Reply 20 of 25, by bloodem
Good point! Now that you mentioned it, I just realize that, in fact, I had downloaded w6163v27.exe a few weeks before getting my hands on the board.
However, I totally forgot about it and I just went with the MSI website download once I started playing with it.
Will try it and get back to you.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 21 of 25, by bloodem
So, yeah, just flashed it and the FSB frequency set in the BIOS now matches the actual FSB frequency. Other than that... things look the same: did a few tests, it's stable as before.
Thanks for the heads up!
Reply 22 of 25, by maxtherabbit
this is a BX board right? make sure your AGP card is stable at 88MHz...
Reply 23 of 25, by bloodem
It is stable (and I have four other 440BX boards which are all stable at 133 MHz FSB with 89MHz AGP, when using nVidia cards).
I'm using GeForce 3 Ti 200 / GeForce 4 Ti 4200 on these boards (a "bit" overpowered, I know). But I also tested cards like GeForce 2 GTS / GeForce 2 Ti and didn't see any instability.
Reply 24 of 25, by maxtherabbit
ahh yeah the Nvidia cards handle 88MHz AGP like a champ, ATI no so much
Reply 25 of 25, by shirka
Thank you, I applied BIOS 3.10 to MS-6163 v1.0 board
Tualatin installation was successful.
