First post, by analog_programmer
This in not a question, but a "quick" AT (286) BIOS HDD table editing manual and it doesn't fix any BIOS executable bugs.
Brief introduction to the problem:
I couldn't find any instructions (0r properly working tool) on how to (manually) edit the Award BIOS of my 286-board since its all 47 HDD table record entries are populated and because of this I can't use my only working little old HDD with it. Also some of those (if not all) 286 Award BIOSes lack "user defined" option ("Type 47") for manually/auto adding new parameters for hard disk drives non-existing in the BIOS HDD table record entries. I found one very buggy DOS tool named "BIOSUTIL" for adding a new HDD parameters into BIOS dump-file (if there is at least one empty HDD table record entry left different from number 15), which was of no real use in my case with the fully populated BIOS HDD table, but helped me for my research.
And here's what I came with by the method of reverse engineering + some trial & error:
** For AT (286) systems with 256 kbit (32 kB) Award or older Phoenix BIOSes:
The first HDD table record entry usually starts at address 0x6401, the last (number 47) ends at address 0x66F0. Table record entry number 15 (0x64E1 - 0x64F0) is empty and can not be used by standard.
** For AT (286) systems with 512 kbit (64 kB) older AMI, newer AMI "color" (also used in 386 & 486 systems), MR (Microid Research) or newer Phoenix BIOSes (I doubt that these need any manual HDD table editing, but just in case):
The first HDD table record entry usually starts at address 0xE401, the last (number 47) ends at address 0xE6F0. Table record entry number 15 (0xE4E1 - 0xE4F0) is empty and can not be used by standard.
AT (286) BIOS HDD table record entry pattern:
Cy Cy HH 00 00 WP WP 00 >> 00 00 00 PT PT SS 00
| | | | | | | | | V
| | | | | | | | | 1 zero byte (0x00, LE: "00")
| | | | | | | | V
| | | | | | | | 1 byte for number of Sectors,
| | | | | | | | max: 255 (0xFF, LE: "FF")
| | | | | | | V
| | | | | | | 2 bytes for "Parking" Track (Sector) number,
| | | | | | | max: 32767 (0x7FFF, LE:"FF 7F")
| | | | | | V
| | | | | | 3 zero bytes (0x000000, LE: "00 00 00")
| | | | | V
| | | | | 1 byte - if Heads are more than 8: 8 (0x08, LE: "08"),
| | | | | otherwise 1 zero byte (0x00, LE: "00")
| | | | V
| | | V
| | | 2 bytes for Write Precompensation Cylinder number,
| | | max: 32767 (0x7FFF, LE: "FF 7F"),
| | | for N/A: 65535 (0xFFFF, LE: "FF FF")
| | V
| | 2 zero bytes (0x0000, LE: "00 00")
| V
| 1 byte for number of Heads, max: 255 (0xFF, LE: "FF")
V
2 bytes for number of Cylinders, max: 32767 (0x7FFF, LE: "FF 7F")
Instructions on BIOS dump-file editing:
1. Get a dump-file of a 286-motherboard BIOS you want to edit.
2. Use your favorite hex-editor to find the HDD table record in your BIOS dump-file.
3. Hex-edit one of these HDD table record entries (or use some empty entry field in ranges 1-14 and 16-47 as the number 15 is always empty and unusable by the standard) according to the given 16 bytes long pattern and your real HDD's CHS specs (convert the decimal values to hex values "little endian" ordered as needed), and voila - you'll get a table entry for your particular model hard disk drive.
4. Don't forget to recalculate a new BIOS checksum!!!
4.1. Checksum correction for 256 kbit (32 kB) Award 286 BIOSes:
8-bit modular sum method (for bytes 0x00 to 0x7FFE) works fine and just write the calculated hex-value in the last byte (at address 0x7FFF) of the BIOS dump-file.
4.2. Checksum correction for 512 kbit (64 kB) MR 286 BIOSes:
8-bit modular sum method (for bytes 0x00 to 0xFFFE) works fine and just write the calculated hex-value in the last byte (at address 0xFFFF) of the BIOS dump-file.
4.3. Checksum correction for older 256 or 512 kbit (32 or 64 kB) AMI 286 BIOSes:
Go figure it out or try to use something like this AMI 286 BIOS checksum hack:
4.4. Checksum correction for newer 512 kbit (64 kB) AMI "color" BIOSes (also used in 386 & 486 systems):
Use my Python checksum bytes calculation and BIOS-dump file auto-parching script attached in this post.
4.5. Checksum correction for older 256 kbit (32 kB) and newer 512 kbit (64 kB) Phoenix BIOSes:
No info.
