Reply 1020 of 1050, by Trashbytes
- Oldbie
nd22 wrote on 2025-06-13, 15:07:Trashbytes wrote on 2025-06-13, 15:01:Archer57 wrote on 2025-06-13, 13:31:A few comments... […]
A few comments...
Well, i totally understand your point of view and why it makes sense to recommend something you have experience with, but... there are plenty of good boards out there. IMO for someone building such a system without strong personal preferences trying to find something specifically from Abit makes very little sense.
It is "nforce2 ultra 400", not "nforce2 ultra" (does not exist), "nforce2", or "nforce2 400". This is very important because motherboard manufacturers tend to throw words like "ultra" in just for good measure. "nforce2 ultra 400" is the only north bridge which supports 400FSB and dual channel. Regular "nforce2 400" is single channel, "nforce2" - dual channel but 333. It is really easy to get confused here so have to be careful. Even more confusing - it seems that some boards switched to "nforce2 ultra 400" (which is newer) from "nforce2" at some point, for example EPoX EP-8RDA i have has "nforce2 ultra 400" (i even removed the heatsink to confirm), even though all info i can find online shows it should have regular "nforce2".
Also SoundStorm only matters if PCI soundcard is not going to be used. If, for example, something from audigy series is planned - there is no point, integrated audio is going to be disabled anyway. Might as well pick one with sata ports - those from nvidia actually work well with any modern devices, unlike ones from via. And also do not require any drivers to work, unlike silicon image stuff. So very convenient.
MCP2-S/R and MCP2-GB also have 8 USB ports instead of 6 on MCP2/MCP2-T, which can be quite handy depending on case and needs.
I am pretty happy with EPoX EP-8RDA3I myself. 12V VRM, very nice monitoring and ability to fiddle with everything like all the frequencies, voltages, etc in bios, nforce2 ultra 400 north bridge... the only disadvantage is regular MCP2 southbridge so no sata and no soundstorm, but soundstorm would be useless for me anyway so no big deal.
Motherboard is one of those parts which does not affect performance as long as it works properly and has the same chipset (especially with no overclocking), so a lot of options here and a lot depends on personal preference.
I am curious who is actual chip manufacturer. I've had very good success with sticks from samsung myself, so perhaps that's another option.
I always prefer sticks from actual chip manufactures because this way there is way less lottery involved. With manufacturers like corsair who does not have their own chips you can get totally differen ram which works completely differently with the same name, which is annoying.
Have to be careful though, nforce2 is very picky. I have whole box of DDR1 and like 2/3 of it does not work properly on boards with this chipset. So sharing what tends to work more reliably can actually be very useful to avoid buying "few Kg of DDR1".
Timings... in my extremely limited testing i was not able to find significant difference between sensible values like 3-3-3-8-1, 2.5-3-3-7-1 and 2-2-2-2-5-1 on my system (if you use
the forcemore voltage it is possible to make regular 3-3-3-8 DDR400 to work with 2-2-2-2-5-1 timings, at least some sticks).Hmm yes .. forgot about about that abomination well not abomination but its has its quirks, its about the only exception here where you do have to go hunting for sticks that it likes, I feel this is a nVidia issue as a lot of their chipsets had this problem ..even the 775 nforce chipsets had issues with DDR2/3 compatibility.
This is the only drawback of the Abit AN7. Until I used Corsair sticks I spent days testing I can not remember how many modules and none of them worked! Even with increased voltage none of them worked! Than I bought a Corsair stick and it worked!! From that moment I bought a few lots of Corsair modules and all of them work in my nforce boards.
IIRC nVidia never actually fixed the issue either and did what they normally do ...turned tail and left the scene which is what I expect they will do with their consumer gaming GPUs very shortly. AI is too lucrative for them to let consumer GPUs keep eating into their AI hardware profits. For the best really they seem to have really just phones it in for the RTX 5000 GPUs with little to no innovation or improvement to their raster ops, though if you LOVE AI fakery they have that in spades with their DLSS MFG.
Its not real frames but that doesnt matter right.
All this talk of Socket A makes me want to dig out my MSI KT880 3200+ Barton board and throw the 5900 XT I just got at it, its a nice setup. I wonder how a 6800 Ultra would run in it and if the 3200 can feed it fast enough.
