Asus TUV4X and Pentium iii SL6BY 1.4GHz (SOLVED)
Reply 100 of 137, by myne
Got a dishwasher?
I've run dozens of things through and about half the dead ones came to life.
Zero soap. Full cycle. Dry in full sun about 4 hours after flicking fairly dry. Or any 3 days inside. Or about 15m in a 90c oven.
I built:
Reply 101 of 137, by Kittyboy
myne wrote on 2025-05-04, 10:28:
Got a dishwasher?
I thought you were just messing with me when you first suggested the dishwasher. Most be an old school technique. 😀
Pentium III 1.4GHz-S (SL6BY), Asus TUV4X, Plextor 760A, ATI 9800 Pro, MS-DOS 6.22/Win98se dual boot
Reply 102 of 137, by myne
How do you think they're cleaned in the factory?
As long as there's no power/battery there's nothing magical about electronics.
I built:
Reply 103 of 137, by Kittyboy
Trying to find closure (SOLVED ) status, why I failed to repair my TUV4X, I spent a number of additional hours visually re-inspecting the board to find physical damage. It appears I initially damaged the board installing the heatsink. A very tiny surface trace near the cpu socket was discovered deformed, only visible under high magnification. Apparently I caused the damage with impact from my screwdriver during installation. I am unable to check for continuity, it's too small. I have attached a few images for others to analyze. It just never sat well not reviving my board from death, especially with EXPERT remote assistance from Vogons member @shevalier. At this point I feel confident to conclude SOLVED status for this posting. Thank you to all the other Vogons members kind enough to help out and advise as well!
Reply 104 of 137, by myne
Doesn't look bad enough.
But the board does look dirty.
Again, wash it.
I built:
Reply 105 of 137, by Kittyboy
myne wrote on 2025-05-13, 01:36:
Again, wash it.
Here is an added image, it's not under the same magnification I was using, but illustrates a likely issue.
Reply 106 of 137, by myne
Fair enough.
One tiny solder blob and you'll know.
Still can't hurt to wash it. Toothbrush and dishwashing liquid if you don't have a dishwasher.
I built:
Reply 107 of 137, by Kittyboy
myne wrote on 2025-05-13, 03:20:
Fair enough.
haha, its such a tiny trace I can hardly see it, even with magnification. If I did attempt, I would need to purchase a new iron tip and a mounted magnifier, guess its worth a shot...
Reply 108 of 137, by bloodem
Kittyboy wrote on 2025-05-13, 03:56:
You most likely don’t need a new iron tip. Even a large one will work fine for this job.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 109 of 137, by Kittyboy
Rather than create a new page, I thought to keep adding to this one with TUV4X related information based on my current experiences with my TUV4X setup. Fortunately, I purchased two TUV4X boards, down to one now, thru operator error I killed-off one already out the gate. And "I do" deserve to be slammed into the rocks for its timely destruction at my hands! I am still experiencing nightmares...
So for this post, I wanted to share a couple observations I don't understand? First, the 'back-to-back' BIOS enable/disable memory related setting and its purpose, (see image). I experience OS freeze-up during boot into Win98 with back-to-back default setting 'enabled' with one stick of 512MB ram and/or two sticks of ram. However, if set to 'disable' everything seems fine? I am also curious to learn if I am operating at full system capability with disabled selected?
Also, what exactly does 'enable' BIOS auto setting enable?
Reply 110 of 137, by _StIwY_
Kittyboy wrote on 2025-05-22, 22:45:
Oh my GOSH!! you saved my day...you really did with this hint!
Just for the record, since yesterday i was bashing my head with a TUV4X paired with a Tualatin 1.4Ghz.
I noticed that i couldn't boot most of diagnostic programs i use to test the stability ( and Windows 98 SE setup too was getting stuck all the time ).
I tried EVERYTHING since yesterday.......changing RAM, PSU, CD-ROM, cables....nothing worked. Almost every testing tool was going on a blank screen before the boot.
The motherboard is even perfectly clean and the capacitors looks like new. So i was wondering where the heck was the problem
Then i tried to reduce the CPU speed from 1400 mhz to 1050 mhz, so the bus from 133 mhz to 100 mhz...and everything was working again.....win 98 setup aswell.
So i installed Win 98 SE with the CPU at 1050 mhz / 100 mhz......then i tried to put the CPU on default again at 1.4Ghz, and.......Windows 98 was getting freezes right at the boot with the background logo.
Then i searched on internet and came up here...to read about this damn option in the BIOS....and guess what ?
It solved everything. Now the setup and every diagnostic program boots...and i can finally complete the build
P.S: And yes i wonder what's the purpose of this cursed option..which is Enabled by default -__-"
Reply 111 of 137, by bloodem
What that setting does is reduce latency for consecutive CPU -> memory transactions.
The memory controller allows the CPU to start a new memory transaction immediately after the previous one, without inserting idle cycles (a sort of "0 wait states" for consecutive memory access chains).
Stability when using this setting might heavily depend on the RAM silicon lottery, chipset silicon lottery and overall board design.
Reply 112 of 137, by _StIwY_
bloodem wrote on 2025-05-23, 08:21:
I will never forget this BIOS option from now onward.....i was going crazy to figure out what the problem was x)
Reply 113 of 137, by Kittyboy
_StIwY_ wrote on 2025-05-23, 08:30:
I am happy it helped out. One other thing to keep in mind. The 'disable' setting some how will 'self' 'reenable' at times. When that occurs, you have to go back into the BIOS and change again. I don't know how the BIOS just decides when to change things on its own?
Reply 114 of 137, by Kittyboy
Kittyboy wrote on 2025-05-23, 09:02:
Also, I have noticed that when clocking down to 1050, the issue does not occur as frequently, experiment with that and follow-up please. May be that 1400 is too fast for the board design/memory as previously noted by another VOGONS member.
Reply 115 of 137, by _StIwY_
That's weird, i never had this motherboard until a couple of days ago, i will keep you updated because i'm still testing everything, then i will use the PC for retrogaming.
P.S: Let's not forget that the BIOS 1006.002 was left on beta state, maybe is afflicted by some glitch?
Reply 116 of 137, by Kittyboy
_StIwY_ wrote on 2025-05-23, 12:21:
Yes, mine is the 1006.002 as well. Thanks for reminding me. I will revert to the previous 1005 and test that out.
Reply 117 of 137, by _StIwY_
Kittyboy wrote on 2025-05-23, 12:39:
Any news ? I've been using the PC for two days, dozens of reboots, installing game / playing games / stress test like 3dmark2000 in loop ....etc. Nothing to report, PC seems perfectly rock solid, after disabling that option.
Reply 118 of 137, by Kittyboy
I am working out a few things, primarily, when I perform a cold power boot with power disconnected overnight, it will boot into the BIOS (see image). This may be because currently I'm running a dual boot setup, MS-DOS 6.22/Win98se?
Reply 119 of 137, by Standard Def Steve
Oh man, I too was thrown off by that 'CPU DRAM back to back transaction' thing when I had my TUV4X.
I could only get that setting to work @ 133MHz FSB with Coppermine CPUs. With Tualatin, it'd only boot at 100MHz.
Based on the brief description of what the setting does, and the fact that Tualatin has a data prefetcher (Coppermine doesn't) I'd wager that Tualatin @ FSB133 is simply too demanding on the memory controller.
"A little sign-in here, a touch of WiFi there..."
