 3700X / MSI X470 GAMING PLUS MAX / RX 9070 XT
PC#2: Core i9 13900H / Lenovo ThinkBook 16p Gen4 / RTX 4060 Laptop
PC#3: Xeon E3 1230 v2 / Gigabyte Z77M-D3H / GTX 760
PC#4: Pentium E5800 / Gigabyte 8I865GME-775-RH / X800 XT AGP / Audigy 2 ZS
