Reply 120 of 136, by feipoa
How did you feel about giving up AGP for your slot2 build?
Reply 121 of 136, by Jackhead
luckybob wrote on 2025-06-08, 23:47:
OK. Now you're just showing off.
Will you be willing to share that STL file?
Its nothing special. But if you want it, sure.
The attachment CPUBracketV3.stl.7z is no longer available
feipoa wrote on 2025-06-08, 23:56:
I feel good about it, because the board offers 66MHz PCI Slots and my voodoo clone is PCI so anything good.
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - GUS ACE - MPU-401AT with YucatanFX
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 122 of 136, by feipoa
If the board is EATX, your pickings for the case will be slim. Have you looked for the original HP case for this motherboard?
Jackhead wrote on 2025-06-09, 08:32:
Remember, only two slots can do 64-bit at 66 MHz. Would a Voodoo5 even benefit from AGP? I faintly recall reading some benchmarks which showed the PCI/AGP Voodoo's about equal. Is my memory correct?
Jackhead wrote on 2025-05-30, 06:57:
i have a 1Ghz and 900MHz 5/12V pair.
Jackhead wrote on 2025-06-08, 21:24:
I got the Mainboard and some other parts i need to power up the system.
Don't keep us in suspense any longer. Was it fully functional with the 900 MHz 2M 5/12 V Xeons?
Reply 123 of 136, by Jackhead
That will be the next problem with the case..
Atm im waiting for some power cable to connect the Powerboard with the mainboard.
HP use sometimes strange pinouts, so i have to be very carefully and double check anything before i boot the board first time.
Hopefully next week! Than i will test the 900 2MB CPUs.
About the case, i still hold on my NorthXL. It will need some dremel action, but as i now have a 3d printer im pretty sure i can do it!
And no i dont want a huge server case, this have to go in a normal eatx case. But before case modding begins i want to verify the board is working.
About the voodoo. I run it atm on a pci-x slot on another build. The benchs (PCI 66MHz) look good as AGP. Its pretty much the same.
Here some shots from the Compaq/HP parts:
The attachment GsRpsxXXMAARFYS.jpeg is no longer available
The attachment Gs13SyZWsAA84Zl.jpeg is no longer available
The attachment Gs2QrgIWoAA14l1.jpeg is no longer available
Atm im cleaning the PSU and install a new Fan. My plan is running two PSUs, the HP one powers the board only. A second small ATX one is for the Drives, Fans and GPU.
Its to much going on at the powerboard and the PSU. I dont have a pinout. Pretty sure its not a good idea using a normal ATX PSU with some self build adapters for power the Mainboard.
Maybe in the future when anything is up and running..
I still dont know if i need that ribbon cables from the powerboard to the Mainboard.
My hope is that i can connect power button and led directly on the mainboard header.
Reply 124 of 136, by Jackhead
Swapped the Fan from PSU. Pinout was flipped to normal fans. I checked the datasheet of the old fan and the noctua has same stats or better. So should be fine.
With connected power source, the one green LED on the PSU is blinking. On the Power board a LED goes on and stay.
The Fan dont spin. Im not sure that is normal? At least no magic smoke..
Still waiting for the mainboard power cable. I really hope they fit and with bridged power buttom pins the system start.
The attachment PXL_20250611_152017864.jpg is no longer available
The attachment PXL_20250611_153931428.jpg is no longer available
The attachment PXL_20250611_154004365.jpg is no longer available
Reply 125 of 136, by luckybob
This is a big sand pit trap.
OEM servers like this REALLY REALLY don't like to be incomplete and/or outside of their bespoke chassis.
I've never been successful, and over the decades I haven't seen anyone else be successful either. I don't say this to dissuade or disparage you, I'm just putting up a big warning sign.
In all servers, the fans always run when the unit is on. So if they aren't spinning, something is wrong. Or it's turned off.
