Tiny Vortex86-based DOS gaming PC - weeCee
Reply 1040 of 1106, by Will have had
vanfanel wrote on 2025-05-28, 12:43:
On a related note, to get perfect compatibility with games needing EMS on any computer built around the Vortex86 DX, use JEMMEX instead of HIMEM.SYS+EMM386, like this:
DEVICE=C:\DOS\JEMMEX.EXE X2MAX=32767 X=E400-EBFF
That makes the most hard-to-get EMS games to work, including Aladdin, Realms of Arkania II, Elder Scrolls: Arena, Lemmings 2, etc... All the hard ones work flawlessly!
Including, it seems, Wing Commander 3 (now it fails the way it did in Windows, at least).
@Mu0n have you tried JEMMEX instead of HIMEM?
Reply 1041 of 1106, by vanfanel
snipe3687 wrote on 2025-05-28, 13:29:
- I have a BOM but not a component placement map or anything. I suppose I could work something up for that. I always hand assemble so I didn't really think of that.
- yep the front and back plates were designed specifically for this build so they should fit just fine.
I know it's asking you to work "for free", and I am embarrased to do so, but please, if you can, inlude a placement map too: I lack the abilities or equipment for hand assembling.
I was about to order the original WeeCee design pre-assembled at PCBWAY (that's why I was talking to Rasteri about it) but now that your fork is ready, I would prefer to have the USB-C connector.
But, without the placement map, I can't order it because I wouldn't be able to assemble it.
Reply 1042 of 1106, by snipe3687
vanfanel wrote on 2025-05-30, 09:00:
I know it's asking you to work "for free", and I am embarrased to do so, but please, if you can, inlude a placement map too: I l […]
It's not work when you are having fun! I will see what I can do.
Also, I don't mind assembling one for someone myself if they wanted to pay for all the parts and some of my time for the assembly. Just throwing that out there.
Reply 1043 of 1106, by Mu0n
Will have had wrote on 2025-05-29, 18:04:
instantly bombs with a conflict, I'm afraid:
1Bit Fever Dreams: https://www.youtube.com/channel/UC9YYXWX1SxBhh1YB-feIPPw
AnyBit Fever Dreams: https://www.youtube.com/channel/UCIUn0Dp6PM8DBTF-5g0nvcw
Reply 1044 of 1106, by Mu0n
I modified the JEMMEX parameter address range to the next 2k and it all worked out. Not sure what's recommended or forbidden in those choices, but I was able to go through the installer and launch the game!
thanks for the suggestion, that's a good tool from the freedos world.
Reply 1045 of 1106, by vanfanel
Mu0n wrote on 2025-05-31, 11:00:
What's your exact JEMMEX line, please? Just to be sure 😀
Reply 1046 of 1106, by Mu0n
vanfanel wrote on 2025-06-01, 10:31:
it's just yours, but +2048 (or +0x800), so:
DEVICE=C:\DOS\JEMMEX.EXE X2MAX=32767 X=EC00-F3FF
Reply 1047 of 1106, by vanfanel
Mu0n wrote on 2025-06-01, 18:53:
Ok, thanks! 😀
Reply 1048 of 1106, by vanfanel
@snipe3687: Any news with regards to the placement map file, please? I'd really like to order improved the WeeCee Redux board along with some friends at PCBWay or similar service, and it's needed to be able to do so 😀
Reply 1049 of 1106, by snipe3687
sorry for the delay! if you look in the PCB.C folder on github there should now be a folder called pcbway_production that has the position file. hopefully that works.
Reply 1050 of 1106, by vanfanel
snipe3687 wrote on 2025-07-09, 20:13:
Yay! Thanks!!! Time to get my definitive Vortex86DX based DOS PC! 😀
Will try to place the order at PCBWay ASAP!
Reply 1051 of 1106, by vanfanel
@snipe3687 After putting the order in PCBWay, they ask me this:
"As shown in attached screenshot1, there are vias on pad. Could we fill them with resin? It can avoid poor soldering when assembly. But there will be extra fee. And we also can fill all vias.
Extra fee is same. Do you want to fill vias on pad or all vias?"
And this is the screenshot in question:
The attachment 1.png is no longer available
I told them to fill all vias. Is that OK?
Reply 1052 of 1106, by RayeR
Generally via in pads and filled vias are advanced technologies that increase price, the same in JLCPCB. It's critical for automated soldering - reflow via paste and stencil. If you solder it manually you can handle unfilled vias without problem, just put more solder to fill the holes...
Reply 1053 of 1106, by vanfanel
RayeR wrote on 2025-07-11, 14:54:
I am not soldering it, I will be getting it ready to use from PCBWay (I am a DOS guy, not an electronics guy),
So, since they will use automatic soldering, telling them to fill the vias is the right answer?
Reply 1054 of 1106, by snipe3687
ah yeah, I usually do them by hand so that's normal. you can fill them as they will get filled with solder anyways. the only downside is SOMETIMES they can tombstone during the automated process that's why they don't do it as a best practice, but I've had it done before and it was ok. if it becomes a real problem, I can modify the schematic to remove them from the pads and update the github.
Reply 1055 of 1106, by vanfanel
snipe3687 wrote on 2025-07-12, 21:13:
Removing them would be the best option indeed, the fees for filling the vias are very high, it almost doubles the price of the board in PCBWay.
I will wait for the modified schematics then, many thanks!
Reply 1056 of 1106, by snipe3687
thanks for hanging in there. also sorry to Rasteri for hijacking this thread a little bit.
that being said, I made the adjustments and uploaded to github. try it again. you shouldn't have any issues now 😀
Reply 1057 of 1106, by vanfanel
snipe3687 wrote on 2025-07-14, 20:53:
Thanks! There are some other issues with the BOM: some of the parts seem to be "out of stock" or have wrong identifiers.
I'm attaching a modified BOM XML so you can see for yourself, in case you can also adjust that.
I specially fear for the CS4237B availability (that was why I was trying to order it time ago), and I believe the SOM304RD-VI should be removed from the BOM since it should be provided by us the final users.
Reply 1058 of 1106, by rasteri
All good, your weecee variant is the one I'd recommend people build now 😀
Reply 1059 of 1106, by snipe3687
vanfanel wrote on 2025-07-15, 07:25:
Thanks! There are some other issues with the BOM: some of the parts seem to be "out of stock" or have wrong identifiers. I'm att […]
The CS4237b is going to be old stock but you can still buy them from places like UTsource. sorry I usually dont have them built so im sure there's some errors. will get back to you!