5. Open a bottle of cold beer and enjoy the good work 😉
Some final notes:
1) All the data bytes in these HDD table record entries are "little endian" (LE) ordered hex numbers;
2) Given "max" values are based on the maximum values accepted by the mentioned cr*ppy DOS tool - "BIOSUTIL" and used only as visual "little endian" ordered hex numbers representation examples. The most realistic acceptable working CHS maximum values are 1024 for Cylinders (0x0400), 16 for Heads (0x10) and 63 for Sectors (0x3F) giving a maximum real HDD volume of 504 MB (1024 * 16 * 63 * 512 / 1024^2) - as Jan Steunebrink (Chkcpu) suggested in his comment:
Chkcpu wrote on 2025-06-18, 18:50:
Note that the 286 BIOS is non-translating so it is limited to 504MB, and the maximum CHS values are 1024 Cylinders (400h), 16 Heads (10h), and 63 Sectors/track (3Fh).
3) Table entry number 15 is always empty and can not be used even in the newer BIOSes (for 386, 486, P-class, etc,) - I don't know why, probably some limited 8086/8088 compatibility inheritance. Again Jan Steunebrink (Chkcpu) gave some details in his comment:
Table record number 15 is indeed never assigned. Because of the original expectation that there would never be more than 15 driv […]
Table record number 15 is indeed never assigned. Because of the original expectation that there would never be more than 15 drive types in existence, only a single byte of CMOS memory was assigned for 2 drives. Of course, this limit was quickly exceeded, so another extended CMOS byte was assigned for each drive. The extended CMOS byte is used as the drive type when the original CMOS nibble type is 15. This is handled transparently by the setup program, however it explains why drive type 15 can’t be used.
(Book source: “The Undocumented PC, Second Edition” by Frank van Gilluwe.
https://archive.org/details/The_Undocumented_ … rankvan_Gilluwe
page 561.)
4) Don't ask me about the weird ">>" byte with only two valid hex values related to the heads number (0x00 or 0x08) - back in the 70's and 80's there was an unlimited number of PC-engineering idiots with a bunch of limiting standardized ideas. Deunan gave a suggestion in his comment:
Deunan wrote on 2025-06-19, 12:04:
As for the weird "over 8 heads" byte, I have some theory about that. There are some MFM controllers (from WD) that handle 8+ heads differently. There's a jumper for that on some cards. Basically it has to do with what head code is stored in the sector header, sometimes only 3 bits are used and thus heads 8-15 are stored as 0-7. This is not a problem as long as the controller that formatted the HDD is used to R/W it, but will fail if the HDD is moved to a card with a different/newer chip that stores all 4 bits. Perhaps the weird byte was some sort of attempt to create an extra flag, which would allow particular HDD types to have a software workaround for controllers that could switch the mode via a register rather than a jumper?
5) Don't ask me about details for Phoenix BIOSes as I don't have such a BIOS for my 286-board. The given HDD table records pattern is one and the same for every BIOS regardless of its manufacturer. Go find the table's address location in the Phoenix BIOS for yourself - it's really easy to spot the populated HDD table records in hex-editor;
6) Don't ask me to share the cr*ppy "BIOSUTIL" DOS tool here - it's "ab*ndonw*re".
Thanks for reading and happy 286 BIOS editing! 😉
Edit history
EDIT1: Added some byte-size corrections.
EDIT2: Added some explanations and real maximum CHS values in "final notes 2) & 3)" by Mr. Steunebrink (Chkcpu).
EDIT3: Added some notes in "final notes 4)" by Deunan.
EDIT4: Added some AMI 286 BIIOS checksum details in 4.3. - thanks to feipoa.
EDIT5: Deunan pointed me, that there are 286 motherboards with AMI "color" BIOSes - added checksum correction for those in 4.4.
EDIT6: Updated link for my checksum correction script "amichksumcalc3.py" in 4.4.
EDIT7: Added info for BIOS HDD table records in those ancient Phoenix BIOSes.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 1 of 23, by Chkcpu
Hi analog_programmer,
Thanks for your 286 BIOS HDD Parameter table patching guide.
This is very useful information for us retro PC enthusiasts! 😀
To improve this guide, here are some remarks/additions.
AT (286) BIOS HDD table record entries pattern:
I’m afraid you confused bytes and nibbles here.
https://www.dataunitconverter.com/blog/bit-nibble-byte
You indicated the amount of nibbles for each record item, so the number of bytes is half of that.
Therefore, each of the 47 records in the table contains 16 bytes, not 32.
