PSU for 2006 Build
First post, by Fredelicious
Bit stuck on what I can use for a PSU. Ideally something a bit more modern and reliable rather than something period correct.
Specs:
Intel Pentium 4 519K 3.06 GHz
Gigabyte GA-8I945PL-G
4x512 MB Kingston DDR2 400MHz
GeForce 6800 256MB
500GB HHD
Cd drive
Various fans
Maybe a floppy drive.
Having done a calculator, says 350w should be more than enough.
Let me know what you think.
Many thanks!
Reply 1 of 10, by RetroPCCupboard
One thing I would be careful of is to check that the PSU has 20+4 ATX power connector. If it is 24 pin then it most likely won't fit your motherboard. Increasingly I am finding modern PSUs don't support 20 pin power.
Reply 2 of 10, by Fredelicious
RetroPCCupboard wrote on 2025-06-08, 08:10:
I think this Motherboard has a 24 pin connector and a 4 pin P4
Reply 3 of 10, by RetroPCCupboard
Fredelicious wrote on 2025-06-08, 08:14:
Ah, I looked on the gigabyte website before I posted and it looked like 20 pin. I see now that there is a plug in the last 4 pins:
The attachment SmartSelect_20250608_095315_Chrome.jpg is no longer available
Reply 4 of 10, by Ydee
Even on a 24pin connector, 4 pins tend to be removable (20+4 pin), so it goes into a 20-pin on mainboard.
Reply 5 of 10, by RetroPCCupboard
Ydee wrote on 2025-06-08, 10:21:
If it says 20+4 then yes, for sure. But if it just says 24 pin, I wouldn't bet on it
Reply 6 of 10, by Ydee
Then:
Reply 7 of 10, by fosterwj03
I like to try to double the power available to the power required. If you're system could draw 350W, than I'd use a 700W PSU. It's a little overkill, but you won't need to worry if you upgrade any of the components later.
You could go with 650W as well, but I don't see a lot of price difference between the two in my market for good quality brands.
Reply 8 of 10, by Fredelicious
fosterwj03 wrote on 2025-06-08, 13:10:
When I did the online calculator, it said a 350w would be about 50-60% of the capacity. I don't know if that seems low or I put in the wrong info. Or if that's just 2006 stuff.
I'll have a look again.
Reply 9 of 10, by fosterwj03
Fredelicious wrote on 2025-06-08, 16:24:
Given the components, 300W of possible power draw sounds about right. You'll want a PSU with a bit more power to handle transient power spikes.
Reply 10 of 10, by 3dfx_fan
Qoltec ATX SilentLine PSUs are nice for retro PCs.
