Lualb wrote on 2025-05-23, 16:59:
Oh wow, you're right, haha, old developers and their tricks. Anyway, I'll keep trying, since I'm a big fan of Windows 3.1X to this day !
Hi there, me too! I like Windows 3.1, it's what I had running on my hot-rod 286 PC in mid-90s.
It was a 12 MHz model, ATI VGA Wonder, 4MB RAM, 80MB Conner HDD, 3,5" floppy, ProAudioSpectrum 16 with SCSI CD-ROM drive (Sony),
a handy scanner, HP LaserJet Plus, 33k6 Creatix modem, Genius mouse..
I also had a radio receiver for a time signal station (DCF-77) that connected to serial port. The magic wasin the software, though.
The receiver dongle was just receiving the pulses from the radio signal and passing it to a serial port pin.
Anyway, it was interesting to run the DOS application and see the decoding happen (there was a test program).
Windows 3.1 software was included, too. Here's an example of such a dongle:
https://www.youtube.com/watch?v=0JU_Ufovf9w
https://www.youtube.com/watch?v=vzUTV66A_V8
My copy of Windows 3.1 was running in Standard-Mode all the time, of course.
So no 386 Enhanced-Mode fun, sadly. DOS was MS-DOS 6.20..
But back to FreeDOS. I think you can use Himem.sys/EMM386 that comes with Windows 3.1x.
I know it's not ideal, but it's a workaround. Maybe they can be added to FreeDOS start-up menu.
The only important thing is using a FreeDOS kernal that's okay with Windows 386 Enhanced-Mode.
PS: Back in the 90s, when OS/2 was being advertised on TV, the host/moderator said that Novell DOS 7 is a fine DOS he likes.
And I think that wasn't a lie, he could have advertised IBM's own PC DOS 7 instead, but didn't.
Novell DOS 7 had great multitasking and memory managment (32-Bit multitasker; supported by PC GEOS).
It also had built-in networking (DOS/Windows 3.1) since it was 1994 and Novell had to compete with Windows for Workgroups.
So I think that DR DOS, which Novell DOS was based on, isn’t bad.
It's worth a try. Maybe to "borrow" parts of it or use it as a basis for DOS applications.
Unfortunately, I haven't really used later DR DOS myself yet. I once had a demo, though, Caldera DOS.
PS: PTS-DOS or Paragon DOS has a simple network driver for Windows 3.1x included.
It's not the best (stability issues), but maybe "fun" to play with.
In an emulator with a virtual network, at least.
PS: Using 386Max isn't bad, either, I think.
The commercial memory managers supported most if not all of the standards.
