First post, by raerek
Please help me with a strangely (non)working 486 and CF to IDE combo.
The hardware used:
The 486 is a DEC PC LPV 425 SX with an Intel DX2-66, (motherboard here: https://theretroweb.com/motherboards/s/dec-decpc-lpv). When turned off, BIOS settings are kept, but RTC stops (although time is not lost even after weeks being switched off). No cache memory.
CF to IDE looks like this Re: CF to IDE compatibility .
Using a SanDisk 512MB card.
What works:
BIOS detects card (HDD) cylinders/heads/sectors correctly (when transferring the CF to IDE to a Pentium 1, it detects the same parameters).
fdisk, fdisk /mbr, format c:, format c:/s all run correctly, without errors.
What does not work:
sys c: makes the computer seemingly freeze: CF to IDE LED lights up and stays so forever, command does not return, Ctrl+Alt+Del works.
Norton Disk Doctor begins the test sequence and runs the first tests, but freezes the same way as "sys c:" when "Reading directory structure". Same when doing surface test. Same when running Norton Diskedit, but only when opening the "HDD" in "logical" mode, when opening raw, I can edit the disk and save the edits.
Same freezing when trying to boot after a successful format c: /s.
Same freezing when trying to reformat c: i. e. format the already formatted c:, but all goes well if I first delete and recreate the partition in fdisk.
Tested with both Standard and LBA modes.
Even more strange:
When doing a format c: /s in the 486 and then transferring the CF to IDE to the afforementioned P1, it boots with no problems.
All the same story when using an SD card to IDE adapter.
HELP ! (Pretty please.)
Reply 1 of 7, by weedeewee
Considering you have norton disk editor. Could you try the following.
Use diskedit to clear the first 64 sectors of the flash card while in the pentium & REBOOT and then do the fdisk, format /s, etc steps.
Let us know if it changes anything.
thanks.
edit:
and since you have diskedit you could look at both a working & non working cf layout and try to figure out how they differ.
comparing bios parameters vs partition table parameters seems a good start.
Do not ask Why !
Reply 2 of 7, by raerek
weedeewee, thanks for the answer
Tried the following:
- clearing up first 64 sectors on the pentium, all zeros
- reboot
- fdisk, format, sys c:, boot - works
- clearing up first 64 sectors on the pentium again
- transferring CF 2 IDE to 486
- still no joy, same old symptoms
- sadness 🙁
Reply 3 of 7, by weedeewee
ok, I thought It could've been some misalignment issue but seems like it's more complicated.
so you have a clean CF card in a 486
then you fdisk & format /s in the 486 and get no errors but you can't boot from the CF card in the 486 nor can you do any further operations from within dos on the partitioned CF card in the 486 though diskedit in direct/raw mode does work.
additionally the CF card, while partitioned & formatted in the 486, does boot int the pentium.
Is this summary correct?
I would swear i've seen similar issues pass by here on the forum though F me I can't find a quick solution to it.
Do not ask Why !
Reply 4 of 7, by douglar
Sounds like you may have a buggy bios that can’t handle the geometry of your CF device.
I’d try replacing your BIOS int 13h on your 486 as the next troubleshooting step. You can do that by upgrading the bios for your motherboard, adding an XTide universal bios option rom, or installing ez drive disk overlay. https://www.vogonsdrivers.com/getfile.php?fileid=1900
EZ drive might be the simplest thing to try as a diagnostic step. It will check out your device for you during the installation and warn you if it sees unexpected hardware behavior.
Reply 6 of 7, by raerek
douglar wrote on 2025-05-25, 02:40:
Thank you, will try them and report back.
Reply 7 of 7, by clownwolf
My advice is always have multiple models for each component. Sometimes things work out just by changing the parts. Do you have any other cards or adapters to use?
For example, only 1 model of CF adapter works on my Socket 8 motherboard. The others just wont read any cards.
Then only 2 out of 7 different CF card models works. The rest of the cards are not being identified, or hangs when being read, or crashes during W98 installation.
While on my P3B-F Slot 1 Motherboard, all CF adapters works fine, and all 7 CF card models can run W98 perfectly.
