Need HELP with socket 7 mainboard
First post, by coxilerio
Hello, im trying to setup an old forgotten motherboard socket 7 that I had lying aroung only to discover that it doesnt even let me install or run anything..
It is very strange
Specs
Mainboard pcpartner VIB804DS (35-8804)
Cpu amd k5 pr100
Ram 64mb sdram
Ide1 Hdd wd 20gb
Fdd floppy 3.5inch
No cdrom
Vga cirruslogic 2mb pci
So i have a bootable dos 6.22 floppy i boot pc from it. And on hdd drive i have win95 setup files complete. I try to run from c: drive
C:\win95\setup.exe
Setup starts and asks to press enter key to proceed to first step to run sandisk before starting win95 setup to check disk for errors.
When i press enter key the pc freezes.
I tried different ram, hdd , cpu, vga and still it cannot execute anything and just freezes. The jumpers on the motherboard are correct as i double checked them in manyal found in retroweb website.
Please help me identify and fix the problem.
Could it be a faulty motherboard or its chipset failing??
Pkz help
Coxilerio
Daily drivers:
Gigabyte Z790 Aorus elite, Intel 12900KF, I-Chill X4 RTX 3090
ASUS B550F, Ryzen 7 5800X, Gamerock RTX 3070
Retro Builds:
Intel 440BX, Pentium 3 (500), Geforce 2 GTS , SB Audigy SB1394
Intel 440BX, Pentium 2 (400), 3dfx Voodoo 3 3000
Reply 1 of 40, by Repo Man11
One thing that occurs to me is that the hard drive might be too large. Do you have the latest BIOS? You could always try to limit the capacity by manually entering the parameters.
https://www.youtube.com/watch?v=cCulATQ7GlM
Reply 2 of 40, by coxilerio
cant be the hdd. i tried another 3 hdd all tested free of bad sectors. 1.2gb seagate , 1.6gb wd, and 2,4gb wd all ide.
as for bios is not the latest , but it should have worked with the small hdd 1.2gb , 1.6gb and 2.4gb
the 20gb hdd gets detected in bios properly, so i thing the bios supports it too.
thanks
Daily drivers:
Retro Builds:
Reply 3 of 40, by coxilerio
note: the 3 hdd all tested free of bad sectors on another working computer!!
Daily drivers:
Retro Builds:
Reply 4 of 40, by Major Jackyl
I think the Win95 installer needs to be run from a CD. I've never been successful trying to "sneak" the OS onto a drive, from a drive. Going to/from the same drive is not a great idea, anyway, as it is going to try reading/writing at the same time, making the process slow as f and beating the sh*t out of the hard drive. (unless you're installing to a different drive, I suppose)
Is there a specific reason you're trying to install C:-C:?
I'd recommend burning the w95 ISO properly and running the setup from there. If you don't have CDROM loaded onto your boot disk, you can add OAKCDROM.SYS to CONFIG.SYS and MSCDEX.EXE to AUTOEXEC.BAT of the floppy and it should work.
Or even better, if you can generate a Windows 98 boot disk, those are great.
Quick instruction on adding CDROM to Boot disk:
Acquire OAKCDROM.SYS and MSCDEX.EXE and copy to the boot disk
At prompt (A:) after booted, type : "edit config.sys" +Enter
Edit should open if your disk is loading the shell properly. You can add this line just about anywhere:
DEVICE=A:\OAKCDROM.SYS /D:MSCD001
"/D" just sets the device same for the next step
Save CONFIG.SYS and open AUTOEXEC.BAT
add this line to the end :
A:\MSCDEX.EXE /D:MSCD001
Save and restart. Should boot with CDROM support. CDROM can be connected as Pri Slave or Sec Master/Slave, but should be set to "none" in BIOS (unless you have CDROM option)
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 5 of 40, by coxilerio
i tried to install from c drive as i originally have tried at first from cd with the same results as above
i suspect its the motherboard at fault
but what component on the mb though?
Daily drivers:
Retro Builds:
Reply 6 of 40, by Major Jackyl
The IDE controller is in this guy:
The attachment Screenshot 2025-05-24 131439.png is no longer available
Oi, I feel you. I've had this problem quite few times, for various reasons. One time it was a bad IDE cable. It was a bad drive (multiple times) Another time I was trying to get IDE-CF to work. I was using too many controllers simultaneously. Etc.
It usually isn't the board, but I wouldn't rule it out. Always start with having only the bare-minimum attached. If you have a PCI IDE controller, that can assist is diagnosis. (and possibly "fix" the problem)
Read/write operations are good otherwise? I'm assuming they're fine, since you have w95 setup files copied onto it.
