First post, by dionb
Recently got myself a little unexpected gem as part of the - a Biostar (?) MB-1433UIV. That's common enough (sold one myself a few weeks back) but this is revision 7, which means 3.3V and 4V supported, as is the Cx5x86. That makes it pretty much the ultimate VLB motherboard, which was exactly what I wanted. Better yet, apart from awful HDD support (chips for XTIDE on NIC already ordered) it works perfectly with my 5x86 and other stuff.
Just one issue: CMOS settings.
The old barrel battery has been removed without visible damage. The board has a 4-pin header (JP8), which needs a jumper over 2-3 if 'internal' battery is used, otherwise an external battery can be connected to pins 1 and 4, with 1 being +. So that's what I'm trying to do:
3x AAA rechargeable batteries, fully charged (measured 3.78V on the connector pins), red positive connected to JP8 pin 1, negative connected to white (black was on wrong pin...) JP8 pin 4.
Should work? Well, it doesn't. After a few minutes without power, all settings gone. Tried inverting polarity. Same again.
Any suggestions how to get this board to remember what I tell it?
Reply 1 of 10, by Baoran
I thought there should be more than 3.78V in those batteries (1.5V each). I have a motherboard that has similar connector and there is 5V in the battery connector so I always assumed I would need at least 3x1.5V which would mean 4.5V there. With 1.26V each it seems like the batteries are empty or close to it.
Reply 2 of 10, by dionb
NiMH rechargeable AAA batteries have a nominal voltage of 1.2V, not 1.5V (no-rechargeable alkalines) so actually at 1.26V they're over spec.
I assumed the original barrel was a 3.6V barrel, but if the CMOS needs 5V, that might explain something. Tomorrow I'll try with some alkalines for 4.5V - if they do seem to hold settings, I'll add a diode and stick with that.
Reply 3 of 10, by Baoran
At least my motherboard that had similar connector had 5V between pins 1 and 4 when checked using multimeter even if originally it had lower voltage barrel battery. Normal AAA batteries might work as long as it doesn't try to recharge them like my motherboard does.
Reply 4 of 10, by TheMobRules
I have that motherboard, I first tried a 2xAA battery holder (3V) but CMOS would not keep time and settings when turning off. Using 3xAA alkaline batteries (4.5V) did the trick.
I think there is a bigger voltage drop when using the external battery connector vs. the barrel battery terminals due to some additional diodes, so the CMOS/clock chip may not be getting enough voltage with the NiMH...
Reply 5 of 10, by dionb
Alternative might be to solder in a few pins where the original battery was connected...
You say the bigger voltage drop is due to additional diodes. That suggests it should be possible to use alkalines (or other non-rechargeable batteries) without additional diodes. I'll check that out this evening.
Reply 6 of 10, by Doornkaat
The external battery pack often had another voltage than the onboard rechargeable battery. If 3.6V doesn't do the trick the PCB is likely designed for a 4.6V external battery.
Reply 7 of 10, by dionb
Looks like that was it. Replaced the 3x 1.2V rechargeables with 3x 1.5V alkalines and it now holds its settings!
Also looks like there are diodes in place to prevent charging of the external battery, so I can probably just leave it like this 😀
Reply 8 of 10, by 9646gt
dionb wrote on 2019-09-30, 17:33:
Did you have to bridge pins 2 and 3 to “close” them? Or just 4pin connector with positive on on 1 and negative on pin4? It does NOT try to recharge them correct?
Reply 9 of 10, by dionb
9646gt wrote on 2025-06-14, 01:15:
That was 6 years ago... but no, you specifically don't want to bridge 2-3 as that connects to the onboard battery and the charging circuit. 1-4 have diodes, so discharge only. Originally you'd have had a battery pack with a 4-pin connector to slide over pins 1-4, but only 1 and 4 are connected. So that's what you want to do too.
Reply 10 of 10, by 9646gt
dionb wrote on 2025-06-14, 09:18:
I can’t thank you enough for taking the time to respond to this! I’ve already got battery holders ready to go so now to get to work 😀 thank you again!
