kikendo wrote on 2025-06-14, 21:37:
darry wrote on 2025-06-14, 21:15:
Also, what model do you have? I have one of these http://www.tcocd.de/Pictures/Peripheral/Logit … ch/tcd26f.shtml , but use a newer marble (red ball) variant most of the time.
As I mentioned before, it's the very first Trackman that I have. it is often found in serial version, and that's what I got.
Maybe I'll get a PS/2 one if I can find and afford it.
Sorry, if I was unclear, I meant the model number. There have been a few Trackman products over the years, and it wasn't all that clear to me which one was the first and when it was released (mine seems to be from the mid 1990s). If you have a link you could share to an at least relatively authoritative and comprehensive source of information on the chronology of Logitech Trackman products, it would be helpful, IMHO.
EDIT: This site, which I linked to, http://www.tcocd.de/Pictures/Peripheral/Logit … /Logitech.shtml is nice but is far from complete. There are at least 2 products named "Trackman Stationary mouse", one of which is natively serial, and I suspect you have a squarer looking and likely older (1989ish) one also named "Trackman Stationary mouse", which I believe might be the original model ( T-AA1-4MD might possibly be the ADB variant of it). EDIT2: Most likely model T-CA1-9F , assuming https://en.wikipedia.org/wiki/List_of_Logitech_products is accurate on that point (it definitely is not exhaustive).
As for the serial switch box option I had mentioned, something like this https://www.industrialautomationparts.com/pro … 4-port-manual-1 (an example, not an endorsement or recommendation) should allow you to switch a serial mouse or trackball between multiple computers easily, if not automatically through your KVM switch.
That being said, I agree that getting a PS/2 trackball would be simpler, possibly cheaper and more seamless.
