Reply 29740 of 29750, by PD2JK
Upgraded the Coolermaster HSF on my Athlon 700, almost the same cooler, but 60 grams heavier and a bit higher. That should keep it 1°C cooler... 😏
The attachment DSC_4552.JPG is no longer available
Reply 29741 of 29750, by Trashbytes
Spent the day doing more testing of my GPUs in storage and now I have two dead Voodoo3 PCI cards, both just black screen and cause the PC to beep. So either its dead bios or possibly the voltage regulators, not sure how to test and replace them but it cant be ay harder than recapping an entire motherboard.
So ill set them both aside till I have time to operate on them ... or I find someone who knows what they are doing and get their advice.
Kicking myself too since both are high end V3 cards, one is a 3000 the other is a Compaq OEM 3500 with a normal VGA port so its worth repairing.
Also tested my Voodoo5 and it works ok but needs new fans as the OG ones have finally bit the dust, anyone have suggestions for good replacements that don't require weird attachment solutions 😁
Reply 29742 of 29750, by xa3d
[/quote]
Ok, I've updated more than a dozen things I've been "meaning to" for a bit...
(including the latest DDLINK source code)
[/quote]
Thx! Much appreciated.
Reply 29743 of 29750, by PcBytes
Unfortunately not much. I got some kind of awful flu that's constantly keeping me sick, in the sense that I have nausea at all times.
However:
- one of my Slot A mobos died to a shorted CPU
- finally got the MSI MS-6167 running
- may swap the HSF from the shorted CPU (700MHz Thunderbird) on the 700MHz Pluto.
Reply 29744 of 29750, by Trashbytes
PcBytes wrote on 2025-06-14, 17:36:
Unfortunately not much. I got some kind of awful flu that's constantly keeping me sick, in the sense that I have nausea at all t […]
However:
Ouch, thats gotta hurt losing a Slot A Athlon and board.
Reply 29745 of 29750, by PcBytes
Trashbytes wrote on 2025-06-14, 17:38:
However:
Technically just the board. The CPU seems to have been DoA, at least upon verifying the backside of the CPU core after the damage was done - a short so massive it acted as a short SO HUGE on the MB VRM it even made it shoot some solder balls, god knows only how.
Reply 29746 of 29750, by Trashbytes
PcBytes wrote on 2025-06-14, 17:51:
However:
How many AMPS do you want .. ALL OF THEM !
Reply 29747 of 29750, by appiah4
Spent two days unsuccesfully trying to troubleshoot a nonworking Panasonic 475-3 5.25" drive. The thing gets power but its head never initializes/moves and it always gives Floppy drive errors at POST 🙁
Reply 29748 of 29750, by Nexxen
appiah4 wrote on Yesterday, 12:26:
Could it be a dead component?
Post pics, you never know 😀
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Reply 29749 of 29750, by Trashbytes
Trashbytes wrote on 2025-06-14, 13:38:
Spent the day doing more testing of my GPUs in storage and now I have two dead Voodoo3 PCI cards, both just black screen and cau […]
So . .I decided to throw both of these onto a system that had a older Athlon XP compliant PSU . .57 Amps on the 5v rail and 37 on the 3.3 and the EvilKing Voodoo3 PCI card fired right up and ran happily ..Im like WTF .. why, it point blank refused to run in three other boards with two different PSUs.
So it seems that at least one of the two Voodo3 cards works ok it just needs a decent PSU, the Compaq V3 however is dead .. doesn't even get recognized by the BIOS or Windows as even being inserted in the board. Checked with a few tools that can read the PCI bus and the card is not there at all, the card itself does get warm, so that's something I guess, ill poke the voltage regulator on it to see if its working ok but right now its DOA .. turns out its not a 3500 as I was lead to believe but a 2000 so I'm not going to sweat over it if its not repairable.
Reply 29750 of 29750, by appiah4
Nexxen wrote on Yesterday, 12:54:
Good idea, will do.