4. When calculating the 8-bit checksum, only adjust the last byte (at offset FFFFh for a 64KB BIOS) to arrive at zero with this last byte included in the addition.
The byte at offset FFFEh is the model_type and is FCh for a 286 or later PC.
Some final notes:
3) Table record number 15 is indeed never assigned. Because of the original expectation that there would never be more than 15 drive types in existence, only a single byte of CMOS memory was assigned for 2 drives. Of course, this limit was quickly exceeded, so another extended CMOS byte was assigned for each drive. The extended CMOS byte is used as the drive type when the original CMOS nibble type is 15. This is handled transparently by the setup program, however it explains why drive type 15 can’t be used.
page 561.)
Cheers, Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 2 of 23, by analog_programmer
Hi analog_programmer, […]
Thanks for your 286 BIOS HDD Parameter table editing guide.
Hi, Jan! Your remarks are correct. I'll make the corrections about the 16 bytes (not 32 bytes as I mistakenly wrote) for the pattern lenght in my first post, as I often mess in hurry these hexadecimal visual number representations. You know that all the table entries are 16 bytes long, not just the 47-th entry. Also the last checksum byte instead the two bytes - I've done the same stupid byte representation mistake.
As for the "max" values, I don't claim that 1 TB of HDD is usable on AT machine by this BIOS editing (you know what I mean 😉 ). Those values are just "examples" acceptable by the not-so-useful and buggy "BIOSUTIL" software and that's why I made an explicit final note 2) on this. The one, who will gonna make a modified 286 BIOS for non-existing HDD table entry, has to be aware of what's the real HDD's maximum acceptable volume by the edited 286 BIOS and his real CHS values for his HDD. I'll add the suggested real maximum values for CHS maximum values in note 2).
Thanks for these corrections!
Some final notes: 3) Table record number 15 is indeed never assigned. Because of the original expectation that there would never […]
Some final notes:
page 561.)
Cheers, Jan
So, I guessed correctly about the idiots with the standardized limiting stillborn ideas a-la "640 kB ought to be enough..." 😁 But it's good to learn some new details about this empty unusable table entry number 15 and how the things were "patched" after the limiting ideas took their place as standard.
Thanks for your opinion, corrections, notes and remarks! You're the only one "ancient BIOS" modification expert here.
Reply 3 of 23, by jakethompson1
A caveat is that there will be a large overlap between BIOSes without type 47, and an IRQ acknowledgement bug preventing reliable use of IDE/CF drives, described here Re: JCS286/SCAT (82C235) Motherboard among other places on the forum.
Reply 4 of 23, by analog_programmer
jakethompson1 wrote on 2025-06-18, 20:17:
With all my respect to your work and research on some old BIOSes: Sorry, but I can't help with BIOS executable code bugs as I don't read op-codes like my native spoken language. And this is not a BIOS bug-patching manual.
I'll remove all the "patch"-ing words, so not to mislead the ones, who expect some modern HDD/CF-card + ancient 286 BIOS "miracles" here.
P.S. On some of the 16-bit ISA I/O controllers there is an option for selecting the PIO modes by some jumpers. I don't know if such a hardware setting for lower HDD transfer speed (with higher cycle time) can solve this "fast" HDD BIOS bug, but someone can try it. Again - this is a topic for another thread.
Reply 5 of 23, by Deunan
Few of my own notes that somebody might find useful:
- Drive types (1-47) might map to different geometries on different BIOSes/mobos. Especially starting with 24 and onwards.
- AMI BIOS might be using a 16-bit checksum stored at 0xFF50.
- Very early BIOSes might require the sector count to be 17, and some parts might be hardcoded for that.
And a reminder that quite a few of these old BIOSes are buggy and will report to DOS one cylinder less than what is set, or perhaps this was done on purpose to always alloacte last cylinder to landing zone? Having LZ>CYL fixes it on some BIOSes but not all. The result of this "bug" is FDISK is never using the very last cylinder of the HDD, and for older, small drives (80MB and less) this is actually quite a loss of usable space.
Reply 6 of 23, by maxtherabbit
I thought FDISK itself was responsible for reserving the last cylinder
Reply 7 of 23, by analog_programmer
Hi, Deunan, and thanks for the given details! I'll make some comments on them, based on my experience and research.
This is possible. If you can't rely on CHS data from the HDD's label, one solution to get the needed specs for the BIOS HDD table entry is to attach the hard drive to motherboard with "user define" option for auto-detecting HDDs. This was the way I got WPC number and "Parking" Track (Sector) number for my HDD and the CHS from its label matches the data from the BIOS with HDD auto-detection option.