I personally would look into making an adapter harness for a modern atx power supply. New supplies are superior in every metric you can measure. You are not likely to fill all 8 of those pcix slots with 75W cards. Nor are you likely going to attach a huge scsi array. Although I certainly would enjoy it. You are also not going to need or even want multiple loud power supplies.
Reply 126 of 136, by Jackhead
I think its turned off.
I looked at the Power "button" board on some pictures.
There just normal switches going without pcb directly on the Power board.
Its ok, i have low expectations. But fun to try out.
But as you say, i will connect the two ribbon cable plugs to the motherboard. Fingers crossed they are 1:1 and not have bridges.
Reply 127 of 136, by luckybob
It's almost always 1:1 - putting a twist in a cable costs money.
Reply 128 of 136, by maxtherabbit
Fan shroud looks sick af
Reply 129 of 136, by Jackhead
maxtherabbit wrote on 2025-06-11, 21:47:
Was really fun to create. Color matches perfect with the coolers. Hope it will cool also nice 😀.
More cables incomming, but still no power cables. I had to import them from uk. Sometimes its really slow..
I sort out some cards i want to use in the system:
The attachment PXL_20250613_164111265~2.jpg is no longer available
AAR-2610SA/64bit
AUA-4000C USB2.0
SB0350 Audigy 2 ZS
Reply 130 of 136, by PD2JK
luckybob wrote on 2025-06-11, 16:40:
I agree. And if one fan doesn't work all the others go weeeeeee!
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 131 of 136, by Jackhead
i guess there is no fan control in the bios that let me ignore not connected fans?
I dont know the behavior of such system.
When something is wrong there is a warning on boot or just dont boot?
Reply 132 of 136, by luckybob
it should always boot if its able, that's a server philosophy - it is a common server behavior to turn all fans to 110% if it detects one or more fan failures.
Reply 133 of 136, by Jackhead
getting closer, but i still dont understand how to connect the Power board to the Mainboard correctly.
Both voltage plugs are clear, but the two ribbon cable plugs??
So far i thinking the PowerButton board goes on the PowerBoard. But than i have 3 plugs on the Mainboard?
Systemdata i pretty sure goes directly from the PowerBoard to the Mainboard.
Someone an idea ?
The attachment PXL_20250617_134440186.jpg is no longer available
The attachment PXL_20250617_134454995.jpg is no longer available
Reply 134 of 136, by eisapc
If interested I have a complete 530 with a partially fried mobo, just the front is missing.
Located near Koblenz, Germany but can be picked up near Stuttgart as well.
Your BIOS meassages are probably related to the CPU microcode update.
It is not possible due to the CPUs are much newer than the board/BIOS, not able to provide the matching microcode update for the CPUs.
Still have two Compaq SP700 workstation boards I want to build up, but too many other projects.
The 900 MHz is really rare, I am still looking for the sixth 900/2M for my Netserver LT6000r actually at 6x 700/1M,
while my Proliant 8000 is happy with 8x 550/1M.
There was a set of six 900/2M on $AUCTIONSITE some years ago, but someone snatched the 6th one, so I ended up with only 5 CPUs for a 6 socket system.
Reply 135 of 136, by Jackhead
A complete Ml530 would be very helpfull! I send you a PM.
Reply 136 of 136, by Paadam
Great build and great effort.
I had Supermicro S2DG2 ~15 years ago that I sold for peanuts and it ran nicely pair of 900 MHz/2MB Cascades but obviously only 2.8v versions.
Right now I have Asus XG-DLS, it supports 900 MHz too but only 2.8v versions.
To run 5/12v versions in sort of acceptable computer (not fridge sized servers etc) you should look for Compaq SP750 workstation. It has i840 chipset, AGP, dual-channel RDRAM. Can be had for sort of reasonable money (at least in Slot 2 world). VOGONS user Callahan has one working with pair of 900MHz Xeons for example.
Many 3Dfx and Pentium III-S stuff.
My amibay FS thread: www.amibay.com/showthread.php?88030-Man ... -370-dual)
