shevalier wrote on 2025-06-03, 08:05:Its not Schottky, its ultrafast diod.
Although the snubber on the PFN is set up well and there are no voltage surges on the diod […]
Although the snubber on the PFN is set up well and there are no voltage surges on the diodes.
100 V Schottky diodes work reliably at +12V rail.
But 2 assemblies of ultrafast diodes in parallel give a greater effect than one Schottky diode.
This way you not only change the efficiency, but also redistribute the energy.
If you remove the second ultra-fast diode on the +12V rail and replace on the +5V Schottky rail with a modern parallel one, you will get a redistribution of about 1-3%.
Somewhere from 12.8 to 12.5V.
Fine-tuning the existing design.
Yeah, my mistake and that's what often happens when I'm doing a couple of similar things simultaneously. Those SF1603G diodes on the +12 V line (BD4 and BD5) are not schottky and now I have two SF1608G from my previous idea to change them with suitable diodes with higher V-drop (I got SF1608G).
Off: And now is a perfect time to express my thanks to the moderating script, that took away my "edit button" for "good" 😁
Resistance is 51 Ohm - so the readings will be good without any load.
Hmmm. But for the "good readings" I have to put back the load into the shape from the diagram you've linked - you know what I mean. I think, someone else also mentioned before, that R41 and R42 are some kind of "dummy load" resistors when PSU is starting. And they are exactly this - a "dummy load" resistors as one end of each of these two resistors is connected to ground, the other - to corresponding output voltage line. So if I could force the PSU to produce "good voltages" wit just this "small internal dummy load", it also has to produce "good voltages" with more external load on +12 V line (HDD, CD-ROM, FDD - there are no other serious consumers on +12 V line for the old systems, right?).
shevalier wrote on 2025-06-03, 08:05:For normal PC operation, the load on +12V should be 1.5~2 or more amperes.
And this is 6 Ohm 25 Watts.
https://imrad.com.ua/user […]
https://imrad.com.ua/userdata/modules/product … HS-10-05.45.pdf
On a radiator with a fan.
Or an assembly of 5-6 pieces of 10 watts each.
https://imrad.com.ua/userdata/modules/product … ssives-CR-W.pdf
Wire wound resistors are a must.
If you use a 10W resistor rating at 10W power consumption, it will be about 100 degrees Celsius (boiling water).
Thus, you represent the heat death of the universe, senselessly converting electricity into heat. 😀
Six pieces of 1 Ohm 5 W resistors (the non-ceramic ones are small enough) in series with no radiators on +12 V line sounds good for the revisited additional internal PCB idea. 30 W seems to much for dummy load, probably 20 W will do the job when PSU is used with old ATX/AT systems. I can try a combination of two 1 Ohm 5 W + two 2 Ohm 5 W resistors in series or... I'd better off to try the R41 mod with the additioanal resistors on a PCB.
And of course I can always go back to my not so clever idea with changing of BD4 and BD5 (SF1603G) diodes to SF1608G diodes, but this is not a flexible solution.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
