I need a new monitor
First post, by c0burn
Looking a modern monitor that does the following:
Must support refresh rates 60hz, ideally has gsync/freesync and high refresh
Must support forcing 4:3 on all content (so I can use with an OSSC)
There's a Philips mentioned on here but it's only 60hz.
I like my OSSC but its only perfect when the above two features exist.
Any ideas?
Reply 1 of 12, by darry
c0burn wrote on 2025-06-14, 19:55:
Looking a modern monitor that does the following: […]
Any ideas?
I use a Philips 252B9. Mine definitely handles at least up to 75Hz without skipping frames.
Re: Purchasing a 4:3 LCD for DOS/DOSBOX/MISTER/OSSC games?
According to the manual, https://www.documents.philips.com/assets/2023 … 02000c472f0.pdf , up to 1920x1200 at 75Hz is supported (works without frameskip according to my tests), but 1920x1200 at 60Hz is "optimal". I suspect that has to do with this monitor using a 6bit+FRC IPS panel (potential for visual artefacts like texture dithering on some colors) at higher refresh rates).
Reply 2 of 12, by zuldan
My Asus ProArt PA248QV works great. It auto switches to 4:3 as long as the signal is coming through the HDMI port.
Reply 3 of 12, by c0burn
darry wrote on 2025-06-14, 21:01:
I use a Philips 252B9. Mine definitely handles at least up to 75Hz without skipping frames. Re: Purchasing a 4:3 LCD for DOS/DO […]
Any ideas?
Does the 4:3 setting stick?
zuldan wrote on 2025-06-14, 21:08:
Many monitors interpret VGA 320x200/720x400/640x400 as widescreen and can't force 4:3. Is this the case with this one?
Reply 4 of 12, by darry
Does it do so even in DOS, when displaying 320x200 mode 13h (line doubled to 640x400 by the VGA card) ? AFAIK, it does NOT.
Many monitors, including that specific one, AFAIK, only treat as 4:3 resolutions whose active pixel counts for the x and y axes have a 4/3 (1.33) ratio. I.E. 640/480=1.33 , so the monitor will "see" it as 4:3 , but 640/400=1.6 , so the monitor WILL NOT display it as 4:3. In other words, the monitor will assume that all modes have square pixels AND "deduce" the aspect ratio from active pixel count ratios for x and y axes, which does not work for 320x200 because it does NOT have square pixels.
You will not have encountered that issue IF you use the native HDMI or DVI output of most (probably all) Nvidia and ATI based video cards because, by default, those video cards, in DOS, upscale 320x200 mode 13h to a 4:3 square pixel mode resolution that is then pillarboxed into a 16:10 resolution (exact resolution will depend on monitor EDID and VGA BIOS logic, but often the monitor's native resolution), so the black bars on each side of the image will be generated by the video card.
If one uses a VGA card's analogue output and digitizes it with an OSSC, the resulting 640x400 resolution, sent over DVI/HDMI, will require a monitor that allows forcing 4:3 mode to have a proper 4:3 aspect ratio, which the PA248QV cannot do (unless newer revisions/monitor firmwares have added that feature), but the 252B9 and a few other monitors can do.
Reply 5 of 12, by darry
c0burn wrote on 2025-06-14, 21:16:
Does the 4:3 setting stick? […]
Any ideas?
On my 252B9, the forced 4:3 mode is persistent accross monitor power cycles.
For the PA248QV, see my response to Zuldan and the thread link in my first response to you. The PA248QV is specifically discussed there.
Reply 6 of 12, by c0burn
darry wrote on 2025-06-14, 21:50:
Many thanks for all you insightful and helpful comments. I think this is going on my shopping list!
Reply 7 of 12, by darry
c0burn wrote on Yesterday, 07:20:
Unfortunately, it appears it is discontinued, I have just now realized looking at the Philips website, though I still see some for sale. Maybe others here will be able to suggest easier to find and possibly even better options.
IMHO, the most significant difficulty in finding a decent monitor is the frequent lack of a forced 4:3 mode. This is something that might be made moot with an OSSC Pro or one of the Retrotink models, for example, but those are expensive and I personally cannot confirm that either of those could actually be effective for that (I did read more about the OSSC Pro while it was still in dev and it seemed promising, but I have not checked up on it further since due to its cost and the fact I have a working setup already).
Reply 8 of 12, by c0burn
darry wrote on Yesterday, 10:22:
They are thankfully newly available still on Amazon UK, so we have stock here at least 😀
I agree, if the OSSC Pro can force 4:3 it would be a lifesaver.
Reply 9 of 12, by c0burn
I suppose what would be really interesting to me is a 1440 or 4k monitor that does high refresh and allows forcing 4:3. I wonder if other Philips models have the same software so will also work.
Reply 10 of 12, by jh80
I use a Dell S2721DGF with my OSSC and it is absolutely great. It's 1440p and it supports 144 Hz over HDMI (165 Hz over DP), FreeSync/GSync, and has forced 4:3 that persists.
Caveat: it's a few years old and might be discontinued, but still seems available in the US at least. I wonder if there's an updated version (probably 4K).
I haven't throw every odd resolution or refresh rate at it, but I've tried a lot. I can set it to 100 Hz in Windows 98 and it works wonderfully (but you need a good VGA cable to do this without degradation). For regular 320x200 or 640x480 with 2x on the OSSC it looks beautiful. Its scaling of 800x600 and 1024x768 is also good, to my eyes at least.
I run two inputs into it: one Windows 11 PC via DisplayPort, and one retro PC via HDMI/OSSC. It automatically detects whichever PC the signal is coming from and switches to it, and maintains the 16:9 or forced 4:3 setting depending on the input. Basically, I never have to touch the monitor settings.
Note that there are other Dell monitors with similar model numbers, but they have very different features, so be careful.
Reply 11 of 12, by Imperious
My 32inch LCD (LG 32GK650F-B) only supports maintaining aspect ratio, but I just adjust the OSSC settings until I get a 4:3 image on the screen.
It's a bit of a pain having to make adjustments fairly often when changing systems, but still a lot better than forking out hundreds of $$$ more.
It's unfortunate the RGB2HDMI doesn't support 256 colours as that would have been a good cheap alternative.
