Reply 40 of 49, by Jo22
- l33t++
BitWrangler wrote on 2023-01-28, 03:59:You've got me wondering what happens if you stick one of those 14.375ish Mhz crystals in there, whether it synchs on a TV or video monitor. Then maybe it has overscan?? IDK
My head is also going toward the simpler Amiga scandoubler plans and the stuff Grant Searle has done for composite display, using atmels, where maybe it could intercept the signal digitally then videofy it.
These are some interesting thoughts! 😁 👍
Since MDA/MGA are 1-Bit in its simplest implementation (pure mono video, omitting intensity for now), an A/D and D/A conversion for TTL<->Video might be possible without so much trouble.
I mean, a framebuffer in its simplest form (holding a 1:1 bit pattern of zeros and ones) would do. Timing/sync are a different story, perhaps, needing some dedicated glue logic.
But I'm optimistic the process of "digitizing" would very well be possible with little code. CGA would be more complex, at least in 4 colour modes, I guess.
Speaking of Arduinos/Atmels, here's something interesting:
External RAM with Atmel: https://spritesmods.com/?art=avrcpm&page=2
Compsoite (VBS, actually) with Arduino/Atmel 328p: https://nootropicdesign.com/video-experimenter/