I can't confirm this 'til I revisit those AMI BIOSes that I have for m 286 motherboard - 7 different AMI BIOSes from 7 different 286 boards with the very same chipset for the time period 1988-1990 (including). Generally these AMI BIOSes don't need any BIOS HDD table editing as they have an option to enter drive parameters for user's HDD.
For the MR BIOS that I have I checked it's for sure - the checksum byte is the last one (at address 0xFFFF).
For all the early hard disk drive models in the BIOS tables I've inspected the hardcoded value for the Sectors count is 17 (0x11). And this is valid for newer ( 386, 486, etc) BIOSes as well.
This byte is really weird one and the BIOSUTIL tool totally ignores it when creating a new table record entry for HDD with more than 8 heads - it always writes value of 0 (0x00) no matter if heads count is bigger or smaller/equal to 8. Good to know that it's related to those very early MFM drives. I included the condition when it has to be manually written as 8 (0x08), 'cause I see the same patterns in 386 BIOSes and just to be safe (BIOSUTIL is buggy and I can't trust its byte ignore here).
For note 4) in my first post I will add the link to your post later.
OK, good to know this possible bug. But for the best BIOS HDD table editing results we have to rely on the actual hard drive CHS specs and not on what the BIOSes "report" to DOS.
EDIT: On a second thought: What if FDISK treats the "Landing Zone", "Parking" Track (Sector) or the surface of the HDD's plates were the heads "rest" when HDD is powered off as an entire unusable Cylinder instead of a single unusable Track (Sector)? This could be implemented for data safety reasons and may explain the "bug" in some particular cases.
Reply 8 of 23, by analog_programmer
analog_programmer wrote on 2025-06-19, 15:11:
I can't confirm this 'til I revisit those AMI BIOSes that I have for m 286 motherboard - 7 different AMI BIOSes from 7 different 286 boards with the very same chipset for the time period 1988-1990 (including)...
Ok, we're both wrong about these checsum bytes in the AMI 286 BIOSes.
You're messing it with AMI 386/486 "color" BIOSes:
jakethompson1 wrote on 2021-08-28, 02:34:
Finally it also appears that the two-byte checksum is most likely stored at ff50h.
And I messed it with MR 286 BIOS that I've tinkered with. And this "universal" scr*wed-up "BIOSUTIL" tool treats all the BIOSes checksum's bytes the same way (as for Award), which is very inappropriate if used on AMI 286 BIOS (but still works with MR). I have to write some more detailed notes when testing multiple things at once.
For now I can't find any clue where are these "magic" checksum bytes or byte in these AMI 286 BIOSes. There is a hack in another forum's thread to bypass the checksum test on AMI 286 BIOS POSTing:
feipoa wrote on 2025-03-07, 13:18:
I disabled the checksum.
Offset: 819A
changed 74 to EB
In general no one should mess for a good reason with the AMI 286 BIOSes HDD table records, as these have a built-in BIOS option for HDD parameters user input. So I don't see any reason to dig into this more.
Reply 9 of 23, by Deunan
That AMI BIOS is also used on newer (20MHz+) 286 mobos, but yeah, it does allow user-definable HDDs so there is no need to hack it. Disabling the checksum test is another option, I did that too for some experiments with 486DLC patches, but for burning the final EPROM it's better to fix the checksum. This way the image can be quickly validated for any weak bits or degradation in few years time - even if the original image used to create it is lost.
Reply 10 of 23, by analog_programmer
Deunan wrote on 2025-06-20, 13:37:
Ok, if you are sure, that there are 64 kB AMI "color" BIOSes (the ones for 386/486 motherboards) for some of the latest 286 mobos, then check this out 😉
Can you give me some example for a 286 mobo with 64 kB AMI "color" BIOS to test my checksum script with its BIOS?
Reply 11 of 23, by Deunan
Here's the BIOS in question. Mobo is PCChips M218, looks like this (mine is SIMM based): https://theretroweb.com/motherboards/s/pcchips-m218
I don't remember exactly how that BIOS looks like but it sure is AMI and has 16-bit checksum.
Reply 12 of 23, by analog_programmer
Deunan wrote on 2025-06-20, 23:26:
Thanks. This really looks like AMI "color" BIOS with BIOS date from 05.05.1991. My script "says" that the two checksum correction bytes at address 0xFF50 are "FB 98" (LE ordered) and the calculated file checksum (16-bit "word" sequential 16-bit sum) is equal to 0 (it validates correctly).
So, at the end you're actually right - there are some later 286 boards with AMI "color" BIOSes and my script can be used to auto-correct their checksum bytes after manual editing/patching them.
