First post, by Danilo_Dias
I have an old chaintech ct-6bda Intel 440bx
https://theretroweb.com/motherboards/s/chaintech-ct-6bda
With a pentium 3 slot 1 800mhz /100mhz is it worth to upgrade to one of those adapters for socket 370 and use a Celeron 1.1ghz 100mhz fsb?
Thank you!
Reply 1 of 13, by douglar
What kind of worth are you looking to get from the upgrade?
Reply 2 of 13, by AlexZ
Definitely buy a coppermine capable slotket but use PIII 1Ghz or 900Mhz instead of Celeron. Celerons consume too much power for the performance they give you.
I thought about buying a 1100Mhz PIII (not celeron) but I don't really need that performance.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 3 of 13, by smtkr
If slotket prices are as high as they were last time I checked, it would be cheaper to buy parts for an AthlonXP setup if you're after performance.
Reply 4 of 13, by chinny22
Personally I find 600Mhz is fine for Win9x games, anything faster just means slightly quicker load times.
Anything that struggles on a P3 600 is crossing over into P4 territory.
I've upgraded just to cross the 1Ghz mark though, so if that's the goal then it's still a valid upgrade IMHO.
Reply 5 of 13, by peter_shaw
smtkr wrote on 2025-06-22, 14:56:
this!
you can get a whole athlon xp bundle (mobo + ram + cpu + gpu) for the price of just the slotket adapter...
My humble vintage PC collection: https://www.peter-shaw.de/2023/10/vintage-pcs/
Reply 6 of 13, by AlexZ
But you do not get ISA with Athlon XP. If you want a high clocked PIII, you need to buy a slotket.
An alternative is Duron/Athlon on KT133.
Reply 7 of 13, by Jasin Natael
I had a similar dilemma recently. First upgrade to 1Ghz Coppermine and that was great. But got the itch and eventually bought a cheap slocket and a modded Tualatin off ebay.
Was it worth it? Probably not but I scratched the itch.
Reply 8 of 13, by GemCookie
AlexZ wrote on 2025-06-27, 08:38:
You do with a motherboard using the KT133A chipset.
I've had the time of my life
I've never felt this way before
Yes, I swear, it's so true
I'm holding onto used hardware
Reply 9 of 13, by douglar
GemCookie wrote on 2025-06-27, 14:20:
KT133A builds can be a lot more "exciting" than a 440BX.
  • The VIA 4-1 driver experience isn't universally enjoyed
  • Balancing a heatsink on top of the Athlon XP requires more caution and dexterity compared to Slot1 or S370 Tualatin
  • KT133A boards often come from the middle of the capacitor plague, while 440BX boards frequently predate the age of the bad caps.
  • "Edge case" compatibility issues with some AGP & PCI cards
  • 686B southbridge bug that can corrupt files when doing large UDMA100 transfers w/ Creative SB Live! if not mitigated
But like all retro computing, it's not always performance or ease of use. It's about making the system that you loved, or making the system that you always wanted to love.
Many people have fond memories of the KT133A chipset and the systems can work well, even if they take a little more planning.
So to the OP, if a 1.1ghz slot1 mobo is what you always wanted, go for it. But a PIII 800 is going to give you ~85% of the performance with fewer headaches.
PIII Tualatin vs PIII Celeron
Reply 10 of 13, by sfryers
Danilo_Dias wrote on 2025-06-22, 12:22:
In my experience, the 100Mhz FSB variant of the P3-800 and the Coppermine Celeron 1100 provide almost identical performance. The extra 300MHz clock speed is offset by only having half as much cache as the P3. A Tualatin Celeron (with a compatible board or adapter) is faster as it retains the same 256kb cache size as the Coppermine P3.
MT-32 Editor- a timbre editor and patch librarian for Roland MT-32 compatible devices: https://github.com/sfryers/MT32Editor
Reply 11 of 13, by AlexZ
It would make more sense to buy the super rare Coppermine PIII 1100 (100Mhz FSB) than a Celeron. Hardly anyone has that.
Pitty that KT133 doesn't support Athlon XP. I have 4 KT133 boards, I was not lucky to buy a KT133A one. 1.2Ghz Athlons are not that common, I managed to get 3 of them while they were cheap.
Reply 12 of 13, by PcBytes
Soltek SL-75KAV is one of the boards that's got both KT133A and ISA. If anyone is looking for one, I highly recommend it. Latest BIOS is said to support mobile Bartons even.
Reply 13 of 13, by Danilo_Dias
Thank you everyone. I'll keep my slot 1 pentium 3 800mhz in it.
I already have a atlhon XP Barton build in other Pc.
