Silverstone to release a retro-style desktop case
Reply 60 of 71, by Standard Def Steve
chrismes wrote on 2025-05-05, 19:58:
I can also answer the question of whether the FLP01 can hold a monitor or not. It's sturdy enough.
Mmm mmm good. Dang, that's fine!
"A little sign-in here, a touch of WiFi there..."
Reply 61 of 71, by bofh.fromhell
Seems like Silverstone will add another retro look case to its lineup:
The bottom PSU location and shroud (maby its removable?) limits its retro uses.
But atleast it seems like it has 3 full 5.25" slots.
Reply 64 of 71, by Unknown_K
I like the look of the case, but the 2-digit LED should be replaced with one showing the current CPU speed.
Reply 65 of 71, by jakethompson1
bofh.fromhell wrote on 2025-05-21, 19:00:
I've found the biggest limitation on post-2015 (or so cases), at least for sticking a VLB-sized Baby AT motherboard in there, is that there tends to be a "lip" around the motherboard tray, putting a limit on width.
On older cases without that, you could get away with a board a little wider than the designers expected.
What are you thinking the PSU shroud blocks? And you can always use an extension on the motherboard power cable, though it's ugly.
Reply 66 of 71, by jakethompson1
If the FLP01 really is selling better than they expected, I wonder if this leads to a revival of beige peripherals to go with it
Reply 67 of 71, by wierd_w
I should order one to make into a modern sleeper system.
(The practical joke would be to put an LS120 in a bay adapter on this thing.)
Reply 68 of 71, by anamyd
Unknown_K wrote on 2025-05-21, 20:52:
Does the 2-digit 7-segment display need to be replaced, or can't a controller be made for it that makes it show the CPU speed? Of course, it would only be good for up to 99MHz, but if the dots/points were used, it could show GHz instead, such as "1.4" for my Pentium III Tualatin, "2.2" for my Athlon 64 (single-core) and "3.4" for my Pentium D.
Reply 69 of 71, by SquallStrife
Unless they're obscenely expensive, I'll get these for all my ATX systems, including my main Ryzen system.
Is it modern? Is it a K6-2? WHO KNOWS??? Lucky dip! 😁
Reply 70 of 71, by Unknown_K
anamyd wrote on 2025-05-22, 00:22:
My understanding watching a video of that case is that the 2 digits are programmed to show fan PWM speed. The turbo button on the front toggles the fans to 100% on for extra cooling.
Reply 71 of 71, by aries-mu
Whooooooooooooooooooooooooooooooooooooooooooaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaohmygosh!
THIS IS AWESOMEFANTASTIK!!!!!!
It is happening guys!!!I can't believe it!!!!
So, when I called SilverStone several months ago, they recommended that we spread the rumor, we push with the national stores, so that they will be convinced to order the case.
I had Retrocomputer magazine in Italy cover the topic, telling readers to call the stores... here's the article:
I recommended they make other traditional retro cases, they said it all depends on how the sales of FLP01 go.
They must go well! A few days ago, a store in Germany got restocked. And here in Italy too! Drako.it got it. I ordered it 2 days ago! But I'd have preferred this tower one 🤣!
I'll call them tonight and ask how it's going and what their further plans are, if any.
They said therefore to him: Who are you?
Jesus said to them: The beginning, who also speak unto you
"physical media trumps cloud-simp servitude" (Conrad Riker)
Computers should be fun inside not outside! 😉 (by Joakim, VOGONS)
