Here's a release with high detail composite textures.
theelf wrote on 2025-06-08, 10:55:
Hi thanks!! look much much better with this wad. My 286 have 4mb of ram and i can upgrade to 16mb if need, then no problem about memory
Upgrading from 4 MB to 16 MB won't do anything for Doom8088.
Doom8088 uses the first 640 kB of memory for graphics that are shown in the current frame.
The memory above 1 MB is used as a RAM drive to store the WAD file. It will already fit if you have 4 MB.
When a sprite is needed but isn't in the first 640 kB, it's copied from the RAM drive to somewhere in the first 640 kB.
Thanks, i checked your github, and see jWadUtil but did not understand what to do, for example, Build: mvn verify ?¿?¿ i googled mvn, and look like related to something called Maven, then i check and too many downloads, and most of them are x64, im running XP 32bits, start looking for old versions... and get bored 😀,
jWadUtil needs Java 21 and Maven to build it. That won't work on a Windows XP 32-bit computer.
then i start looking other options, i found extendable wav editor that can edit wav without break for doom 8088
jWadUtil uses the same compression tricks as wadptr. Maybe it's incompatible with SLADE somehow.
One thing i was thinking is maybe possible to use mscdex to play audiocd, this in theory will not have any penalty in performance, just need to do a timer or something to repeat the track after the time, no need to check if audiocd stoped because each track have a fixed lenght
Interesting idea. I've put it on the to-do list.
theelf wrote on 2025-06-08, 18:26:Hi! sorry again, a question, how do you compile 240 and 120 modes in watcom? i can see a SH scripts, but no idea how to integra […]
Hi! sorry again, a question, how do you compile 240 and 120 modes in watcom? i can see a SH scripts, but no idea how to integrate this to the bat file. I tried
export RENDER_OPTIONS="-DFLAT_SPAN -DVIEWWINDOWWIDTH=240" in BWC16.BAT without luck
the regular 80x128 mode compile fine using watcom in Open windows, give multiple error in watcomm 11 in DOS
I want to compile the 240x128 mode to change some stuff, but anyway the watcom compiled exe is too slow compared with gcc one... something is wrong, like your build mode 80x128 15fps, in watcom is 8fps
thanks a lot
Add -DVIEWWINDOWWIDTH=240 to makefile.w16 after -DFLAT_SPAN. Optionally also add -DHIGH_DETAIL for high detail composite textures.
To improve the performance of the Watcom build, switch to branch feature/watcomassembly. It uses assembly for some rendering functions, just like the GCC build.
