First post, by stuckunderhere
okay so I followed these steps: http://www.dosbox.com/wiki/Basic_Setup_and_In … ation_of_DosBox
with the CD-Rom version of it... but it still wouldnt work. And now whenever I try to play a game, it says theres an error and its copyrighted or read-only (sorry its all in french and thats the best i can translate to). How can I go back to my original settings?
Z:\>MOUNT D D:\ -T cdrom
MSCDEX installed.
Drive D is mounted as CDRom D:\
Whats the opposite of this???
-Sarah-
Reply 1 of 4, by wd
Rank DOSBox Author
DOSBox Author
close dosbox and restart it
Reply 2 of 4, by stuckunderhere
I'm not even using dosbox no more and it still says the same message. Did I do something permanent to my Drive when I followed those instructions or is it supposed to be just for the time its being in use on dosbox til I close it??
Reply 3 of 4, by wd
Rank DOSBox Author
DOSBox Author
No, dosbox doesn't change anything at your system configuration.
Restart your pc and see if it still occurs without dosbox loaded.
Reply 4 of 4, by stuckunderhere
ok thanks 😀
