First post, by plantfood
I just installed DosBox and am trying to install Return to Krondor. I created a directory for my game and mounted it as the c drive, and mounted the cd-rom drive as the d drive. I switched to the d drive and I can run the directory command and see the file "setup.exe" in the list. However, when I type "setup" or "setup.exe" the prompt says "win setup.exe" and then the error "illegal command: win". I didn't type "win". What am I doing wrong?
Thanks in advance.
Kelly
Reply 1 of 12, by leileilol
PRO TIP: Windows games run on Windows
Reply 3 of 12, by plantfood
Ok, duh, but it's a 16 bit game and I read somewhere else on the Web that 16 bit games run on dosbox because Win 3.1 overlayed dos. Do you have any suggestions on how to run a 16 bit game in win xp?
Reply 4 of 12, by leileilol
I dunno, but... have you tried running it in Windows XP!
Reply 5 of 12, by DosFreak
16bit Windows games run fine in Windows XP 32bit.
16bit Windows games only run in DOSBox if you install Windows 3.1 in DOSBox.
Is Return to Krondor a 16bit game? and would it work in Windows 3.1? Since it was released in 1998 somehow I doubt it.
Return to Krondor works fine in Windows XP, duh
Make your games work offline
Reply 6 of 12, by Miki Maus
Both Wikipedia and MobyGames mention that Return to Krondor is game released for Windows 95 which is logical as it came out in 1998.
Offtopic:
Did anybody else notice disturbing trend on Internet where people are recommending DOSBox for any game that doesn't run on WinXP/Vista? It seems that it doesn't matter to them if it was made for DOS or Windows. 😒
Reply 7 of 12, by wd
Rank DOSBox Author
DOSBox Author
That might mean dosbox is too user friendly, let's do something against this!!
Reply 11 of 12, by leileilol
Betrayal of Antara is Win16 though
Return to Krondor is definitely Win32, and also OMG 3D ACCELERATEZED
Reply 12 of 12, by DosFreak
collector wrote:
inway romfay hetay ommandcay romptpay?
Esyay eway avehay emthay imetay igpay atinlay inway ethay
ommandcay omppray. Ouldshay etgay idray ofway allway ofway ethay
oobsnay.
