A few comments...
nd22 wrote on Yesterday, 05:08:
MOTHERBOARDS – as I tested only Abit boards and have everything that Abit manufactured for socket 462 my recommendations will be only Abit!
Well, i totally understand your point of view and why it makes sense to recommend something you have experience with, but... there are plenty of good boards out there. IMO for someone building such a system without strong personal preferences trying to find something specifically from Abit makes very little sense.
Tier 1: nforce2 ultra – BEST chipset for anyone wanting to assemble the ultimate socket 462 system! There are several versions available and the one you want is with the MCP – T Southbridge! There are nforce2 boards with MCP – RAID/GIGABIT Southbridge that lack the sound storm audio chip.
It is "nforce2 ultra 400", not "nforce2 ultra" (does not exist), "nforce2", or "nforce2 400". This is very important because motherboard manufacturers tend to throw words like "ultra" in just for good measure. "nforce2 ultra 400" is the only north bridge which supports 400FSB and dual channel. Regular "nforce2 400" is single channel, "nforce2" - dual channel but 333. It is really easy to get confused here so have to be careful. Even more confusing - it seems that some boards switched to "nforce2 ultra 400" (which is newer) from "nforce2" at some point, for example EPoX EP-8RDA i have has "nforce2 ultra 400" (i even removed the heatsink to confirm), even though all info i can find online shows it should have regular "nforce2".
Also SoundStorm only matters if PCI soundcard is not going to be used. If, for example, something from audigy series is planned - there is no point, integrated audio is going to be disabled anyway. Might as well pick one with sata ports - those from nvidia actually work well with any modern devices, unlike ones from via. And also do not require any drivers to work, unlike silicon image stuff. So very convenient.
MCP2-S/R and MCP2-GB also have 8 USB ports instead of 6 on MCP2/MCP2-T, which can be quite handy depending on case and needs.
I am pretty happy with EPoX EP-8RDA3I myself. 12V VRM, very nice monitoring and ability to fiddle with everything like all the frequencies, voltages, etc in bios, nforce2 ultra 400 north bridge... the only disadvantage is regular MCP2 southbridge so no sata and no soundstorm, but soundstorm would be useless for me anyway so no big deal.
Motherboard is one of those parts which does not affect performance as long as it works properly and has the same chipset (especially with no overclocking), so a lot of options here and a lot depends on personal preference.
RAM:
Tier 1: Corsair is the way to go if you want an Athlon XP 3200 or very tight timings.
I am curious who is actual chip manufacturer. I've had very good success with sticks from samsung myself, so perhaps that's another option.
I always prefer sticks from actual chip manufactures because this way there is way less lottery involved. With manufacturers like corsair who does not have their own chips you can get totally differen ram which works completely differently with the same name, which is annoying.
Trashbytes wrote on Yesterday, 07:48:
Im going to be real here .. its socket A .. Ram timings don't matter at all neither does IC manufacturer, any DDR400 will be fine, you are not breaking any records here and if its DDR400 you are using then you can tune the timings down substantially on pretty much any old stick of DDR400 if its running at a lower FSB than its rated for.
Have to be careful though, nforce2 is very picky. I have whole box of DDR1 and like 2/3 of it does not work properly on boards with this chipset. So sharing what tends to work more reliably can actually be very useful to avoid buying "few Kg of DDR1".
Timings... in my extremely limited testing i was not able to find significant difference between sensible values like 3-3-3-8-1, 2.5-3-3-7-1 and 2-2-2-2-5-1 on my system (if you use the force more voltage it is possible to make regular 3-3-3-8 DDR400 to work with 2-2-2-2-5-1 timings, at least some sticks).