I quickly checked if the HDD table record uses constant address in couple of different 386 AMI "color" BIOSes and yes - it uses the same starting "point" 0xE401.
Reply 13 of 23, by analog_programmer
I found some Phoenix BIOSes for my 286 mobo - one 32 kB and three 64 kB dump files. Their HDD table records addresses match the ones of the other BIOS brands .
Anyone familiar with the old Phoenix BIOS checksum protection mechanisms?
Reply 14 of 23, by Ixide
Hi everyone,
I found a method to calculate the checksum for old AMI 286 BIOSes and some "color" AMI 286 systems.
The principle is the same as the one used for AMI "color" (386 & 486 systems), but the calculation does not start from the very beginning of the dump – it starts from the middle, at address 0x8000.
I assume this is because two ROM chips are used (even and odd addresses).
I modified analog_programmer's script to allow changing the start offset for the calculation, and also removed various dump checks that were performed before the calculation.
Reply 15 of 23, by rasz_pl
interesting
even more interesting. Do you know any more details about this?
Here is list of headers supported by my MFM decoder:
https://github.com/raszpl/sigrok-disk/blob/43 … /mfm/pd.py#L293
and actual code:
https://github.com/raszpl/sigrok-disk/blob/43 … mfm/pd.py#L1505
I have disk captures from mfm WD1003V-MM2, rll WD1003V-SR1 & WD1006V-SR2. Sadly all with 6 Head drives so I never saw what you describe 🙁
All WDs seem to use 3 byte headers (decode_id_rec_3byte) where Head number is limited to 4 bits (0x0F).
oh it was even worse with MFM/RLL controllers: https://github.com/raszpl/sigrok-disk?tab=rea … ile#screenshots :
"This is a spare/unused sector created at the end of every track on MFM drive by Seagate ST21 controller. ... Every MFM/RLL drive I looked at so far wasted precious space either leaving enough unused disk surface for one more sector per track of having one dummy sector at the end like above. I know of only DEC RQDX1/2 using all 18 sectors, but DECs next RQDX3 controller went back to 17. This translates to never using 6% of MFM and 4% of RLL disk surface you paid for, about 2.5MB on typical 40MB MFM drive. For comparison 15 years later transition to 4K Sectors (88->97% efficiency gain) was the result of HDD manufacturers fighting for every scrap of capacity."
Reply 16 of 23, by aVd
Ixide wrote on 2026-04-03, 11:13:
Hi everyone, […]
Hi everyone,
Hi, @Ixide,
I think, that this "second half" (starting from address 0x8000) BIOS checksum calculation in those old 286 AMI BIOSes (64KB) has to be done this way, because the "first half" (from 0x000 to 0x7FFF) may be occupied by some additional BIOS service programs or OPROMs, left empty or sometimes contains an unused copy of the "second half" (with the BIOS). I can't confirm at 100%, but often the actual 286 AMI BIOSes are 32KB in size. When two ROM chips are used in those old motherboards, mind that we can't work with the two BIOS dumps directly in their interlaced form, so first we need to merge (de-interlace) them into one BIOS dump file.
Thanks for the script!
EDIT: If I find some motivation, I may try to modify the script for universal 286/386/486 AMI BIOS checksum patcher.
SvarDOS fan :: artificial "intelligence" bots - not a fan at all :: say NO to systemd :: is freeware a lie, when human freedom is a fundamental lie? :: f00ck €u!
Reply 17 of 23, by Kekkula
Is there a simple program to edit old phoenix 386 bios?
I've got annoying auto detect hardrive feature on Osborne/Commodore machine.
I don't need bios level hardrive detection as I'm using xt-ide, but bios insists auto detection which takes about 2 minutes even after warm reboot 🤬
So I would like to disable hardrive routines all together from bios.
Reply 18 of 23, by aVd
Kekkula wrote on 2026-04-04, 06:50:
Is there a simple program to edit old phoenix 386 bios? I've got annoying auto detect hardrive feature on Osborne/Commodore mach […]
Hi, @Kekkula,
I assume you're asking about some kind of specific old BIOS patcher software, so probably there's none. If there's no option for "no hard drive" selection in your old Phoenix BIOS menu and you still want to disable the HDD, then you'll have to disassemble, analyze, patch and recompile the BIOS manually. I don't recall how the BIOS checksum for the 386 Phoenix BIOS is calculated, but 286 for Phoenix BIOS it's "the 8-bit modular sum method" mentioned in the OP's first post and you may try if this works with 386 Phoenix BIOSes too.
Good Luck!
Reply 19 of 23, by jakethompson1
If you link to it, and it doesn't break under emulation so that others can play with it, I'm sure someone can check it out.
