nd22 wrote on Yesterday, 04:51:
So what do you think would be the most flexible socket A system?
Keeping in mind max performance for all games 2000 - 2004.
I should mention that, in my case, I only use this platform for DOS/Win98. For WinXP there are better alternatives out there.
Anyway, the ideal system in terms of flexibility would look something like this:
CPU: fast Barton (2800+ -> 3200+), converted to mobile with all multipliers unlocked up to 24x (allowing you to both find the overclock sweet spot and also downclock the CPU, in software, to as low as 3x multi).
MB: VIA KT133A motherboard with an ISA slot (Abit KT7A, Biostar M7VKD, etc). My favorite is the M7VKD, because it's a very solid, stable board + its BIOS already sets the 55h register to the correct value needed for controlling the mobile Athlon XP multiplier in software.
GPU: GeForce 4 Ti (the faster, the better). GeForce FX 59xx would also be fine (if you want even more speed in newer games), but it does have some issues with certain games in both DOS and Win98.
Audio 1: Audigy 2 ZS PCI
Audio 2: ESS ES1688 non-PNP ISA or similar.
Anyway, this type of system is simply amazing in terms of flexibility, you can basically play 99% of games released between 1980 - 2002.
Now, of course, if you are not interested in DOS at all, then there are much better options out there.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