How did you partition the drive(s)? Try leaving the drive blank (no partition) and doing it "manually" with fdisk/format from the DOS boot disk (will leave you stuck with 2GB partition, but if it works, you'll just need a w98 boot disk for the newer fdisk with "large disk support")
Reply 7 of 40, by coxilerio
To be honest i didnt try anothet ide cable. Or ife controller. But read write ops were good. So go figure ???
I didnt try fdisk method. I booted dos6.22 and run setup of win95 from both cd and also hdd. Setup freezing always.
I tried same method on my Pentium 2, pentium 3 and 486dx2 and those worked however.!!
Daily drivers:
Retro Builds:
Reply 8 of 40, by coxilerio
Thats why i think it might be a motherboard issue!!
Daily drivers:
Retro Builds:
Reply 9 of 40, by coxilerio
i have on it bios-g (71209B) on it with this string
01/22/98-580VPX-LGS3C-2A5LDV3HC-00 BIOS-G (71209B)
such version no where to be found even in retroweb , so even if i wanted to update the bios i cannot , as flashing diffrent bioses on it will brick it completely and must be then garbaged !!!
Daily drivers:
Retro Builds:
Reply 10 of 40, by dionb
coxilerio wrote on 2025-05-24, 20:40:
Hardly - the BIOS EEPROM is socketed, so if something goes wrong you can always pop it off and re-flash in an EEPROM programmer or if you don't have one, hot-flash from another board.
If you look at the BIOS images listed here: https://theretroweb.com/motherboards/s/pcpart … ds-35-8804#bios
You'll see the ones with "PRIME3(C)" string are for LGS super I/O chip which is what your BIOS string indicates; I'd suggest 02/11/98-580VPX-PRIME3C-2A5LDV3AC-00 would be a pretty good bet given your "LGS3C"
Reply 11 of 40, by coxilerio
why not 06/19/1998-580VPX-PRIME3-2A5LDV3AC-00 then. seems newer...
and where is bios-g in list of bioses. something tells me that the board is not VIB804DS but the VIB804DSe
pretty good betbut not entirely safe..
Daily drivers:
Retro Builds:
Reply 12 of 40, by coxilerio
and even if i try to execute awardflash to update bios , the pc will con execute the comand. it will freeze like it does when i run c:\win95\setup.exe or setup.exe /is command
lock up and have to cycle it from power button or reset buttons
what a mess !!!
Daily drivers:
Retro Builds:
Reply 13 of 40, by waterbeesje
Another lifehack for bios swapping:
get a second eeprom
Boot with original rom
Start awdflash or uniflash or whatever you use
Swap bios chips
Burn new bios file
Reboot.
This way you make sure the original bios chip remains untouched and you always have a fallback if the new bios file bricks the board.
Stuck at 10MHz...
Reply 14 of 40, by coxilerio
I just noticed that i cant even run awdflash to flash the bios
When typing on the keyboard in dos mode forgods sake the pc locks up and it must be reset...
Something is seriously wrong with this motherboard.!!!
Daily drivers:
Retro Builds:
Reply 15 of 40, by coxilerio
Best scenario is to bin it !!! I guess...
Daily drivers:
Retro Builds:
Reply 16 of 40, by Major Jackyl
It runs fine on floppies? Disconnect exerything except the floppy drive and boot/swap and load games/mem test/speedsys/ etc. to see how the computer works in general. If you say you have a P2/3 computer(s), install your drive in to that, install windows, then move the drive over.
So much to try still, don't give up on it yet! Older computers are just different and need relatively old hardware/methods to work.
Since you say it randomly locks up at DOS prompt, I'm inclined to think the CPU or memory has failed/is failing. If you have other CPU/mem to test, that would be good to try as well. Maybe the cache is failing, try disabling. Boards are TANK-Y, and should be the LAST suspect.
Getting a POST card installed could help, as well. It might set codes when the computer locks-up.
Reply 17 of 40, by dionb
Which CPU are you currently using? If you're not already at 50MHz FSB/mem clock with that K5, try underclocking to both de-stress CPU and clock the RAM lower. If possible I'd suggest also testing with a P54 (Pentium) just to be sure there's no strange compatibility thing going on.
Reply 18 of 40, by coxilerio
Any cpu i try same result
Daily drivers:
Retro Builds:
Reply 19 of 40, by coxilerio
Any psu ram vga keyboard hdd cd drive same results
Daily drivers:
Retro Builds:
