First post, by Paladin PIP
I got a CT4780 Sblive card. It works with both sound and midi in dos 6.22 and 7. There is a test in the Descent 2 sound setup with a test for redbook audio. I was always curious what the cable was for from the cdrom to the card. I have both the analog 4 pin and the digital 2 pin hooked up. I get zilch from the test, it actually dosen't look like the cd is even being accessed. But if I run the game it uses it. I have no way of knowing if its a faulty cd, or a driver issue. Is there any other way to test that the cable and cd and drivers are setup to play this cd-audio track format and that its working right ? Is there any other test utility specificly for this ?
