Reply 20 of 39, by stinkydiver
Looks like the revision is SU093 which should support USB 1.1. So this is beyond me why it refused to work
Take that there and put it in here
Reply 21 of 39, by maxtherabbit
I ran SIV on two different 440FX systems. The first, which has working USB is shown here:
The attachment 20250519_213321.jpg is no longer available
Next the Octek board with no USB components populated:
The attachment 20250519_213400.jpg is no longer available
Oddly the Octek board shows no USB controller whatsoever... does this mean it is SY052?
Also both machines are showing cards which are no longer present in the system, which is odd
Reply 22 of 39, by stinkydiver
Is USB enabled in the BIOS of your Octek board? I had to enable it in mine for it to show up in SIV.
Reply 23 of 39, by maxtherabbit
There is no option for it, I'm already on the latest bios too.
Reply 24 of 39, by myne
Try a Linux live CD from... Around y2k.
If Linux won't make it work, it's broken.
I built:
Reply 25 of 39, by jakethompson1
The PIIX3 datasheet suggests that there is a USB Enable bit in PCI configuration space for function 0.
However, there are potential pinout differences depending on whether USB is being used or not. A 3.3V supply is only needed if USB is enabled, if not, it can be supplied with 5V only.
Reply 26 of 39, by stinkydiver
maxtherabbit wrote on 2025-05-20, 02:26:
Do you have USB headers on your motherboard? If not, perhaps it doesn't even have USB support
Reply 27 of 39, by maxtherabbit
jakethompson1 wrote on 2025-05-20, 03:12:
Indeed there is. After spending more time than I would have liked with the datasheet, (it's in "miscellaneous status register") I whipped up a little COM file in DEBUG to turn it on.
Reply 28 of 39, by maxtherabbit
After turning it on, and running WIN, win98 pops up and prompts to install the driver. Then when I run SIV I get this:
The attachment 20250521_213225.jpg is no longer available
So if SIV is to be believed, I have the working revision. Of course, so does stinkydiver and it still doesn't work. Makes me think twice about going to the trouble to solder on the components.
Reply 29 of 39, by maxtherabbit
stinkydiver wrote on 2025-05-20, 03:25:
No pin headers, just the unpopulated footprint at the I/O shield
Reply 30 of 39, by myne
This feels like information that should have been in the first post.
Gee I wonder why something that was deliberately disabled during manufacturing doesn't work?
I built:
Reply 31 of 39, by mockingbird
I say you gave up too easily. I have USB working fine on my i430VX motherboard (some generic model I can't be bothered to look up ATM).
The attachment PIIX3USB.png is no longer available
(Decommissioned:)
Reply 32 of 39, by stinkydiver
I'd happily try other things to troubleshoot, but I have run out of ideas.
Reply 33 of 39, by mockingbird
stinkydiver wrote on 2025-05-22, 04:15:
Try nusb36e from here.
BTW, when I say working, I mean as in I insert my USB storage stick and everything works fine. I can read from it and write to it.
(Decommissioned:)
Reply 34 of 39, by stinkydiver
mockingbird wrote on 2025-05-22, 04:29:
That is my end goal, USB storage function 😀
In the mean time I've been using FTP to transfer files which is fine. Still, would be nice if that USB slots worked...
Reply 35 of 39, by myne
In all probability since it was unpopulated from factory, there are other components missing, like resistors and diodes.
I built:
Reply 36 of 39, by maxtherabbit
myne wrote on 2025-05-22, 06:20:
You are conflating me with the OP. My board (Rhino Pro 6) does have missing protection diodes and a PTC footprint. I have not installed any components nor the USB connector itself. I have also not attempted to test anything beyond twiddling with the PCI config register and running SIV.
Stinkydiver had pin headers from the factory and they mysteriously do not work, despite having the correct south bridge revision
Reply 37 of 39, by maxtherabbit
myne wrote on 2025-05-22, 03:17:
Some of us are inspired to unironically ask such questions and attempt to answer them
Reply 38 of 39, by darry
maxtherabbit wrote on 2025-05-22, 13:53:
Yup.
Sometimes, it's because it couldn't be made to work due, for example, to a chip flaw or to a short-sighted design. Replacing the chip might be an option if a fixed revision exists. Working around some other issue might be practically impossible, even today.
Sometimes, it's because it couldn't be made to work practically or at a reasonable cost, so the design was changed at a late stage. In modern days, it might be possible to work around this.
Sometimes, it's because of market segmentation, where expensive model B has a feature implemented and cheaper model A does not, with both being based on the same design. That one is pretty obvious.
Sometimes, it's something else.
It can be fun to find out.
Reply 39 of 39, by myne
maxtherabbit wrote on 2025-05-22, 13:52:
Ah. Right. My bad.
Again, I'd try a linux livecd.
I built:
